Like Tree2Likes
Old 06-16-2008, 04:02 AM   #9331
tc3team's Avatar
Also, If you are using, or considering using foams indoors, use a stiffer spring.
Wider foams may require a 2mm shim on the wheel hex to make the inside of the wheel clear the top ball joint, which will in turn also increase the width to give a little more stability.
Avoid using tyres with a high "mechanical grip" such as minipins as the chances of grip roll will increase quite a lot with high power motors and cells.
hth
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-16-2008, 04:08 AM   #9332
tc3team's Avatar
duplicate
Old 06-16-2008, 06:19 AM   #9333
Default Suspension
Hi,
I have a TA05, just wanted to ask what suspension blocks are good to use in conjunction with OP-428 hubs TA04 hard rear upright (are these 1 degrees?)
Seems most setups now are 3 degrees toe in rear using suspension blocks and 0 degree in the hubs, just trying to come close to this setup in a TA05.
I think I have the short suspension arms.
Many thanks in advance.
joel
rccartips is offline   Reply With Quote
Old 06-16-2008, 06:50 AM   #9334
kavadni's Avatar
Originally Posted by rccartips View Post
Hi,
joel
Joel,
This might help you http://www.thard.co.uk/viewtopic.php?f=24&t=30
Kevin
kavadni is offline   Reply With Quote
Old 06-16-2008, 08:41 AM   #9335
94eg!'s Avatar
Trader Rating: 17 (100%+)
Each letter on the suspension blocks is a half a degree different from the next. 1B is one step wider than 1A.
BTW: The "X" series of blocks get narrower as the letters go along. 1X is the next step narrower than 1A...
This means that if you have 1B + 1XD, your getting 3* out of your blocks. If you have 1A + 1XD, your getting 2.5*. Don't forget to add or subtract these numbers from uprights as the TA05 does NOT use 0* uprights...
94eg! is offline   Reply With Quote
Old 06-16-2008, 09:00 AM   #9336
tc3team's Avatar
It is also worth noting that changing inboard (gearbox side of the wishbone) will give a different feeling than changing outboard (hub side of the wishbone) setting.
I use 1 degree inboard and 2 degree outboard rear toe, giving 3 degrees in total.
For me, combined with the right suspension,toe and spring/oil settings make the car turn in very sharply, as does using this combo with a spool....
Pulls the car out of corners well too
Old 06-16-2008, 10:39 AM   #9337
majicman's Avatar
Default 17.5 Gearing
Has anyone had experience in gearing a 17.5 in the TAO5? Getting to the starting 3.5 FDR looks like it may be tough with the higher internal ratio of the car.
My track has mandated the use of the 17.5 for stock to align itself with the upcoming 2009 ROAR rule changes.
If anyone has a spur/pinion combo that they run on their car 48p or 64p with the 17.5 they would care to share that would be fantastic.
Thanks for the help.
Majicman
SDRC RACEWAY - http://www.sdrcraceway.com/
majicman is offline   Reply With Quote
Old 06-16-2008, 11:06 AM   #9338
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I've run the 17.5 quite a bit and never actually made it down to the 3.5 Novak suggests. I usually ran a rollout off around 48-49mm...so with rubber tires...start around 98/54-55.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-16-2008, 12:28 PM   #9339
majicman's Avatar
What size of a track are you running on, and how much room for gearing up/down does that combo give you?
Majicman
Old 06-16-2008, 12:46 PM   #9340
That was for about 100 x 60...I could easily go to 56-57 tooth with the 98 spur. I used to use a 90t spur when I first started racing with brushless motors. I'm not sure of the exact maximum teeth (spur and pinion added together) but I think it's around 160 so. If your running on a large outdoor track..say 150 x 80, I'd go with maybe a 98/56-58 range. I'd gear it so that it doesn't get any hotter than maybe 150-155 outside. Indoors no hotter than 140.
Old 06-16-2008, 12:51 PM   #9341
majicman's Avatar
That is good to know thanks for the info.
Majicman
Old 06-16-2008, 03:38 PM   #9342
Default Suspension
Hi,
Thanks for the help, just a couple more...
1. Is there a 0 deg hub that can be used on the TA05 that is platic? Aluminum is too expensive.
2. What is the difference in length between standard arms and the long arms? Is it 1mm?
3. How about the lightweight reversible arms? Is it a long arm?
4. Is the TA04 hard rear hub 1 degrees instead of the standard 2deg?
Thanks again.
Joel
Old 06-16-2008, 04:17 PM   #9343
In the Standard 05 suspension there are only 1 and 2 degree rear hubs. But you can cancel the toe with the toe blocks.
As far as I know there are no different length arms for the standard suspenion. You can use the short arms designed for the TA04SS...but they are short as in wheelbase not car width.
There are varying lengths of arms for the lightweight suspension. I'm not sure exactly the difference but it's between 1-2mm per arm.
And yes, the hard rear hub on the standard suspenion is 1 degree.
Old 06-16-2008, 11:33 PM   #9344
majicman's Avatar
Default wheel spacing shim
What is the best shim to use as a wheel spacer between the hex and wheel to widen the stance of the car? I know that some use 1mm shims but what is the OD/ID or part number people are useing?
Majicman
Old 06-16-2008, 11:51 PM   #9345
94eg!'s Avatar
Tamiya sells them in two different colors (red & blue). I don't know if they are the same thickness or not (I would bet they are the same). 53646 & 53647
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
