Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 11-14-2008, 07:40 AM
  #9916
94eg!'s Avatar
Trader Rating: 17 (100%+)
You did right setting both belts the same. All belts aren't made equal, so one will almost always be different than the other. No big deal. Idealy you want the belts as loose as you can run them without skipping for reduced friction...
94eg! is offline
Old 11-14-2008, 09:17 AM
  #9917
I had the belts at the point where is just doesn't skip. But it seems the belts vibrate so much that my top speed was hindered. I made it one notch tighter, and felt the car pull faster. Also, the TA05 chassis flexes forward, so your belts actually get looser upon braking. Make sure you test the tension of the belts while listening during full braking.
redbones is offline
Old 11-14-2008, 07:57 PM
  #9918
Drifting101's Avatar
That can be a problem with brushless i have seen many pulley stripped because of the loosness of belts and with my mi3 i have set the belts very loose and very tight ......... tight drives nicer and less rolling friction
Drifting101 is offline
Old 11-14-2008, 08:06 PM
  #9919
TwoTone's Avatar
I'll try asking again, anyone have a decent carpet/rubber set up they wouldn't mind sharing?
TwoTone is offline
Old 11-15-2008, 03:16 AM
  #9920
mok
mok's Avatar
2-2.5 degree rear toe in
0.5-1 degree front toe out
4 degree caster c-hubs
front camber 2 degrees
rear camber 3 degrees
centre one way (this isnt necessary, i just liked it)
diff front set medium tight
diff rear set loose-med
tamiya white springs front
tamiya blue springs rear
60wt oil
2 hole pistons
medium front stabiliser
soft rear stabiliser
4mm front droop
2.5mm rear droop
its either going to work for you or it wont..
as far as i was concerned the box stock settings were pretty good, but i liked a stiffer car to drive
-mark
mok is offline
Old 11-15-2008, 08:10 AM
  #9921
Ed237's Avatar
TA05R with Carbon Chasis
Rear Susp Mount A + Mount D (Std) No shims
Front Susp Mount A + Mount A (Std) No shims 0 degree toe
rear camber 2 degrees
Front One Way: Critical for on power steering
Front Shocks: TRF w/AE 30 lb purple springs 2 hole pistons 50 wt oil
Mounted Middle hole of shock tower / outer hole on A arm
Back Shocks: TRF w/AE 19.5 lb gold springs 2 hole pistons 40 wt oil
Mounted 2nd From Top on shock tower / inner hole on A arm
Large front stabilizer - preloaded 2 mm
Soft rear stabilizer
1 mm front droop
2 mm rear droop
4.5 mm ride height
Camber links: Exact middle on inner mount (front & rear) and outer on rear hub. 2.5mm spacer under the front inner mount. 1mm spacer under rear hub ball connector.
Battery compartment dremeled so Trakpower 4900 lipos lay flat on the bottom + 28 mg of weight added to battery side of chasis
Jaco Green (spec) tire on medium grip carpet. Death grip tx compound.
13.5 brushless with 64 p 46T pinion and 96T spur.
This set up will probably only work with a one way. I'm considering adding .5 mm of front kick up and/or soft back springs because the car turns in hard. Most people who test drive my car hit pipes on entry.
Ed237 is offline
Old 11-15-2008, 09:52 AM
  #9922
In my opinion you will be all over the place chasing a set up that you didn't derive for your track.
The stock set up will get you within the ballpark but you will need to get the right tires for your track, that is about 80% or more of the set up. Next is to stiffen the suspension, I prefer the white springs in front and 50wt with blue in back and 40wt. That combo seems to work well with a 13.5 motor. Camber is -1 all around and I use CS27 tires or Sorex 28. No rear stabilizers.
Good luck and have fun.
AreCee is offline
Old 11-15-2008, 04:49 PM
  #9923
TwoTone's Avatar
Yea I know, it's been about 10 years and I'm building a car for my 6 year old also, so I was trying to get a starting point. I wasn't sure how good it ran out of the box.
Thanks for all the replies, gives me some ideas to start with.
TwoTone is offline
Old 11-17-2008, 07:07 AM
  #9924
TwoTone's Avatar
I stopped by the local track and one of the guys into Tamiyas said the out of the box set up would be good starting point.
I forgot to ask him, anyone know what the stock shock oil weight is. I looked through the manual and don't see the actual weight referenced anywhere.
Also, what that Tamiya oil weight equals in some other brands.
TwoTone is offline
Old 11-17-2008, 08:18 AM
  #9925
mok
mok's Avatar
i dont think its 100% perfect..
tamiya 200 - 20wt
tamiya 400 - 40wt
tamiya 600 - 60wt
its a rough guide and something that i've only seen talked about.
mok is offline
Old 11-17-2008, 08:19 AM
  #9926
Start with 30wt in the rear and 40 up front.
AreCee is offline
Old 11-17-2008, 08:33 AM
  #9927
Trader Rating: 37 (100%+)
Hey guys...
I've got a new IFSr, have raced twice now...great car! Really loving it.
Anyone know what size turnbuckle wrench is necessary for the stock blue aluminum turnbuckles? Getting tired of using the kit wrench and marring up the nice blue color! I think it's 4mm, but want to make sure before spending $ on a nice new wrench. Thanks!
jubilee is offline
Old 11-17-2008, 08:50 AM
  #9928
Originally Posted by jubilee View Post
Hey guys...
try this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXETK9
redbones is offline
Old 11-17-2008, 09:11 AM
  #9929
Originally Posted by redbones View Post
Gracias.
jubilee is offline
Old 11-19-2008, 06:52 AM
  #9930
badboy's Avatar
Trader Rating: 14 (100%+)
Default 13.5 BL Gearing
What gearing do you recommend for a 13.5BL motor (medium asphalt track)?
Thanks.
badboy is offline
