Like Tree2Likes
Old 08-21-2005, 10:46 PM   #1006
ScottyP's Avatar
Does anyone know what the tire type is that comes with the TA05 Mercedes kit? Is it Type A?
Cheers,
Scotty P.
ScottyP is offline   Reply With Quote
Old 08-21-2005, 11:22 PM   #1007
ttso's Avatar
Originally Posted by Jam-ehz
You just need to get the Evo IV carbon bumper brace like I did, and you're all CF'ed out, until the R comes to replace those front and rear braces...
Haha.. you do read my mind..
In fact I'm studying if it's possible to have CF chassis. Problem is it will cost quite a $$$..
ttso is offline   Reply With Quote
Old 08-22-2005, 01:08 AM   #1008
Ghostfit's Avatar
You just need to get the Evo IV carbon bumper brace like I did, and you're all CF'ed out.
Some Ass switched on his radio and sent my 05 full bore (8T) into the boards, the CF bumper brace took all the force and even made contact with the front shocks. Hencewith, I'm running the stock bumper brace !
105T is the max (106T may work, but is pushing the clearance limits of the chassis), and Tamiya will be releasing their own TA05 105T Spur gear sometime...
I'm running Kawada's 106 spurs without any clearance problem, the motor mount has got scratches on the bottom all around the spur hole but I've not lost any 106 spurs yet ! ...maybe a 108 spur will be pushing the limit.
Ghostfit is offline   Reply With Quote
Old 08-22-2005, 01:49 AM   #1009
Send a message via ICQ to rcnewb2004
http://rc-mushroom.com/product_info....oducts_id=6906
Does anyone know will the TA05 diffs outdrives from the link above fit on a TA04??
rcnewb2004 is offline   Reply With Quote
Old 08-22-2005, 03:04 AM   #1010
ttso's Avatar
There will be problem if you running spur very small. With 64p 90T spur (Kawada), you need to use at least 36T to get a close enough gear gap, means highest ratio will be 5.4675. Anything smaller than 36T will causing problem. So unless your motor is something super torque, don't use spur which is smaller tha 94T.
Old 08-22-2005, 03:21 AM   #1011
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by ttso
I got them from ProShopFutaba, it makes car lots stiffer in pitch axis, roll axis only improve a little.
No, I race on asphalt only. Using the 2F will make the traction fade a little, but I like the solic feel...
ttso: are those carbon fiber upper deck made by Tamiya
buboy28 is offline   Reply With Quote
Old 08-22-2005, 06:56 AM   #1012
The only manufacturer that i know of that makes the top deck is Tech Racing, they make nice quality stuff, i have got the top deck and the Batt brace so far.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-22-2005, 07:08 AM   #1013
ttso's Avatar
Ya they are TechRacing parts, TCS-illegal!...
Old 08-22-2005, 07:09 AM   #1014
ttso's Avatar
I saw one 415 guru is surfing on this thread....
Old 08-22-2005, 08:36 AM   #1015
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
How close do you mesh your 64p gears?
I can get it sometimes to the point where I can "feel" the spur 'tick' when I nudge it back and forth with my finger, but can't actually see it because it's so close... it's still free when I rotate the spur and all, but is there any benefit of having it that close rather than being able to see the space?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-22-2005, 08:54 AM   #1016
ttso's Avatar
Well, I usually push the pinon all the way in, than use hand to move it out about 0.5mm, than check with flashlight see if it's too much. Not very science way but it works always for me...
Old 08-22-2005, 09:03 AM   #1017
jeffreylin's Avatar
R/C Tech Charter Subscriber
It helps to reduce the possibility of stripping the spur gear.
jeffreylin is offline   Reply With Quote
Old 08-22-2005, 02:06 PM   #1018
Internal Ratio
Anyone know the internal ratio on the 05 ? How is this car fairing on the carpet ?
Thanks,
RacerX18 is offline   Reply With Quote
Old 08-22-2005, 02:18 PM   #1019
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks,
internal ratio is 2.25
Hebiki is offline   Reply With Quote
Old 08-22-2005, 03:20 PM   #1020
blue hornet.'s Avatar
i would just be happy with a carbon reinforced plastic chassis....CF chassis could be done but would need a whole new motor mount.
AE RC8 B3.1
AE B64D
AE SC10
blue hornet. is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
