Like Tree2Likes
Old 04-03-2008, 09:30 AM   #9166
Tsquare's Avatar
Originally Posted by pgeldz View Post
Hey folks. Almost finished with the build of my new TA05-R and could use a hand...
I got the 1 way diff and the instructions show the use of spacers between the diff and outdrives, and also shows the use of the pink sponge (cut in half) in the outdrive itself.
Problem is with the spacers and pink sponge halves in place, I can't snap the turnbuckles in place (using the factory lengths).
So, I have either 2 options...
1) Skip the spacers and use the pink sponge halves, or
2) Skip the pink sponge halves and use the spacers
I chose option 2, but my LHS who races the exact car uses option 1. He said either is ok.
Which would you guys do and why?
- Paulie
I skip both.
Tsquare is offline   Reply With Quote
Old 04-03-2008, 11:36 PM   #9167
Sweet. Thanks guys.
- Paulie
pgeldz is offline   Reply With Quote
Old 04-06-2008, 03:04 AM   #9168
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Ran the TA05R today for the first time since december last year. Put it on the track and it just worked, didnt change one thing except for a fresh set of CS27's and managed two 3rds and a 2nd in the three finals. One 3rd should have been a 2nd due to getting taken out. Im happy to share the setup if anyone wants it, i raced stock on ashpalt.
Fast XXXS is offline   Reply With Quote
Old 04-08-2008, 11:26 AM   #9169
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Just a quicky. What's the largest 64p spur can fit into TA05? 108t, 109t?
-KilleR- is offline   Reply With Quote
Old 04-08-2008, 03:39 PM   #9170
macnkitty2002's Avatar
I will be racing my 05R for the first time on asphalt parking lot this saturday. It is a pretty small setup that is quite tight. Should I stick with balls front and rear or put my spool up front? I've never tried my spool before because I raced on carpet all the time, but is asphalt the time to use it?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-08-2008, 04:34 PM   #9171
Redwings's Avatar
I believe that 105 is the biggest that you can use, but I have seen people use a 108 yet almost peaks through the bottom of the chassie.
Redwings is offline   Reply With Quote
Old 04-08-2008, 05:05 PM   #9172
HI_808's Avatar
On a really tight asphalt course, I think a spool would probably be difficult to set up well. A one-way might be better, but it depends on all of the other considerations (such as power, traction, precise course layout, etc.). I don't care for a front differential on asphalt because of the lack of on-power steering.
HI_808 is offline   Reply With Quote
Old 04-08-2008, 07:26 PM   #9173
lbckevin's Avatar
Trader Rating: 91 (99%+)
I would run a diff first, if its dirty parking lot, then my second choice would be a spool.
In stock , 27t I would run a diff
In 19t , I would run a spool
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 04-08-2008, 08:23 PM   #9174
Thanks for the replies. I will be running CS27s, DNA2 with a CO27. Not the smoothest track, or the tackiest either.
When would be the optimum scenario to use a spool?
Losi Rock Rey
Old 04-08-2008, 09:33 PM   #9175
lbckevin's Avatar
Spool is good when you dont need alot of steering ( it takes some away) and there is alot of traction and you need brakes.
In stock racing ....I run a one way or double diff.
Kevin Smith
Old 04-09-2008, 09:50 AM   #9176
RC Intel's Avatar
Default TA05I FS-R Pic
Originally Posted by JimmyMac View Post
Anyone have any pics of the TA05 IFS-R kit? #49491
item No:49491
●TA05-IFS R CHASSIS KIT
http://www.tamiya.com/japan/news/new...ews1.htm#49491
RC Intel is offline   Reply With Quote
Old 04-09-2008, 10:09 AM   #9177
yummy
Losi Rock Rey
Old 04-09-2008, 10:31 AM   #9178
m3ndo5a's Avatar
I converted my Ta05r to the IFS R+.
m3ndo5a is offline   Reply With Quote
Old 04-09-2008, 11:28 AM   #9179
Hebiki's Avatar
Trader Rating: 26 (100%+)
white belts. interesting.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-09-2008, 12:26 PM   #9180
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Ah, the white belts must be longer to fit 18T Mid pulleys! I was wondering when they'd get around to doing this.. Just what i was waiting for!
Should be fine if we keep the 36T pulleys instead of switching to 37T, just have to set it a bit tighter..
Here's the Description, translated..
IFS ★ TA05-chassis, 30-race essential part of a new species equipped with a kit. ★ new parts made of aluminum center plate and cutting out 37T-18T belt pulley set. ★ Center's Floating type chassis plate is easy to twist it to improve steering response, the belt-driven drive to achieve reduction of resistance.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
