Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 06-09-2008, 08:33 AM
  #9301
macnkitty2002's Avatar
all belts must be broken in, and may appear too loose afterwards if still set at the factory tension. after breaking them in, readjust the tension.
macnkitty2002 is offline
Old 06-09-2008, 09:45 AM
  #9302
majicman's Avatar
This is good advise and general info, however how do I as a first time belt drive user determine when the belts are "broken in"? Is there a fomula or general rule of thumb that says after X minutes of use a belt is considered broken in?
Thanks for your help.
majicman is offline
Old 06-09-2008, 11:46 AM
  #9303
I'd say after 5-7 packs your belts should be broken in. Once you think they are broken in, test the tension. Try to have the belts as loose as possible without allowing them to skip teeth on the pulleys. You should be able to press down on them and they spring back up.
Old 06-09-2008, 11:54 AM
  #9304
majicman's Avatar
So that's 25-35 minutes of running @ 5 minutes a pack. Since track time is not generally availabe outside of race day, would I achieve the samething If I attached a dremel to the axle and ran it at around 2-3k rpm for the same time?
majicman is offline
Old 06-09-2008, 01:29 PM
  #9305
Heck, I just put mine on the track and let them break in on the fly. Check them when you recharge your pack and adjust accordingly if necessary. You better off with a loose belt than a tight one.
You should check them often for fraying anyway.
AreCee is offline
Old 06-09-2008, 02:01 PM
  #9306
seaball's Avatar
free [email protected]^&job for anyone who can accurately measure the distance "x" labled on the attached photo.
look, this offer won't be around forever.
seaball is offline
Old 06-09-2008, 02:13 PM
  #9307
justin lessard's Avatar
justin lessard is offline
Old 06-09-2008, 09:16 PM
  #9308
Turbonium's Avatar
Trader Rating: 27 (100%+)
sorry... trade secret!
my TA05 diffs measure 17.00 mm from shoulder to shoulder, where the bearing sits. is that the dimension you are looking for?
getting more exact, looks more like 16.95mm....
Turbonium is offline
Old 06-09-2008, 09:38 PM
  #9309
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Stop lying to everyone. That is the only offer you ever do.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 06-10-2008, 01:57 AM
  #9310
myan_gsr's Avatar
Haha, thats my beast
I'd knew i recognised that dirty belt
19.1mm (between the bulkhead) is the measurement as described on ya diagram...
myan_gsr is offline
Old 06-10-2008, 07:07 AM
  #9311
seaball's Avatar
cool. thanks to you and turbonium for the dimensions. does that mean there is about 2mm of axial play in the diff (before using shims)? regardless, the 17mm is technically what i'm after.
thanks to both of you.
seaball is offline
Old 06-10-2008, 08:06 AM
  #9312
tc3team's Avatar
Yes, ive noticed some sideways movement in the front gearbox, it doesnt matter if you use a diff or the tamiya spool, unless you use shims it is there.
I have raced for a year with and without shims, you can get a very fine white coating on the gearbox housing if you're unlucky so it does pay to use 1 or 2 shims on each output.
I believe from memory these come with the Tamiya alloy blue spool if you buy one.... I'm almost certain that the 415 outdrive shims will fit too as they are a similiar, if not identical diameter....
hth
tc3team is offline
Old 06-10-2008, 08:12 AM
  #9313
94eg!'s Avatar
Trader Rating: 17 (100%+)
There is no way it's 1 to 2 whole millimeters of play. The included shims are only .1mm thick each, and they only give you 4 (with the TA05R). On my own car I was only running two as four made it overly snug for my tastes.
This was with the carbon bulkheads, so maybe the alloy ones are different, but I really doubt it. At most I would believe .5mm.
94eg! is offline
Old 06-10-2008, 08:20 AM
  #9314
tc3team's Avatar
brainfart, yes i admit ive not measured it but you can definately feel some moment there. it did get shimmed out with the shims that came out with the spool though
tc3team is offline
Old 06-10-2008, 08:26 AM
  #9315
seaball's Avatar
yeah, i imagine most of that 2mm is taken up by the flanges on the eccentrics. none the less, has there been any problem breaking diff screws? i think they are 2mm, no?
seaball is offline
