Like Tree2Likes
Old 12-22-2008, 09:30 AM   #10186
TwoTone's Avatar
Originally Posted by macscac View Post
got some parts in the mail yesterday!!
got to build some more of the car tonite.
any thoughts on next parts?
also, what is the best way to cut out the carbon?
it appears that the top deck is going to hit the lipo wire so much that it will probably rub thru the wire?
Well with all the bling, can't believe you still have the plastic suspension bridges
TwoTone is offline   Reply With Quote
Old 12-22-2008, 07:21 PM   #10187
What gearing would you suggest for a 15T modified motor? Everything is stock on there atm (70/22). I talked to my LHS owner when i bought it (Peak Racing Griffin 15x2 cheap ol thing) and he said there wouldn't really be a need to lower the pinion size but i've just had my second ESC go using the same motor so im wondering if it is a problem with the gearing.
Limerick91 is offline   Reply With Quote
Old 12-23-2008, 12:58 AM   #10188
What esc do you have? Also what sort of track are you racing on? Your ratio is fine (7.16) unless you are racing on a tight track
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-23-2008, 12:08 PM   #10189
I've got an LRP IPC V4.1 (12T limit), and yeah im racing on a tightish track, i've only used it for 3, 4 minute races though.
Old 12-24-2008, 12:32 AM   #10190
Anyone knows if there is any difference between:
#84048 TA05 Lightweight Urethane Bumper
#49462 TA05 Urethane Bumper, Black
Both have 300 Yen as the price on the cardboard. I'm not really concerned about the weight difference, but if there are material difference that affect toughness or durability.
stocker is offline   Reply With Quote
Old 12-24-2008, 07:31 AM   #10191
Jin
[QUOTE=macscac;5182086]lol!!!
did i really put the front and rear hubs on the wrong side???
LoL! try drive it like that
Jin is offline   Reply With Quote
Old 12-26-2008, 10:58 AM   #10192
TeamGoodwrench's Avatar
Default Center one-way ?
I've got a front one-way in my TA05-R (running on carpet, USVTA tires).
If I put a center one-way in it, how does it change the way the car drives compared to not having the center one-way ?
I guess my question is, if you have a front one-way, is it worth putting in the center one-way too ?
Thanks !
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 12-26-2008, 11:29 AM   #10193
Juanchoyo's Avatar
Talking
Wow!! A rear steering TA05??? An me thinkin about the IFS being weird!!! LEt me see how it works! hehe
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 12-26-2008, 04:46 PM   #10194
dameetz's Avatar
Hi guys, i m interested in getting the TA05 for my first EP touring car. I need advice from you guys on which TA05 to get. I can see there are TA05R, TA05MS, TA05IFS , TA05 IFSR... I been in the hobby for a while now racing nitro tourer and 8th scale. Recently got interest in EP touring. I will be racing this car on asphalt track with foam tyres. Will a stock TA05 be a good mid level car? Can u give me advice on which parts should i upgrade? So far i m thinking of are alum motor mount, front cvd, carbon frt and rear shock twr and TRF damper. One more thing to ask, my LHS only supply foam tyres for nitro tourer, the front tyres (26mm) should bolt in just fine but rear (30mm) is it ok to use? Will there be anything rubbing the inner part of the rim? I m asking because a friend of mine running the tyre in his Kyosho TF 5 and the shock ball end does rub the inner part of the rim. Thanks in advance for your advice.
dameetz is offline   Reply With Quote
Old 12-26-2008, 07:11 PM   #10195
05forfun's Avatar
Trader Rating: 81 (100%+)
Thanks !
I never used center one way, but I doubt it will make any difference. The center pulley doesn't have diff function (I suppose, at least my ta05 doesn't), then if you use forward only ESC the car can only go forward which means the center pulley can only rotate forward (one way), then now what is the difference between using two way and one way? The only difference I can theoretically imagine is that you can no long physically push your car backward because the center is fixed. Well as I state at the beginning I never used it, these are just based on my understanding, so if I am wrong please correct me
05forfun is offline   Reply With Quote
Old 12-26-2008, 11:17 PM   #10196
lol
im never going to live down my "rear steer" ta05!!!
i have since corrected the flaw however i havent built any more of the car.
now that christmas is over, ill find some more parts on ebay.
my only goal is to build this as "blingy" as possible.
i have no intentions of ever racing it
macscac is offline   Reply With Quote
Old 12-27-2008, 06:25 AM   #10197
OK, first the TA05R or IFSR is the way you want to go because it has all the hop-ups in the box. However, you will need to buy a body (you can choose any shell you want, the Protoform R9R or Parma Mohawk are good choices). If you want to use one of Tamiyas low front profile bodies then you need the IFSR. Forget the motor mount, the stock one is cast Aluminum and works fine but doesn't have the bling.
For asphalt the stock chassis is good. Get the softer front foams and use those in the rear.
AreCee is offline   Reply With Quote
Old 12-27-2008, 07:32 AM   #10198
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
One ways prevent the front wheels from being retarded under braking, in fact it removes the braking action from the front wheels entirely giving you a rear wheel braking only car.
This allows the front wheels to maintain a higher rolling speed into the corner, which is what is responsible for the increased turn-in that comes with using a one-way (centre or front)..
Front one way is the same as centre one way, but with a centre one way you can "tune" the front diff action to control the increased turn-in.
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 12-27-2008, 11:38 AM   #10199
So if you run a front one-way, then you would never run a center one-way too -- it seems it would really do nothing ?
Thx
Old 12-27-2008, 01:41 PM   #10200
looking at getting some suspension mounts for my car...
not sure about the degrees tho.
what degree is best for just an all around play car?
thanks
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
