Like Tree2Likes
Old 10-19-2008, 01:11 AM   #9781
The gap between chassis slot and batter is where I add lead weights. I don't even use the strap, I use the battery tape.
DirtyRacer is offline   Reply With Quote
Old 10-19-2008, 02:22 AM   #9782
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
hey guys, just being curious here..... anyone know if 415msx rear diff outdrives fit ta05?
Valentin.H is offline   Reply With Quote
Old 10-19-2008, 03:43 AM   #9783
I just got a Mazda speed6 for my TA05. The wing has a couple of lines to give a few variations of the final shape. Any advice on which lines I should cut?
stocker is offline   Reply With Quote
Old 10-19-2008, 05:03 AM   #9784
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
They are trim lines for different sets of body rules.
If you follow IFMAR/ROAR and the GBS then the smaller of the 2 sizes is permitted as the larger wing size falls outside of 40mmx20mm as per the GBS etc.
-Mark
mok is offline   Reply With Quote
Old 10-19-2008, 06:01 AM   #9785
My track doesn't seem to have any ruling on this...
What should I look out for to determine if I should cut it down or mount it forward as there are 2 possible positions from the indents on the wing.
If I'm having too much rear grip, understeering, do I move the wing forward or cut the wing? Now I have the largest possible size and the rearward mounting position.
Thanks!
Old 10-19-2008, 06:03 AM   #9786
DJ
Default ta-05 belt
hi need advise regarding the belt.
In installing the belt, should I loosen ot tighten a bit, which is recomended thanks
DJ is offline   Reply With Quote
Old 10-19-2008, 11:43 AM   #9787
macnkitty2002's Avatar
I never thought of that, that's a great idea. It's the most centralized and lowest part of the car pretty much.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-21-2008, 01:50 PM   #9788
Originally Posted by RC Guru View Post
hey guys, just being curious here..... anyone know if 415msx rear diff outdrives..possibly even the diff fit ta05?
no one?
Old 10-21-2008, 05:04 PM   #9789
94eg!'s Avatar
Trader Rating: 17 (100%+)
no one?
They certainly don't fit. The TA05 has a much narrower bulkhead, and therefore has much shorter outdrives. This is the reason why the MSX uses 46mm drive-shafts when using the same suspension (ta05R uses 48mm)...
94eg! is offline   Reply With Quote
Old 10-21-2008, 07:48 PM   #9790
thanks!
Old 10-21-2008, 09:25 PM   #9791
TwoTone's Avatar
Originally Posted by guinnes.s View Post
i always had problem in find 05 bearing because of the unusual size so i did a 416 conversion that uses common clutch bells end are much better. You shoud do the same.
Originally Posted by TwoTone View Post
Can you describe the conversion and the parts need?
I just picked up 2 TA05s for my son and I, so I'm still learning about the car.
Can anyone tell me what the 416 conversion is on a TA05?
TwoTone is offline   Reply With Quote
Old 10-21-2008, 09:34 PM   #9792
DRAG_ON's Avatar
no it does not fit
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 10-21-2008, 09:38 PM   #9793
mok
mok's Avatar
416 conversion? Never heard of this before...
Doest make sense either, given there's basically nothing in common between the TA05 and the TRF416 chassis.
A conversion in my eyes would be silly.. might as well just buy a 416!
Old 10-21-2008, 10:41 PM   #9794
I think it's just the hubs... to use the bigger bearings?
Old 10-21-2008, 11:03 PM   #9795
94eg!'s Avatar
Hey guys check this out:
It's Penguin's new prototype hop-up chassis for those who already have the Penguin P2020 chassis kit on their TA05. It's meant to hold Lipo packs with an adjustable sliding battery side holder and Velcro battery strap. It's also being sold as a complete chassis kit for those who don't already have the P2020 chassis kit...
The chassis plate is also 20mm narrower than the standard P2020 chassis plate which makes it about the same width as the latest crop of TRF cars. This really helps prevent the chassis from bottoming out in turns...
Penguin tells me they only made 12 sets of parts, and 5 are already spoken for. This means there are 7 left. If anybody is interested you can purchase them at the link below, or send them an e-mail. I am told that any orders placed after stock runs out will be refunded in full...
http://www.penguinrc.com/products/tamiya/p2020L.html
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
