Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 12-04-2008, 06:23 PM
  #10066
TeamGoodwrench's Avatar
Originally Posted by RielTime Racing View Post
How did you get the ride height to 5.5mm? I've been trying to lower mine to about the same height. I ended up putting rubber o-ring on the inside of the damper body on the shaft and fabricated a 2mm carbon spacer that I put under the M3,M5 M5,M4 suspension mounts. The ride height is down to about 6-6.5mm. Haven't had a chance to test it yet. Thanks
I've got the standard length springs and the collars are about 2 mm down. This is with the tires for USVTA, so that may be part of it.
TeamGoodwrench is offline
Old 12-05-2008, 02:29 AM
  #10067
joe of loath's Avatar
strange, with the kit setup mine was dragging on the floor. I had to stretch the springs to get them to fit, and add some preload.
joe of loath is offline
Old 12-05-2008, 06:49 AM
  #10068
I'll take a couple of pictures and post them here so you can see my car and compare.
Old 12-05-2008, 08:03 AM
  #10069
RCGaryK's Avatar
Has anyone picked up an 05ms? I'm thinking it has to be but just wanted to verify that the motor mount was different between the STD 05 and the MS version.
RCGaryK is offline
Old 12-05-2008, 08:06 AM
  #10070
I see yours is the R version. maybe they come with different springs?
Old 12-05-2008, 08:12 AM
  #10071
AWK
AWK's Avatar
Yes the motor mount is quite different and cannot bolt on a TA05.
AWK is offline
Old 12-05-2008, 08:30 AM
  #10072
RCGaryK's Avatar
Actually I am looking at going the other way, converting my 05 to an MS to run GT1 with. I'd like to hope all I need is the chassis plates and the motor mount, but unsure if the bulkheads and the rest all transfers over too.
RCGaryK is offline
Old 12-05-2008, 11:15 AM
  #10073
Redwings's Avatar
Originally Posted by Redwings View Post
Could someone please send me a gearing chart for an LRP 13.5 motor and possibly include the pinion and spur combos as well.
Does anyone have a method to my madness? Please help
Redwings is offline
Old 12-05-2008, 11:24 AM
  #10074
Trader Rating: 114 (100%+)
Do you have to replace the entire suspension ?
Or can you just fit the 416 steering blocks (and 1050 bearings) in the TA05-R LW front suspension ??
The 416 steering blocks will fit into the 05R parts. May have to shim one side
This what I did on my 414
Dave
dragracer72nova is offline
Old 12-05-2008, 12:20 PM
  #10075
94eg!'s Avatar
Trader Rating: 17 (100%+)
I don't think any of the parts are compatible. This is why they have different front & rear alloy bulk-heads, motor mounts, belts, etc. Frankly, I dont even know why they call it a TA05MS. My best guess would be that Satoshi Maezumi just wanted to build a long wheelbase car from Aniverssary Porche parts or something...
94eg! is offline
Old 12-05-2008, 12:44 PM
  #10076
AWK
AWK's Avatar
Sorry but no chance of that. Nothing would fit right. None of the parts convert except suspension pieces. Even the aluminum bulkhead hop up for the TA05 is different than the 05MS bulkheads.
AWK is offline
Old 12-05-2008, 01:15 PM
  #10077
RCGaryK's Avatar
Crap. Ok, thanks guys.
RCGaryK is offline
Old 12-05-2008, 01:38 PM
  #10078
94eg!'s Avatar
Here's a good deal on an 05MS. You could probably sell your R for good money and pay the difference...
http://www.muchhobby.com/shopping/pr...roducts_id=398
Of course I'de rather buy the MSXX for $50 less as it's a way better car (if you run Nimh)...
94eg! is offline
Old 12-05-2008, 01:42 PM
  #10079
RCGaryK's Avatar
Nope, want to hold onto my car I have now, just looking for a less tweak-prone chassis for GT1
RCGaryK is offline
Old 12-05-2008, 02:53 PM
  #10080
RielTime Racing's Avatar
http://www.robinsonracing.com/tips.html
Pick what size pitch size you are going to run, 48 or 64. Remember Tamiya pitch doesn't mesh well with standard 48 pitch, It's a bit different.
Then if you know what FDR (Final Drive Ratio) works for you and track you can figure out what size spur/pinion to use
Tip: Tamiya's 70t spur diameter size is the equvilant to a 93t 64 pitch diameter spur. The biggest Spur I've run in my TA05 is 104 64p anything really bigger is going to hang out the bottom of the chassis.
From what I understand a 13.5 brushless motor is supposed to be about the same as a 27t brushed stock motor. I've seen suggested FDR gear recommndations for 27t brushed/4-cell Vintage at: 5.4 - 5.7 FDR
Personally I've run FDR's at 8.0 - 5.0 in touring class depending on the track.
Hope this helps.
RielTime Racing is offline
