Like Tree2Likes
Old 06-28-2008, 09:49 PM   #9421
kavadni's Avatar
Originally Posted by Interceptor View Post
Hey, what can I do to help with alittle bit of push? Everything else is on rails, but it pushs in the turns. I have a spool up front.
Is the spool something that you run for a reason? I ask as a diff will push less, albeit turn more.
Kevin
kavadni is offline   Reply With Quote
Old 06-29-2008, 07:52 AM   #9422
Originally Posted by AreCee View Post
That's interesting because my TA05R uses the 36T pulley just like the diff that came in the kit and stated in the manual.
Did you get a 37T pulley with yours?
Originally Posted by stocker View Post
Yes, you guys corrected me. I am using the 37T that came with my IFSR. I would've thought that Tamiya would've given the 05R that also. But I guess it's just the IFSR that has the TRF416 pulleys and drive train ratio. Thanks for setting me straight.
R/C Rich is offline   Reply With Quote
Old 06-29-2008, 09:23 AM   #9423
Send a message via AIM to A-Ko
I would try more caster.
Kevin
With the torque from my 13.5BL I went with a spool for pavement.
It makes adjustability easier and I know the front will always have more pull than the rear.
I did lose both diffs from the front loosening up and the rear overpowering the front in my early 13.5 running.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 06-29-2008, 09:29 AM   #9424
The sorex 36 tires I got were hooking up great on the pavement, and did not show any signs of over heating or excessive wear. I currently have blueu springs on the front and yellow in the rear. Would sway bars help at all?
Funny thing is I used to know all this stuff years ago but haven't used the knowledge since 01.
H & E Motorsports team driver
Interceptor is offline   Reply With Quote
Old 06-29-2008, 12:01 PM   #9425
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
I am building my R and found that you can not use a standard futaba 3003 servo. what servo's fit?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 06-29-2008, 12:05 PM   #9426
It will fit, you just have to trim one side of the servo ear.
Old 06-29-2008, 12:17 PM   #9427
bigb11's Avatar
Thanks.
Old 06-29-2008, 12:31 PM   #9428
This is probably a dumb question, but where does this transponder holder go?
http://www.speedtechrc.com/store/ebp...id=459&id=5361
Old 06-29-2008, 06:08 PM   #9429
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
im pretty sure it replaces the outer servo mount and hangs over the side of the chassis.
Fast XXXS is offline   Reply With Quote
Old 06-29-2008, 10:05 PM   #9430
94eg!'s Avatar
Trader Rating: 17 (100%+)
Nope. It replaces the inside/upper servo mount and places the transponder directly above the servo...
94eg! is offline   Reply With Quote
Old 06-30-2008, 08:19 AM   #9431
Does anyone use 26mm wheels on their 05? Is it achieved by using the 6mm hubs and 1mm spacer to prevent rubbing on the insides? Or is it that we should use only 24mm?
stocker is offline   Reply With Quote
Old 06-30-2008, 08:31 AM   #9432
94eg!'s Avatar
I have 26mm wheels/tires that fit mine. The wheels are a +3 hpi wheel, so no need for spacers. Though I doubt a +0 would rub...
24mm is much better suited for this car though...
Old 06-30-2008, 10:56 AM   #9433
OK, understand.
I noticed something from my 05. The rear belt seems to be running to one side of the pulley. I am more concerned with part of the belt not on the centre pulley. See attached picture. What should I do?
Old 06-30-2008, 11:09 AM   #9434
CLK@racing's Avatar
I notice that there is something connecting the rear bulkhead to the motor mount in the pic above. Anyone knows what is it? And the purpose?
Real man races Modified.. simple.
CLK@racing is offline   Reply With Quote
Old 06-30-2008, 11:21 AM   #9435
Looks like a turnbuckle and ball cups
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
