Like Tree2Likes
Old 11-28-2008, 10:28 AM   #9991
RCGaryK's Avatar
Originally Posted by stocker View Post
Can anyone explain what is the effect of using suspension blocks that create a toe-in or out sweep at the front? I guess on the rear, it gives the toe-in for stability.
e.g. FF: B and FR: XC
thanks!
With my 05 I have found if I mix the blocks, say a c and an A block for 1mm difference, the car should have more steering at the apex of the corner. If you're mixing blocks to add static toe-out to the chassis then you're doing it wrong; that's what your steering links are there for.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-28-2008, 07:42 PM   #9992
Yeah, it's for handling. thanks for the info.
stocker is offline   Reply With Quote
Old 11-29-2008, 07:14 PM   #9993
spring71's Avatar
Default sintered rotor for EX
I have a Novak EX 13.5 motor with bonded rotor and SS5800,Novak 5.5L motor with sintered rotor.
Can I use SS5800's or Novak 5.5L's sintered rotor for EX 13.5 ?
spring71 is offline   Reply With Quote
Old 11-30-2008, 05:20 PM   #9994
Redwings's Avatar
Default Gearing info
Could someone please send me a gearing chart for an LRP 13.5 motor and possibly include the pinion and spur combos as well.
Redwings is offline   Reply With Quote
Old 11-30-2008, 07:47 PM   #9995
TeamGoodwrench's Avatar
Default TA05-R setup help for USVTA ?
Hey guys --
Need some setup help with my TA05-R for USVTA -- I need more rear traction.
I've got the 3-hole shock pistons, 50 wt oil front with white Tamiya springs, 30 oil rear with blue Tamiya springs. Front one-way.
Stock shock mount locations per the manual.
Thanks !
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 11-30-2008, 08:06 PM   #9996
RCGaryK's Avatar
Where are you looking for more rear traction? Entry, mid-corner, or exit?
What front and rear suspension mounts are you using? Are you running LiPo or 4-cell? Are you running the stock A-Arms, LW, or Short LW?
HorizonHobby.Com
Old 11-30-2008, 08:13 PM   #9997
I'm looking for more rear traction on entry.
In the front, I have the 1A bridge and 1A mount. In the rear I have the 1A bridge and 1D mount, with 1 deg. rear uprights.
The car is the TA05-R, so it has the LW suspension arms.
I'm running 21.5/LiPo.
Old 11-30-2008, 08:24 PM   #9998
RielTime Racing's Avatar
Originally Posted by Ridge_Racer View Post
Hi
I'm having an issue fitting trans-am tires on my Ta-05. The front tires hit the ball cup and the back side of the steering knuckle. How much have you guys shimmed your fronts in order to get the front trans am tires to work?
Thanks for the help
For a quick fix I just used a washer between the wheel and hex spacer. After running that for a few weeks I then upgraded to a thicker aluminum hex spacer made by Yeah Racing.
RielTime Racing is offline   Reply With Quote
Old 11-30-2008, 08:28 PM   #9999
RCGaryK's Avatar
Take some droop out of the rear. Sounds like you're transitioning too much weight to the nose. I want to say I am running 5.5mm ride height with 1.5mm droop on all 4 corners on mine on carpet. You could also go from the blue rear springs to yellows. That may help but I'm more confident in the droop
HorizonHobby.Com
Old 11-30-2008, 09:48 PM   #10000
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
+1 for less rear droop
In my experiences, this is probably one of the most overlooked settings.
-Mark
mok is offline   Reply With Quote
Old 12-01-2008, 12:16 AM   #10001
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Default ball differential pulley
Guys, I melted the holes on my ball differential pulley (part no. 53935) is there any better alternative for this part and the stock differential joint (part no. 53849), I'm looking something that can withstand the power of the modified motors.. thanks a lot.
Pro4, TA05R, Cyclone TC, 3PK2.4, NGLLRME, TA04R
grizzle is offline   Reply With Quote
Old 12-01-2008, 12:22 AM   #10002
mok
mok's Avatar
I've not come across an alternative diff pulley, but I can assure you I would be using one if it were made from a slightly hard plastic (the teeth wear away when the belt strips etc).
I would be using these however...
http://www.tamiyausa.com/product/ite...oduct-id=53889
I've melted many diff joints (stock and high precision) with modified motors and can assure you that the aluminium diff joints are worth it. The only thing about these however, is the dogbone end that goes inside them starts to wear a groove in the outdrive cups when running modified motors. You're still going to need replacement diff cups, but maybe a couple sets a year as opposed a set of the plastic ones every month/week.
-Mark
Old 12-01-2008, 12:29 AM   #10003
nexxus's Avatar
Trader Rating: 302 (100%+)
I run the Blue Alloy outdrives and the 37t pully (18t in the middle) and haven't had an issue with my TA-05
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-01-2008, 01:53 AM   #10004
grizzle's Avatar
Default drive cup
Anybody have experience in using this aluminum differential joint from 3 racing..?
http://www.rcmart.com/catalog/rc-ta0...th=595_744_720
and also this differential pulley from 3 racing...
or its better the tamiya ones.. ?
Old 12-01-2008, 01:56 AM   #10005
grizzle's Avatar
Default parts
Do you have the part numbers please? are they tamiya parts?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
