Like Tree2Likes
Old 01-03-2009, 12:06 PM   #10231
TeamGoodwrench's Avatar
Originally Posted by redbones View Post
In a different reason, you need some slop on the inner hinge pins on the suspension arms. If you shim them to perfection, I found that they will bind in an event of a crash or even just a rub. Reason being that the suspension blocks may shift ever so slightly that it may apply pressure on the inner hinge. That's why I give the arms a little play (~.5mm) to compensate for that. If your car acts funny after a crash, take the shocks off and check the lower arms. They should just fall down with no effort at all. Better to have a little slop and get a free moving suspension than a binding one.
I agree with the front to back shimming -- to allow a tick of movement. My problem was that the suspension arms were sloppy on the hinge pins. That's what I wanted to get rid of -- i.e. on the rear I had "variable toe-in" lol... anywhere between 1.8 and 2.7 deg. of rear toe at any one time (I'm guessing - I didn't actually measure, but you get the idea).
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 01-03-2009, 07:37 PM   #10232
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's http://www.rctech.net/forum/electric...ox-ratios.html
RielTime Racing is offline   Reply With Quote
Old 01-03-2009, 10:48 PM   #10233
brownstone101's Avatar
Send a message via AIM to brownstone101 Send a message via MSN to brownstone101
(just a little idea nothing real serously big)
my TC shell is a little beat up and tore up and im still useing it but if u got a beat up shell if u got any car wax laying around and a wax pad like i did a little wax and a few mins can realy make ur lid look pretty spiffy for a little wile depending on were you drive it. just a little idea nothing big
brownstone101 is offline   Reply With Quote
Old 01-03-2009, 11:41 PM   #10234
R1wurks's Avatar
i tried searching this but no luck.
need help on where & what spur gear to get, for my ta05 ifs R. i need anywhere from 82T to 87t 48p.
im found a few of them out there but im not sure if its going to work with tamiya spur gear holder.
Kimbrough has some but im not sure what will fit tamiya spur gear holder.
part numbers will help too.
thanks in advance.
R1wurks is offline   Reply With Quote
Old 01-04-2009, 04:20 AM   #10235
nexxus's Avatar
Trader Rating: 302 (100%+)
On an IFS-R you're only really going to fit 70-78t 48p Spurs, anything else is too big.
I prefer the Kawada spurs.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 01-04-2009, 06:54 AM   #10236
Any reason for that? I'm about to get some 48p spurs too, wondering if machined spurs like Speedmind are worth the extra $... ? They seem half the width of regular spurs like the Kawadas.
stocker is offline   Reply With Quote
Old 01-04-2009, 07:35 AM   #10237
dameetz's Avatar
Default TA05R's FDR
My TA05R is on its way. Would like to know few things so i can order it early. I understand it does not come with a pinion so how many teeth of pinion should i get? It is 48p or 64p. I ll be putting an Ezrun 5.5 in it, whats the optimal FDR for. Its for racing on an outdoor track. Thanks.
dameetz is offline   Reply With Quote
Old 01-04-2009, 07:46 AM   #10238
any advantage of 48P over 64p?
Minami is offline   Reply With Quote
Old 01-04-2009, 08:17 AM   #10239
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
IMHO, the FDR for a 5.5T brushless (6000kV) could be anywhere from 6 to 9, depending on the size of track you are running..
I'd start with the manufacturers recommendations for whatever size track you are running on and temp it from there.
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-04-2009, 09:25 AM   #10240
TwoTone's Avatar
First thing for me was hex head screws.
http://cgi.ebay.com/Tamiya-TA05-Tita...742.m153.l1262
Those are Tamiya if you want to stay TCS legal. The off brand is only $5 cheaper so I stuck with Tamiya.
TwoTone is offline   Reply With Quote
Old 01-04-2009, 10:53 AM   #10241
48P- tougher gears against crashes, sounds like a "tamiya" car, easy to mesh, less choice in gear ratio
64P- little more efficient drivetrain, sounds nice, hard to mesh, more choices in gear ratio
anything else?
I use kawada or xenon spurs. PRS is good too, but I can't seem to get them. Only can get pinions.
redbones is offline   Reply With Quote
Old 01-04-2009, 12:12 PM   #10242
R1wurks's Avatar
will this work for my tao5 ifs r
http://www3.towerhobbies.com/cgi-bin...&I=LXWHG9&P=FR
Old 01-04-2009, 12:37 PM   #10243
Ed237's Avatar
It will fit, but its one of the smallest 64p spur gears available. You run the risk of not being able to get the motor close enough to the spur to achieve a proper mesh. Especially if the pinion you plan to use is under 40 teeth.
Ed Toth
LCRC Raceway and Bumps & Jumps.
Ed237 is offline   Reply With Quote
Old 01-04-2009, 01:23 PM   #10244
dont forget that 64P and 48p have diffrent ratios. the stock gearing for my tao5 was like isk 74/22 (just guessing) and i had to do some resurchin and found 100/30 was close to that stock ratio and it fits pretty dandy so going 64p ur spur will actuly have more teeth than a 48p spur
Old 01-04-2009, 05:37 PM   #10245
I drove a TA05 for the first time tonight and was 1sec faster then I was on my old TC3....so I am looking for a TA05 now. Where is the best online place to look for entire car kits....I bet it is covered somewhere in the 300 pages of this thread, but times change and online places change as well, so I wanted a update on this item.
Thanks for the help.
cherokee is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
