Like Tree2Likes
Old 11-06-2008, 11:10 PM   #9871
Skitee's Avatar
Generally the spool will lose you off power steering on corner entry, especially if you're changing from a diff or one-way. i managed to get most of it back with a few setup changes though.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 11-06-2008, 11:31 PM   #9872
Please go on, I'm here to learn.
stocker is offline   Reply With Quote
Old 11-06-2008, 11:55 PM   #9873
Skitee's Avatar
Went to a softer front spring and laid the front shocks down to the 2nd hole from last, added around a half degree of additional toe out in front but be careful with this it can make the car feel quite twitchy. Also added 1mm of rear droop to get more weight transfer to the front when coming off power.
Old 11-07-2008, 12:28 AM   #9874
Which hole do you guys attach the camber links? And the spacers? No one seems to tweak the roll centre and camber gain much?
Old 11-07-2008, 03:07 AM   #9875
joe of loath's Avatar
thats because it's enough ofa headache to tweak for the guys designing the car, let alone those racing it
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-08-2008, 07:40 PM   #9876
DJ
Default Suspension Arms
Hi just want to ask about the above mentioned part of TA-05R
In my manual the part # is 51104
But the only part available in our LHS is design for TA-05ifs with part # 51297
Can i used the ifs part for my TA-05r? (w/o modification)
Need advices also for my Orion 10.5 motor, what are the good Gear and Pinion combination for the said motor?
Thanks alot.
DJ is offline   Reply With Quote
Old 11-09-2008, 01:29 AM   #9877
Drifting101's Avatar
They are the same thing except the ifs one are just plastic not a plasic carbon mix
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-09-2008, 05:51 AM   #9878
Mamba Max 7700Kv, Losi Xcelorin 3.5T or a Novak GTB 3.5T, which is better to put in a TA05 with aluminium outdrives?
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
Old 11-09-2008, 08:46 AM   #9879
racing or bashing?
Old 11-09-2008, 12:41 PM   #9880
spring71's Avatar
Default novak 5800 sintered fdr
I bought novak 5800 BL motor for my ta05R
Is anyone running ta05R with novak 5800 ?
Could you guys recommend FDR for 5800 ?
I have 64P 108 spur gear.
spring71 is offline   Reply With Quote
Old 11-09-2008, 02:20 PM   #9881
hobbipro's Avatar
Trader Rating: 21 (100%+)
The Mamba Max wont fit behind the motor, The GTB is a tight squeeze (I have this in my IFS-R), Not sure on the losi footprint. Why not a Tekin RS pro system? I bought 3 of these for other projects and wont buy another esc Mfg unless its the size of the Tekin.
hobbipro is offline   Reply With Quote
Old 11-09-2008, 06:50 PM   #9882
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
For those that are interested..
Using 6mm of spacers under the battery bar posts and the battery hold down piece from the TA05MS (completely flat, no shaped cell pieces on one side like the standard TA05 part) and you can fit tall lipo packs with large capacities like the LRP 5300 and TrakPower 4900/5400s etc.
Its a perfect fit once the above is done, required no dremelling of the slots to take out the shaped pices for NiMH cells.
-Mark
mok is offline   Reply With Quote
Old 11-09-2008, 07:47 PM   #9883
Guys/gals,
Tamiya only has the wide pitch pulley for diff and one-way, not for spool. does it make a significant difference for spool?
Old 11-09-2008, 08:54 PM   #9884
RCGaryK's Avatar
Guys/gals,
I am 99% sure I have the diff one on my spool.
I ran a Losi ESC in my 05 today. Same basic footprint as the GTB.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-09-2008, 09:37 PM   #9885
mok
mok's Avatar
Guys/gals,
the spool and one-way use the same pulley.. the wide pitch one way pulley will most certainly fit the spool (have one in my hand right now).
-Mark
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
