Like Tree2Likes
Old 05-13-2008, 07:19 AM   #9256
Andrew Barr's Avatar
Trader Rating: 73 (100%+)
Default TA05MS
I have either raced XRAY or Serpent and I have been eyeing the TA05MS. Can anyone give me some feedback on the pro's & cons and just any other info on the car. It looks pretty good and alot of bling.
Giant MTB
Andrew Barr is offline   Reply With Quote
Old 05-13-2008, 07:24 AM   #9257
myan_gsr's Avatar
Originally Posted by Turbonium View Post
you can use these, but probably a bit pricier...
http://www.tamiyausa.com/product/ite...oduct-id=53870
there is another one that is longer that can be cut down for a last resort... but the application and part number escapes me. ill look around.
I was contemplating that, may have to be the go. Thanks for the input!
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 05-18-2008, 05:19 PM   #9258
macnkitty2002's Avatar
Took my 05R to its first asphalt race yesterday. It was still set up for carpet, so I didn't expect anything from it. That was fine with me, since there were only 2 other people racing stock TC. Both of the other guys were using foams and brushless motors, I was sticking with my CS-27s and CO27. My first run was pretty hairy, I was skidding all over the place. Changed shock angle, took off the rear swaybar, and installed softer springs in the rear and that helped a lot. Did some more practice between rounds and decided to try the spool up front (had a ball diff). Car became much more driveable, stable on power and didn't want to spin-out. Lost a little turn in, but I got my confidence back when I was exiting the corners on throttle. Ended up being TQ, and one of the other guys dropped out because of breakage. It was me and one other kid, we were neck-and-neck the first 3 laps, then I started to gain some ground when he ran into the road-domes. I secured my lead when he lost a front wheel as he was turning into the front stretch. Cruised the rest of the time, though I must have still be going fast because I set a new track lap record. Can't say I was not proud for my first time on asphalt with a totally out of whack setup!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 05-19-2008, 03:18 AM   #9259
Skitee's Avatar
Hi Guys, If I want to change to the short arms would I have to change to shorter drive shafts too.
I'm running 1A-1D blocks in the rear with 48mm drive shafts, do I have to get 46mm drive shafts ?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-19-2008, 11:09 AM   #9260
joe of loath's Avatar
Originally Posted by Andrew Barr View Post
Try RC Mushroom
http://rc-mushroom.com/index.php?cPa...r_id=33&page=1
or RC Champ in Japan have to be the cheapest. Send them an email and they will get back to you with a price and postage. They don't do online sales, just fax them your details (they will send you an oder form via email). They are extremely polite, helpful and delivery is quick.
http://www.rc-champ.co.jp/Champ_Inte...onal_index.htm
The website is in Japanese but you can use a translater (through google) or fumble your way through like me.
RCmushroom is $140, so a little more expensive. RC champ is in japan so it means i have to pay for P+P, as my dad goes to hong kong sometimes he can go to rcmart and pick it up himself if i bribe him slightly (and maybe he can haggle a little )
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 05-19-2008, 12:12 PM   #9261
I have the IFS-R, which comes with the short reversible arms. The kit comes with 46mm swing shafts. The rear susmounts were 1XB and 1D.
redbones is offline   Reply With Quote
Old 05-19-2008, 12:30 PM   #9262
anyone used 3racing outdrives?
http://rcmarket.com.hk/product_info....oducts_id=3527
and the motor mount?
http://rcmarket.com.hk/product_info....oducts_id=2463
how are the quality on these? Are they as good as the Tamiya ones?
Old 05-19-2008, 03:38 PM   #9263
Trader Rating: 23 (100%+)
Arrow
I've used a few 3racing products and their quality is OK. However, I recommend Tamiya all the way. Tamiya parts are a little pricey but absolutely worth it. JMHO.
martman_oc is offline   Reply With Quote
Old 05-20-2008, 02:53 PM   #9264
bobbyvegas's Avatar
I will Co-Sign on the above post.. Tech Racing, Square and Tobee Craft are Japanese aftermarket companies. All higher quality than 3racing. Tech Racing is a personal fav...
2011 iic Poker Champion
bobbyvegas is offline   Reply With Quote
Old 05-20-2008, 05:50 PM   #9265
Kevin CBR's Avatar
If your dad goes to HK, you can check Waigo Hobbies also. They are the actual Tamiya Distributor in HK. They are not on the same main street in Mong Kok as the others. They are about a block away.
Kevin CBR is offline   Reply With Quote
Old 05-20-2008, 07:02 PM   #9266
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Here is a cheaper alternative, go to your local tool supply shop and buy a package of drill blanks, it will probably run you $5 for a dozen or roundabout that much. This way you can cut them to exactly the right length. I have run these before, and they work great. they might even be a little more durable than the stock ones.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 05-21-2008, 02:59 AM   #9267
cool thanks, i'll tell him next time he goes!
Old 05-21-2008, 03:46 PM   #9268
Default hingepins
for the person looking for hingepins look at lundsford(sp?) send them a message at there tech support they can cut you any size. I use a 50.5mm and trim down to the right size. They might be a tad pricey at 2.85+s&h per piece but they were custom cut to what I wanted.
hawk1x is offline   Reply With Quote
Old 05-21-2008, 07:00 PM   #9269
Would there be much noticeable steering loss off-power with a spool up front?
Losi Rock Rey
Old 05-23-2008, 04:12 AM   #9270
hey guy's I'm looking for a decent starting set up for a TaO5r. It will be for stock racing on ashpalt on a medium size track with decent traction, rubber tire also.
The car is bone stock. This is the wife's car. so I need a soft setup. as she is not an aggressive driver(well drive rc's anyway. real cars that a different story. hehehe)
also is there anything I should do the car. I heard throught the grapevine that there could be a problem with static electric with the chassis.
we have some tuning options as I run a 415 series car.
cheers
cyrrus is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
