Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 09-09-2008, 06:01 AM
  #9646
joe of loath's Avatar
Originally Posted by tc3team View Post
No problem
Dont forget the standard spur and pinion gears are tamiyas own pitch, ideally you need a 48dp spur and a selection of pinions for it unless you intend to keep using tamiyas pitch... (they wear quickly so ive heard).
I use a 48dp 72t spur. So on that basis,
72/27 would give you 6.0
72/26 would give you 6.23
72/25 would give you 6.48
72/24 ditto 6.75
72/23 ditto 7.04
Just gives you something to think about
Ps, bin the kit tyres and get some proper tyres on. Premounted Sorex 24/28 are a good starting point usually. As you get up to speed, you might find the 2 degrees rear toe might not be enough to get the car through the corners quick enough with a 27t motor.
I run 3 degrees and it just helps the car a little more.
Keep the diffs at the correct tightness, with just amount of grease and they will last for ages
yeah, I'll upgrade the spur/pinion when I have some money... I also made a gear calculator in excel, so I use that. makes it all a lot easier.
I've got my Vtec 27's on there atm. very sticky the kit tyres are staying in the box as spare, and I'm keeping the wheels.
and the diffs? oops, I forgot the spring in the rear one and broke the little plastic bit the locknut goes into.... which means it won't come apart. I might superglue it and use it as a spool
joe of loath is offline
Old 09-10-2008, 05:21 AM
  #9647
Drifting101's Avatar
Originally Posted by DA_cookie_monst View Post
I assume it is sitting off to the right by 6-8mm though?
Yes it is set off, the furthest bit is inline with the edge of the chassis
Drifting101 is offline
Old 09-10-2008, 05:30 AM
  #9648
cheers!!
DA_cookie_monst is offline
Old 09-12-2008, 02:47 PM
  #9649
tc3team's Avatar
A spur and pinion wont set you back more than five or 6 quid if you get the right combo, worth doing or you will probably fry your comm.
I would rebuild the diff you didnt put the spring in and keep an eye on the other, diff's can wear out very quickly if they are not built right.
all the best I may even have a few tamiya pinions kicking around if you're desperate for one.
tc3team is offline
Old 09-12-2008, 07:03 PM
  #9650
guys.. is there a difference with cars having the same FDR, but different IDRs?
Minami is offline
Old 09-12-2008, 07:07 PM
  #9651
DRAG_ON's Avatar
Tekin RS or RS Pro, really small footprint and no fan.
Novak GTB will just fit in at the back of your Ta05R, I run 13.5 BL motor with Novak GTB it fit without any problems
DRAG_ON is offline
Old 09-13-2008, 12:23 PM
  #9652
I can't be bothered for the moment tbh, and anyway, I'm starting racaing offroad tomorrow (yes, I saw the dark side and they offered cookies).
I'll order a set of pinions when I get the rest of the parts for my home made TC i'm building.
oh, I can't rebuild the diff, the screw just spins with the nut attatched to the other end...
superglue methinks
Old 09-14-2008, 04:24 AM
  #9653
jeda's Avatar
Even in our track, these are the two choices brand of racer that using brushless. i've read a lot of positive feedback for Tekin, and many loyal user for Novak GTB.
jeda is offline
Old 09-14-2008, 03:53 PM
  #9654
reenmachine's Avatar
Trader Rating: 26 (100%+)
Hi all-
Finally biting the bullet and upgrading from my plastic shocks as they're about worn out and I'd like more adjustment.
Are these...
42102 Tamiya TRF Series Special Hard Black Coating Damper set (4) (limited Team Edition)
...the best ones to get? What springs and oil would be a good starting setup for rubber on a medium asphalt track running 13.5BL? Short springs or regular?
reenmachine is offline
Old 09-14-2008, 05:08 PM
  #9655
kavadni's Avatar
Originally Posted by reenmachine View Post
Hi all-
Are these...
42102 are the ones to get, they come with a set of yellow springs, 60 wt oil is a good start.
Get 2 sets of 53440 Springs
Kevin
kavadni is offline
Old 09-14-2008, 06:51 PM
  #9656
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Funny that noone mentioned the LRP Sphere TC for the TA-05, where I race 90% of those on brushless have the Sphere TC and it fits fine in the TA-05. I chose it as it was easier to wire up for brushed than the GTB, and I didn't like the idea of having to solder to the esc as I would have on the Tekin (That was a deal breaker for me!).
nexxus is offline
Old 09-14-2008, 10:07 PM
  #9657
little man's Avatar
im using the ezrun brushless it is quick but sensorless and tuneable .
same as speed passions and venom units and fit with pleanty of room to spare have a look at one .my motor is the 10.5 (19 super stock) on lipohobbywing.com
little man is offline
Old 09-16-2008, 09:33 AM
  #9658
I like the handling of the Protoform Mazda speed 6 body on my 05, anyone knows which Tamiya body comes close to it?
thanks and cheers!
stocker is offline
Old 09-16-2008, 09:50 AM
  #9659
94eg!'s Avatar
Trader Rating: 17 (100%+)
My guess would be the Legacy B4 is the only thing that comes close. That is why it's outlawed at every TCS event. They don't want everybody running the same body...
There is 3 versions, two regular and one lightweight. I think the one labeled version-2 just includes window masks, but who knows...
94eg! is offline
Old 09-16-2008, 02:28 PM
  #9660
Yeah, I used to run the Protoform Mazdaspeed 6 as well, and just changed to the Tamiya B4 Legacy...
Man, the Legacy body is FAST!!! I love it!
- Paulie
pgeldz is offline
