Like Tree2Likes
Old 08-21-2008, 09:41 AM   #9571
loriding69's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to loriding69
ouch my head hurts now from all the informaion..........
will keep this info in mind in case i start running foam, thanks
Double E
If your not here to have fun, then stay at home!!!
Breast Cancer Awareness is my race for the cure!
loriding69 is offline   Reply With Quote
Old 08-21-2008, 05:32 PM   #9572
kavadni's Avatar
Originally Posted by nexxus View Post
Hey all am looking at a racing return, have a TA05 IFSR is it worth going the IFS suspension or should I convert back (ie shock tower and mount) to the TA05 set up which I am more used to.
Also can I fit a Mamba Max ESC in here? I have a Futaba 9551 servo (low profile) and enough room to fit my receiver behind the motor (Spektrum SRM3100)
Nexxus,
I don't have IFS. I believe it's purpose is to allow use of low bodies. I imagine there are more parts to break.
If your going to race brushless, take note until the end of the year. PRECC only allows 13.5 in brushless (anything in mod).
Next year should be as per AARCMCC (to be confirmed so don't quote me) with 17.5BL and 27T Brushed in Stock and a Super Stock 10.5BL and 19T Brushed. AARCMCC have a list of approved motors on their site.
Kevin
Kevin
kavadni is offline   Reply With Quote
Old 08-21-2008, 10:29 PM   #9573
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
Originally Posted by RC Guru View Post
hey guys,
i have the light weight/reversible suspension upgrade, and well, i bought some aluminum rear hubs and front knuckles from 3racing, and discovered that not only the knuckle wont fit into the lightweight front chub, but also that the driveshaft axle doesnt come out all the way so i can put in the axle pin...anyone run the 3racing rear hubs and front knuckles? i think the upgrade universal axle part for the stock ta05 is part number TAM53499. can anyone confirm this? thanks guys.
no one?
Valentin.H is offline   Reply With Quote
Old 08-21-2008, 11:51 PM   #9574
reenmachine's Avatar
Trader Rating: 26 (100%+)
I thought you might like to see how beautifully the Tekin RS ESC fits in the TA05. I wanted to mount it 90 clockwise from where it is now so the cap would fit nicely into that nook near the motor, but the sensor cable that came with the SpeedPassion 13.5 is really short. Still loads of extra room though. This little ESC can handle 5.5BL or any brushed.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 08-22-2008, 12:22 AM   #9575
It looks good!!
stocker is offline   Reply With Quote
Old 08-22-2008, 06:24 AM   #9576
Here's a view of my set up. I'm using two Capacitors for mod motors. Can you see the second?
It's there under the battery power leads inside the chassis tub. Got to love the small sizes of Tekin products. Small ESC and small caps.
AreCee is offline   Reply With Quote
Old 08-22-2008, 08:00 AM   #9577
What's that on top of your servo? That's quite a small receiver you got!
Old 08-22-2008, 08:10 AM   #9578
That is an AlleyCat/iLap transponder. The receiver is between the servo and motor, it is a Spektrum micro Rx.
Old 08-22-2008, 09:08 AM   #9579
How about posting some setup sheets?
Old 08-22-2008, 01:40 PM   #9580
Here is the problem with set up sheets: There are five of us using TA05s at our parking lot track which is different each week. All five of us are usually within a lap of each other but we all have different set ups which we find during practice. Which one would you like?
It is best to start with a baseline set-up (the one the manual suggests is always a good starting point) and then note the changes you make and what effect it has. Set up sheets make rough toilet paper.
I'll give you my latest but it will change next Sunday.
Front:
50wt oil
White springs
2nd hole in on CF tower
Spool
4 C-hub
-1 camber
RP36 premount tire sauced with Paragon FXII
outside hole on arm
-5mm droop
no rollcenter washers
zero toe in
Rear:
40wt oil
Yellow springs
3rd hole in CF tower
outer arm hole
stock hub carrier
1D block (3* toe-in)
no roll center washers
-1 camber
-3 droop
diff
General:
5mm ride
no sway bars
Tekin RS Pro
Novak SS 13.5 or LRP X-11 4.5
Trinity IP 3800 Lipo
Spektrum micro Rx
Futaba 3PK Tx
JR Z590m servo
Protoform Mazda Speed Six
Old 08-23-2008, 08:51 AM   #9581
nexxus's Avatar
Trader Rating: 302 (100%+)
Does anyone know the largest 48 pitch spur I can fit in a TA05? I only had a 70 laying around and I can't mesh any pinion smaller than a 26 to it! Any help pls!
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 08-23-2008, 02:32 PM   #9582
loriding69's Avatar
Not sure if you was trying to mesh a 64p pinion. I have had a 72T/48p on mine with 30-34T pinions. check your spur and pinion to make sure they match up 48/48 or 64/64 not 48/64 or 64/48.
I'm running 36/69 48p.
Double E
Old 08-23-2008, 02:33 PM   #9583
loriding69's Avatar
Questions??
I do have 1 question. with the shock towers. When using the kit towers is there a difference when using the CF towers?
Double E
Old 08-23-2008, 10:59 PM   #9584
kavadni's Avatar
CF has very little flex, plastic flexes a lot. Any changes you make to shocks, springs and fluid are meaningful.
Kevin
Old 08-24-2008, 05:37 AM   #9585
More position choices and a wider body mount in the rear.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
