Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 11-21-2008, 04:06 PM
  #9946
RCModel in Hong Kong is very reliable and priced right if they have the inventory in stock.
AreCee is offline
Old 11-21-2008, 04:59 PM
  #9947
I just checked them and they were sold out of everything I wanted
redbones is offline
Old 11-21-2008, 05:17 PM
  #9948
myan_gsr's Avatar
Originally Posted by CMB21 View Post
Hey all,
I am sure this has been asked before but with 330 pages i dont like my chances of finding it.
Just got some lipo's and i run in 540 Pro class, which is the johnson or mabuchi 540 silver can motors. This class was closely contested until a few of the other racers moved to lipo packs where they started dropping 1 to 2 seconds if not more off there lap times.
What is the best gear ratio to run in the ta05 for the 540 pro class with lipo packs? And what fdr should i be aiming for now that i will be running lipo packs.
Thanks for the help.
Hey,
The common 540 Pro gear range at my club is between 3.95 - 4.3. Use 3.95 only for really open tracks, it seems to be the limit for consistent running, though you still see people burn them out in a days racing. I personally keep the ratio between 4.2 and 4.3 as the motor comes off a little cooler .
myan_gsr is offline
Old 11-21-2008, 07:03 PM
  #9949
badboy's Avatar
Trader Rating: 14 (100%+)
Default help with 13.5bl gearing
hi guys,
what gearing do you suggest for a TA05 with a 13.5 orion bl motor? What's the best spur/pinion combo running it with orion 3800 lipos.
thanks in advance.
badboy is offline
Old 11-21-2008, 09:29 PM
  #9950
CMB21's Avatar
First of all myan thanks very much for actually posting up an fdr. A good starting point is all i was asking for. And its a bit hard to ask the other guys when we have finished for the year.
Originally Posted by tc3team View Post
+1, cant see it making a vast difference, a tooth or 2 max to what you are using now? Maybe its the punch out the corner that is pulling the lap times down and not the gearing?
Follow the guy around the track and see where you're lacking I guess would be a good starting point
I can guarantee you that it does make a difference and a noticable one at that. Not just the pull out of the corners, they have more straight line speed.
CMB21 is offline
Old 11-22-2008, 02:04 AM
  #9951
DJ
Originally Posted by badboy View Post
hi guys,
thanks in advance.
I had been adviced to use 4.5 fdr
100(spur)/50(pinion)*2.25=4.5 or equivalent
DJ is offline
Old 11-22-2008, 02:17 AM
  #9952
aussierevo's Avatar
does anyone have a 60a 5.5t in their ta05......installed mine and running about 6.2 to 6.5.......102 spur 36 pinion. motor is hot....any suggested fdr?
aussierevo is offline
Old 11-22-2008, 02:23 AM
  #9953
DRAG_ON's Avatar
hi guys,
thanks in advance.
it's really depend on your track size mate, i'm using 13.5 speed passion i gear it down to 4.5 the track contents 1 straight line, several chicane, and no hairpin at all so i can gear it down to 4.5 FDR...............using EP4200 cells it can run 8 minutes with rubber tires, temperature up to 60 celcius not too hot even with hot weather track temp up to 60 celcius
DRAG_ON is offline
Old 11-22-2008, 02:42 PM
  #9954
Drifting101's Avatar
Closer to 8.5
Drifting101 is offline
Old 11-22-2008, 04:33 PM
  #9955
hi!
just started building my ta05 last nite.
i just bought these on ebay for 35 bucks for the pair.
front and rear aluminum bulkheads..
havent seen any photos of anyone with these on their car.
your thoughts?
cool? gimicky?
thanks
c
macscac is offline
Old 11-22-2008, 04:36 PM
  #9956
They add much needed strength, improve flex and are MUCH easier to set belt tension
Old 11-22-2008, 04:38 PM
  #9957
Here was my 05 before i swapped it for a 4wd buggy
Edit: Forgot link
http://s279.photobucket.com/albums/k...%20For%20Sale/
Old 11-22-2008, 04:40 PM
  #9958
aussierevo's Avatar
thanks drifting101....will give that a try
Old 11-22-2008, 04:42 PM
  #9959
No worries that is why i am here
Old 11-22-2008, 06:16 PM
  #9960
drifting... was this comment in regards to my question about alum. bulkheads?
macscac is offline
