Like Tree2Likes
Old 10-29-2008, 01:04 PM   #9841
Adam?'s Avatar
After my first run, I went to pick up the car, and a lightning bolt shot out of it. I knew there was some talk about static, but JFC!
Also, my Futaba 9550 was not at all happy about the static. It made for a pretty spectacular crash. I'm surprised the car didn't burst into flames afterwards. Since spending $50 on a carbon chassis violates the spirit of this budget car, I guess I need to look into the janky ground wire solution.
Adam? is offline   Reply With Quote
Old 10-29-2008, 01:10 PM   #9842
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I've heard of that several times with the R versions....but I haven't, nor has Greg ever had any issues with all the variations we've run. I know some ran a jumper wire from the spur cover to the chassis I believe to solve the problem.
And BTW the carbon chassis is really cheap so....
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-29-2008, 01:18 PM   #9843
Adam?'s Avatar
Yeah, I was hopeful the static wouldn't affect me, but there's no question it did. The 9550 sounded like it wanted to explode, locked hard right. Power cycling the car fixed it, though. I wonder if a BL Futaba servo would handle it better?
I only put about 5 packs through the car, but it didn't feel nearly as crisp as the 416. It got better with each run as I made tweaks, though, so I'm sure I can get it there with time. I'm actually tempted to make it a Trans-Am car, there seems to be a LOT of interest in that class around here.
They should call it the TA05 "Arc Flash" Edition. :-D
Old 10-29-2008, 01:20 PM   #9844
We found the manual setup to be nowhere close. Which is funny because all the previous versions worked great with the kit setup. I need to put together my latest setup sheet as the car now is 99% there....very easy to drive, even with a lot of HP! A couple of the big things are the front track rods need to be quite a bit shorter than the manual says, and the car,I foundthe car likes to be softer up front than out rear.
Old 10-29-2008, 01:35 PM   #9845
Adam?'s Avatar
Cool, send it my way. I already shortened the front camber links, raised them all around, went to stiffer springs front and rear (white/yellow) and thicker oil. Each change helped, but there's definitely more there.
Old 10-29-2008, 05:43 PM   #9846
spring71's Avatar
Default NOVAK 4.5R for TA05-R
Is there anyone who has TA05-R with 4.5T BL motor ?
Could you guys recommend the spur, pinion and FDR for TA05R with NOVAK 4.5R ?
108T spur, 25T pinion, FDR 9.72 will be fine ?
spring71 is offline   Reply With Quote
Old 10-29-2008, 06:16 PM   #9847
Depends on the track. You can use any FDR higher than a 7. An average 100'x40' technical track may use an 8 or a 9. Go to the track and see what the others are doing. I used a 96T spur and any pinion from 26 to 30 on an asphalt parking lot track measuring about 120'x50' and depending on how technical it was.
AreCee is offline   Reply With Quote
Old 10-29-2008, 06:30 PM   #9848
the carbon chassis is this one?
http://www.tamiyausa.com/product/ite...oduct-id=53893
stocker is offline   Reply With Quote
Old 11-03-2008, 12:58 PM   #9849
spring71's Avatar
Default Novak EX 13.5 Motor FDR
Is anyone running Novak EX 13.5 motor on TA05R ?
Which FDR should I run with that motor ?
Can I run EX 13.5 motor on Stock class race ?
The spec says it's similar to stock 27turn motor.
Old 11-03-2008, 03:39 PM   #9850
Kregger's Avatar
The 13.5 EX is a little faster than a 27T. The gearing is'nt that far off from stock motor gearing, go up a couple of teeth and temp it as you run it.
Of course this is for the EX with the bonded rotor (out of the box). If it's been upgraded with the sintered rotor kit, now your in the neighbord of a 19 turn and your gearing is radically different.
Kregger is offline   Reply With Quote
Old 11-03-2008, 03:47 PM   #9851
Drifting101's Avatar
A 4.5 for a 13.5 were i race........how is a 13.5 like a 19 turn......we race 8.5s in 19t
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 11-03-2008, 03:50 PM   #9852
reenmachine's Avatar
Trader Rating: 26 (100%+)
13.5 and 19T are run together all over the place...
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-03-2008, 05:59 PM   #9853
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Depending on your track, I'd be running an FDR of between 5 and 7. At our local track which has a 24m straight and 80m total length, very technical layout, you might run 6:1 FDR.
5 = possibly unsafe, hot motor etc
6 = nice gearing for 13.5 on short technical track
7 = safe, better accelleration, possibly could go faster
-Mark
mok is offline   Reply With Quote
Old 11-03-2008, 06:04 PM   #9854
That looks higher than what Novak recommends on their web site, a 4.5FDR with their 13.5.
Old 11-03-2008, 06:09 PM   #9855
-Mark
Everyone out here runs an FDR of 4.5-4.7 with a 13.5. That's what most manufacturers recommend as well.
Pete Waydo
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
