Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 10-15-2008, 06:13 AM
  #9766
DJ
Default Bearing
Hi guys, have you ever tried to buy Yeah bearing for TA05. I've seen in rcmart 24pcs a pack. But it didnt indicates the sizes. Is it usefull? coz if it is I want to purchase and change my bearings.
Thank you for the feedback
DJ is offline
Old 10-15-2008, 05:35 PM
  #9767
DJ
Follow up question, what are the sizes of bearing used in TA05, and where can i buy it.
yhanks again.
DJ is offline
Old 10-15-2008, 05:37 PM
  #9768
Doesn't the TA05 already come with full ball bearings? ???
stocker is offline
Old 10-15-2008, 05:38 PM
  #9769
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
YUP, and Tamiya bearings are nice
minicooper is offline
Old 10-15-2008, 06:07 PM
  #9770
Trader Rating: 117 (100%+)
hey guys, just thought i'd let you guys know since some of you might be interested in some extra parts for your ta05!
http://www.rctech.net/forum/r-c-item...rade-16-2.html
thanks guys! its helping me fund my ta05
Valentin.H is offline
Old 10-16-2008, 01:54 AM
  #9771
DJ
yup i know that tamiya bearings are all good, but subjected to be busted (especially the two bearings in the wheel) and you need to find replacement.
Back to my question, any body knows the sizes of bearings design for TA05?
(also ball bearings for ball diff )
DJ is offline
Old 10-16-2008, 03:48 AM
  #9772
mok
mok's Avatar
mok is offline
Old 10-16-2008, 03:55 AM
  #9773
guinnes.s's Avatar
i always had problem in find 05 bearing because of the unusual size so i did a 416 conversion that uses common clutch bells end are much better. You shoud do the same.
guinnes.s is offline
Old 10-16-2008, 04:09 AM
  #9774
mok
mok's Avatar
The lightweight suspension set and universals throughout are the best upgrades IMHO if you're looking for compatability across the Tamiya range
mok is offline
Old 10-16-2008, 06:03 AM
  #9775
TwoTone's Avatar
Can you describe the conversion and the parts need?
I just picked up 2 TA05s for my son and I, so I'm still learning about the car.
TwoTone is offline
Old 10-17-2008, 10:22 PM
  #9776
I was tired of goofing around with lesser batteries and finally went with a higher end lipo battery and now it doesn't fit in my standard bucket TA05. Its a SMC Lipo 5000. How do you make them fit? Or do you just let them "ride high"? If you let them ride high what sort of battery holder should I get? OR did I just waste by $129 and need to flip it for a smaller battery?
rknott is offline
Old 10-17-2008, 11:22 PM
  #9777
You could probably sand down the battery slots on the chassis or go with packs that are closer in size to stick packs (ie yeah racing 3200s or Orion 3200/3800s).
itchynads is offline
Old 10-18-2008, 05:21 AM
  #9778
mok
mok's Avatar
I personally wouldnt bother with sanding the slots at all and let the pack "ride high" as you put it. The lipo weighs less than a NiMH pack so its not likely to affect centre of gravity even when sitting higher. THe TA05 has a nicely protected area for the battery so I wouldnt let that concern you either.
That being said, chances are the larger than 3800 capacity packs will be taller so other brands may also suffer this issue. Incidentally, the Intellect IP3800 fits nicely in my TA05 but its one of the shorter packs.
-Mark
mok is offline
Old 10-18-2008, 05:24 AM
  #9779
mok
mok's Avatar
You might also like to fit spacers between the battery posts and the chassis which will raise the pin holes for the battery holder and allow taller packs to fit in. I'd do this if the packs were causing undue stress on the battery holder.
mok is offline
Old 10-18-2008, 07:30 AM
  #9780
macnkitty2002's Avatar
dont bother to sand anything. I use an Orion Platinum 4800 and it only sits about 5mm higher than my regular 6-cell Ni-Mh pack. Just flip the battery strap over to the smooth side, raise your battery posts to compensate for the increased height, and you're ready to go. as stated before, the increased center of gravity will be canceled out by the fact that you just shaved off 200+g of weight.
macnkitty2002 is offline
