Like Tree2Likes
Old 12-18-2008, 02:15 AM   #10171
got some parts in the mail yesterday!!
got to build some more of the car tonite.
any thoughts on next parts?
also, what is the best way to cut out the carbon?
it appears that the top deck is going to hit the lipo wire so much that it will probably rub thru the wire?
macscac is offline   Reply With Quote
Old 12-18-2008, 03:38 AM   #10172
tc3team's Avatar
macsac, I would swap out the front driveshafts for universal shafts when you get chance to, taking out the dogbones will make the drivetrain a little smoother
Then, when you can get the rears swapped out too, but they are not as important. I used dogbones in the rear of my '05 for two solid seasons of racing, although the outdrive cups were rather worn where the pins slide in.
They still worked ok, just had more play in them until the dogbone turned the outdrive...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-18-2008, 03:40 AM   #10173
Drifting101's Avatar
Your front and rear hub are on the wrong ends!
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 12-18-2008, 03:42 AM   #10174
Dremel
Schumacher
Old 12-18-2008, 05:16 AM   #10175
nexxus's Avatar
Trader Rating: 302 (100%+)
Wow that looks very, erm, blingy. Pity the 3 racing chassis handles like a shopping cart IMO. I did the whole hop up a TA05 carbon fibre etc, my bog stock IFS-R now is 2 seconds a lap FASTER
..or maybe it's me
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-18-2008, 05:38 AM   #10176
tc3team's Avatar
..or maybe it's me
Probably no comparison but the standard '05 swapped out with a 3racing V1 chassis, trf shocks, front swingshafts and a spool was quick for me once it was dialled in...
I could have put it on a diet to make it a little quicker (it weighed in at 1560gr ) but I didnt have the time or money to.
If you bolt on the V2Lipo friendly chassis and use lipo, you will be well under 1500gr before any titanium/lightweight extras...
Old 12-18-2008, 07:57 AM   #10177
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
where is your ESC going to be installed?
in front or behind of the motor?
i ask because if you are putting it behind then why not just turn the lipo around?
it looks like the top deck at the rear may not foul the battery leads if orientated that way...
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 12-18-2008, 09:54 AM   #10178
lol!!!
did i really put the front and rear hubs on the wrong side???
the lipo picture is deceiving... the upperdeck actually cuts across the battery harder on the other side
and there is not as much of that deck to cut away
Old 12-18-2008, 11:06 AM   #10179
94eg!'s Avatar
Trader Rating: 17 (100%+)
lol!!!
You put the front suspension on the back of the car...
Oh well, it happens...
94eg! is offline   Reply With Quote
Old 12-18-2008, 11:11 AM   #10180
joe of loath's Avatar
cut the carbon in water (carbon dust=respiratory FAIL) with a decent dremel bit (not too decent though, as it might become a very smooth polishing bit... it would really need to be diamond but that's a little expensive)
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 12-22-2008, 01:01 AM   #10181
I am aiming for a FDR of just over 5.0, which would be a better combination (48p) or no difference?
1) 72/32
2) 70/31
Titanium Racing pinions look interesting, anyone tried them before? Will probably go with a Kawada for the spur. Appreciate any inputs.
stocker is offline   Reply With Quote
Old 12-22-2008, 03:06 AM   #10182
tc3team's Avatar
Stocker,about TiR.... I don't hate on any company or any individual, but I did notice this in this very forum...
http://www.rctech.net/forum/team-com...ed-me-off.html
I have heard of quality issues too with their pinions (noisy meshing)...
Maybe others have had better service and a better made product, all i'm saying is do some homework before you buy and i'm sure you will get the answer you are looking for.
Old 12-22-2008, 07:33 AM   #10183
Thanks Tc3team.
I read that post, I thought it was a wrong product and refund issues, not quality issues?
I'll be buying from a store, so no issues about wrong items and refunds. But if there are quality issues, then I'd better avoid it. I'll go with Kawada spurs and pinions then. thanks again!
Old 12-22-2008, 07:53 AM   #10184
tc3team's Avatar
Originally Posted by stocker View Post
Thanks Tc3team.
yes, more of a post issue than quality, but still a no dice situation
I have seen the pinion gears generate the noise, and then use a different pinion to see the noise go away, but you pays your money, you takes your pick.
Old 12-22-2008, 08:12 AM   #10185
Thanks, appreciate your inputs. Noisy pinions are no go!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
