Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 09-02-2008, 06:08 AM
  #9616
joe of loath's Avatar
hey, guess what's coming for me in the post
http://www.rcmart.com/catalog/rc-tam...cPath=420_1167
joe of loath is offline
Old 09-02-2008, 12:05 PM
  #9617
loriding69's Avatar
Trader Rating: 25 (100%+)
You may want to order a pair of TRF shocks, CF steering link, CVD's for the front, and a spring kit. Just thought i would throw that out there.
loriding69 is offline
Old 09-02-2008, 01:34 PM
  #9618
I haven't got any more money left lol.
Old 09-02-2008, 01:47 PM
  #9619
reenmachine's Avatar
Trader Rating: 26 (100%+)
Don't worry about it. The TA-05 is great right out of the box up through mid-level club racing. All I've done to mine is add a front spool and the front CVDs and it's going strong in 13.5 sportsman class. I can certainly see the benefit of the TRF shocks though and they're next on my list. The stock plastic shocks are getting worn out and leaky and I'd like to have threaded collars. They've done their job up to this point though!
reenmachine is offline
Old 09-02-2008, 02:01 PM
  #9620
The Bear's Avatar
I am very loosly thinking about trying the tamiya carpet car. I'm somewhat concerned with the mid-motor mount and the overall design being intended for rubber tire.
I'll be running 13.5 foam carpet on moderate to large tracks with medium to high bite.
wondering which setup sheets I should be reviewing and also wondering how much the car relies upon 'one off' techniques like shimed bulkheads or some other little nifty trick the drivers have come up with. Any 2.5 toe left, 2.1 toe right to offset mid motor or something equally as mystifying to me?
thanks for any responses
The Bear is offline
Old 09-05-2008, 01:58 AM
  #9621
somehow I think my driving is more of a problem than the car.
I was racing an E10 before though...
this car is good! i can tell that from driving round my living room (damn 2 inches of rain in 24 hours means I can't test it outside).
what ratio am I looking at for a 27t motor on a very large outdoor track?
Old 09-05-2008, 02:50 AM
  #9622
habis's Avatar
and i would reccomedi exchanging the outdrives to the reinforced version
habis is offline
Old 09-05-2008, 04:12 AM
  #9623
Is the CF steering link significantly better than the stock one?
stocker is offline
Old 09-05-2008, 04:49 AM
  #9624
It's stiffer. Will you be able to tell the difference, it's up to the level you drive at but generally, no. Get the bearings for the steering it helps smooth things out and increases the longevity. The CF link will not eliminate any slop, that comes from the ball cups.
AreCee is offline
Old 09-05-2008, 05:52 AM
  #9625
tc3team's Avatar
6.75 is a good ratio for a medium sized carpet track for a monster stock, so if you can keep the corner speed up, anywhere between 6.75 and 6.4 would be about right.
It all depends on how much speed you can carry through the corner- if you cant and the motor has to pull a large pinion to get back up to its top speed, combined with throttle jamming, it will cook the commutator and brushes very quickly...
Your best bet is to ask the A main what the run, then run a 1 to 2 teeth less to start with. if its too slow on the straight then add a tooth or two to the pinion size
hth
tc3team is offline
Old 09-05-2008, 06:35 AM
  #9626
mok
mok's Avatar
personally i never saw the point in the carbon steering link..
you're much better off with the alu. steering set w/ bearings, for its smooth running goodness
sure you could get the carbon link for the bling value, but its kind of pointless as its pretty much all hidden under the front stiffener plate!
-Mark
mok is offline
Old 09-05-2008, 06:39 AM
  #9627
mok
mok's Avatar
i wouldnt bother with setup sheets other than you're own..
you're best bet is to start off with the setup found in the manual and work from there to suit both you're own personal driving preferences and the track you run on
mok is offline
Old 09-05-2008, 06:43 AM
  #9628
-Mark
In other words, there is insignificant performance improvement from it?
stocker is offline
Old 09-05-2008, 06:44 AM
  #9629
mok
mok's Avatar
agreed! ...i've needed to change to the alu. outdrives on the diffs as i put more power through my car.. i actually melted the stock plastic and high precision diff joints when i put a 3.5T brushless into it :P
from my experience, i would say the plastic outdrives are only really good for 540/novice and stock classes, but when you move to super stock or modified you need the strength the alu. outdrives provided.
-Mark
mok is offline
  #9630
RC MARKET's Avatar
new option kit
RC MARKET is offline
