Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 11-23-2008, 10:59 PM
  #9976
Drifting101's Avatar
Originally Posted by TwoTone View Post
I was bored and looking at hop ups on Tamiya's site.
Anyone tried these? http://www.tamiyausa.com/product/ite...roduct-id=1004
Yes didnt really feel a difference......so thank goodness it was borrowed not that i bought a set at that price
Originally Posted by stocker View Post
Looks expensive!
us$70 is the street price
Originally Posted by macscac View Post
i must say... i do love the activity and involvement here on this forum.
over at rc universe it can take days, if ever, to get a response
thanks for all the involvement and help!!
Some times it can take up to 2 days but that is rare and yesterday i was bored so i just answered your q's
Drifting101 is offline
Old 11-24-2008, 12:02 PM
  #9977
Hey i just got a TA05. The upgrades i have on her is trf shocks and alluminum rear diff cups in the rear. Is there any upgrades i can do to the TA05 to make it more competitive but, not break the bank? Also, what gearing should i run? I want to run 64p(i have 103 64p)spurs. The highest pinions i have are 29,32 and 35t. If i want more speed do i get a bigger or smaller spur? I am going to run the rubber class with a peak racing 19 turn motor and a Novak TC ESC. Thanks. Tekno.
GSCL-1 is offline
Old 11-24-2008, 01:26 PM
  #9978
Originally Posted by GSCL-1 View Post
but not break the bank? .
LOL
thats what im doing!! breaking the bank!
i cant stop it...
ordered 60 dollars worth 2 days ago.. another 84 just moments ago....
and not even close to done...
there is just way too many good things available for these cars!!
macscac is offline
Old 11-24-2008, 03:02 PM
  #9979
kavadni's Avatar
Big Pinion = Higher top speed and less accelleration
Small Pinion = More acceleration and less top speed.
I've just run a checkpoint 19T for 4 meets at two tracks.
Basketball sized carpet track was 105 and 29.
Huge track Asphalt 245 meters was 105 and 41
Kevin
kavadni is offline
Old 11-24-2008, 09:00 PM
  #9980
thanks for the fast response. Tekno.
another question if i wanted to convert the TA05 suspension to ifs suspension what parts do i need? Thanks.
GSCL-1 is offline
Old 11-27-2008, 07:32 PM
  #9981
Can anyone explain what is the effect of using suspension blocks that create a toe-in or out sweep at the front? I guess on the rear, it gives the toe-in for stability.
e.g. FF: B and FR: XC
thanks!
stocker is offline
Old 11-28-2008, 01:42 AM
  #9982
joe of loath's Avatar
thanks!
it should say in the manual, but more front toe out means twitchier steering, and more toe in means a more stable front end that understeers slightly.
joe of loath is offline
Old 11-28-2008, 01:45 AM
  #9983
tc3team's Avatar
thanks!
My limited understanding is I *think* that its to use the lightweight wishbones, as they are not as wide, so you use the X version blocks for the lightweight wishbones and the non prefixed X blocks for the standard wishbones....
Dont quote me on that though!
tc3team is offline
Old 11-28-2008, 06:18 AM
  #9984
Satoshi's setup on the Tamiya site uses B/XC and so this this other setup for asphalt. So I wondering if there is a corelation there.
stocker is offline
Old 11-28-2008, 06:32 AM
  #9985
kavadni's Avatar
The various suspension blocks enable you to adjust both toe and track width.
TryHard has a reference http://www.thard.co.uk/viewtopic.php?f=24&t=30
kavadni is offline
Old 11-28-2008, 07:19 AM
  #9986
What's the best way to position the sensor cables in the 05? The motor protection bar seems to be partially in the way.
In this thread, I found 2 ways,
1) Reenmachine in Post #9574 is under the bar
2) AreCee Post #9576 is between the motor end and bar.
I had it under the bar, but I just had one of the wires break, very likely from abrasion from the track during roll. "In between" looks like bending the wires quite a bit, will that cause the wires to break internally?
stocker is offline
Old 11-28-2008, 07:26 AM
  #9987
Thanks, this helps!
Good adjustment tool, but not cheap if the wrong blocks are purchased!
stocker is offline
Old 11-28-2008, 07:29 AM
  #9988
tc3team's Avatar
not an ideal or cheap solution, but the v2 3racing chassis is open plan, with no bar to get in the way.
tc3team is offline
Old 11-28-2008, 08:35 AM
  #9989
I don't have it infront of me ATM, but I think there is enough material in the bar to remove a section so the wires can go through it?
Old 11-28-2008, 09:25 AM
  #9990
RCGaryK's Avatar
Originally Posted by Ridge_Racer View Post
Hi
I'm having an issue fitting trans-am tires on my Ta-05. The front tires hit the ball cup and the back side of the steering knuckle. How much have you guys shimmed your fronts in order to get the front trans am tires to work?
Thanks for the help
I started using the 4mm hexes with 2 red and a blue shim to space the tires away from the knuckle. I've since ordered a set of 6mm hexes (TAM53569) from my LHS to try to eliminate so many shims and to get more engagement to the wheel hex and the drive hex.
RCGaryK is offline
