Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 10-04-2008, 04:45 AM
  #9736
Herc Driver's Avatar
Hey guys ca i get some pinion/spur starting points for the following:
13.5
21.5
Silver can
I just switched from a TA04 and need to know the range to stock up/start with
I appreciate it!
Also has anyone tried the alumionum diff housings? Thoughts?
BTW I still have an unused 3 racing chassis if anyone is interested
Paul
Herc Driver is offline
Old 10-04-2008, 04:59 PM
  #9737
I've searched and scrolled through the last 25 pages of this thread. My eyes are about to explode...
Can someone please tell me if there's a "best way" to install at GTB into the regular plastic chassis? Pics would be even more helpful.
Thankyouthankyouthankyou.
stitchy is offline
Old 10-04-2008, 06:22 PM
  #9738
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Behind the motor, I fit an LRP Sphere in there fine.
nexxus is offline
Old 10-04-2008, 06:24 PM
  #9739
nexxus's Avatar
13.5
21.5
Silver can
I appreciate it!
Paul
You won't find stock pinions to gear up enough on these except a Silver can where I'd use a 25
As for the Alloy Diff Housings, pointless bling and excess weight IMO
nexxus is offline
Old 10-04-2008, 07:13 PM
  #9740
A GTB will barely fit but does if you file the corner of the output board to clear the screw bump along the backbone of the chassis. It will fit in there because I used it for the TCS, however, I got rid of it for a Tekin RS Pro which fits in easily including its tiny cap. (Never was a big fan of the orange junk.)
Just play with it and you'll see that it will work but the Tekin or LRP is so much better.
I should have mentioned that you want to place the GTB so the power wire cb is facing the motor.
AreCee is offline
Old 10-04-2008, 07:16 PM
  #9741
They may be bling but they make belt adjustments easier.
We are using FDRs around 4.5 to 5 for silver can, 4.5 for 13.5 and 4.2 for 17.5.
AreCee is offline
Old 10-04-2008, 07:21 PM
  #9742
nexxus's Avatar
How? You still have to take off the top bulkhead and adjust the spacers don't you?
nexxus is offline
Old 10-05-2008, 02:05 AM
  #9743
Drifting101's Avatar
I run 4.05 on my silver can
The alloy bulks only have the top, the bottom and the ring that goes around the bearing
Drifting101 is offline
Old 10-05-2008, 06:04 AM
  #9744
The index pin is pressed into the lower bulkhead eliminating the eccentric cam holder. One less part to manuver makes it easier in my play book. (actually that is two less parts, one on each side.)
AreCee is offline
Old 10-05-2008, 07:10 AM
  #9745
DJ
where to use "Aluminum Suspension Mount Spacer #53933 & 53932"?. I read my TA05 manual but cant find it. Im just curios about these parts
DJ is offline
Old 10-05-2008, 08:17 AM
  #9746
Under the suspension blocks holding the lower arms (between the blocks and the chassis). This can change the roll center, anti-squat and anti-dive characteristics.
stocker is offline
Old 10-05-2008, 08:33 AM
  #9747
DJ
Can someone enlighten me about this "roll center, anti-squat and anti-dive characteristics"?
If I add "Suspension Mount Spacer" in the back alone what will be the effect?
If I add "Suspension Mount Spacer" in the front alone what will be the effect?
When or what tracks do we need to put spacer in suspension block?
thanks
DJ is offline
Old 10-05-2008, 08:49 AM
  #9748
this can help you understand...
stocker is offline
Old 10-05-2008, 05:19 PM
  #9749
LOSI123's Avatar
Trader Rating: 63 (100%+)
I know this is the TA-05 thread, but i could not find a TB-02 thread & i thought maybe some one hear might know.
1. Will a TB-02 fit standard 48 pitch spur gears?
2. What is the lowest posible Final Drive Ratio for the TB-02?
3. Is the motor mount limited to holes or is it sloted?
thanks
LOSI123 is offline
Old 10-05-2008, 05:26 PM
  #9750
reenmachine's Avatar
Trader Rating: 26 (100%+)
thanks
Here you go...the huge TB-02 thread:
http://www.rctech.net/forum/electric...a-tb-02-a.html
However,
1. Yes, the "hockey puck" that comes with the kit fits in the stock spur gear's place and adapts to standard 48p or 64p spur gears.
2. Given the above, pretty low.
3. Holes with 4 positions. 3racing motor mount is slotted, and other aftermarket ones may be too.
reenmachine is offline
