Like Tree2Likes
Old 08-05-2005, 09:45 PM   #901
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rtypec
Arms are available seperately. I'm running 46mm swingshafts on mine with no problems.
If your running 46mm swingshafts are you also using the LW arms? I just thought for you to use the LW you need to be using the 50mm or the F201's, Please enlighten, so I know what to buy.
TNX
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 08-05-2005, 09:50 PM   #902
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
TNX
You can use the 46mm shafts with the LW, it will work, but under a hard hit it _may_ pop out being a little closer to the edge of the cup.. 48mm shafts are recommended (50mm must be a typo in their original statement a while back) to keep it in the outdrive at all (or most) times.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-05-2005, 09:58 PM   #903
cheehtae's Avatar
But what if I'm not going to use a LW then I guess the 46mm will not pop out cuz prolly the stock arms are shorter, And if I decide to use a LW then 48mm it is, do you have the part # for this?
TNX
Old 08-05-2005, 10:56 PM   #904
Jam-ehz's Avatar
TNX
Yup, 46mm are fine for the regular suspension. They seat in very far into the cups, be it the diff or one-way.
If you want to stick with the 46mm with LW, you can also buy the X series of suspension blocks, as they'll mount the arms a little closer to the chassis.
48mm Swing Shafts for Assembly Universal Shaft Set - Item No.53836
Only comes with the shafts, you'll need the other parts from another kit, such as the 46mm
Old 08-06-2005, 02:05 AM   #905
Hello , wich suspension blocks use instead of the original plastic parts. i use original suspension .
Caution , for those who buy tech racing lower mount top deck , you can't use it with tamiya aluminium transpondeur mount ( or you need to cut one side of the carbon deck) jean-michel
losi100 is offline   Reply With Quote
Old 08-06-2005, 07:39 AM   #906
cheehtae's Avatar
This getting more complicated everytime,Jam-ehz is the x series susp. blocks listed in the hop-ups portion of the TA05 manual , cuz I hate to ask for the Part# everytime I would need it, anyways just in case its not there can you post it too.
TNX
Old 08-06-2005, 08:15 AM   #907
Cheetae here is a great reference for hop-ups and part #'s
http://www.tamiyausa.com/product/cat...p?sub-id=72000
You can look up all of the suspension blocks along with the upcoming hop-ups too.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 08-06-2005, 01:07 PM   #908
MobileIT's Avatar
I just bought a TA05 Mercedes a couple of days ago north of Toronto (Pinnacle Hobbies), so they are "here" in North America right now.
MobileIT is offline   Reply With Quote
Old 08-06-2005, 07:02 PM   #909
badboy's Avatar
Trader Rating: 14 (100%+)
Clarification please?
1. If I'm going to use the lighweight suspension set for the TA05, I have to use only the XA,XB,XC, and XD blocks in order to use the 46mm swing shafts?
2. If I want to use the the X,A,B,C and D blocks which came with the original TRF 415, I will have to use the 48mm swing shafts? If yes, can I use the F201 swing shafts instead?
Thanks.
slow is fast . . .
badboy is offline   Reply With Quote
Old 08-06-2005, 08:08 PM   #910
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks.
1. yes
2. not really. to be safe.. use the 48mm. i used the 46mm with X through D blocks with 46mm swing shafts and it was fine.
Dan Garber... please call me when you have a chance (lost your number)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-06-2005, 09:41 PM   #911
badboy's Avatar
Hebiki : thanks. . . would you happen to have a good starting setup for carpet with rubber tires (tamiya type a).
slow is fast . . .
Old 08-06-2005, 10:56 PM   #912
JimmyMac's Avatar
Well ran my fully hopped up TA05. It's a porker! But I will say I'm already on pace with it compared to my Yokomo BD and EvoIV. I'm about 3 seconds off my fastest time. Car was nice and smooth. And it seemed to have good steering and corner speed. Gonna work with it some more tomorrow as I go to another track to race.
One problem I do seem to have is chassis tweak. It's kinda hard for me to set droop because of this. I'll have to mess around and find a different way to measure this.
Anyways, off to bed. So far I like the car alot! I'll be leaving my Yokomo at home tomorrow and give this car a good shake down!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-07-2005, 03:58 AM   #913
Hebiki's Avatar
sorry dude. the closest carpet track to me is 420 miles.
Hebiki Design Works
Old 08-07-2005, 05:09 AM   #914
Its funny how people keep saying its heavy with options installed, a mate of mine just built his, with all tamiya options, and all tech components, his car was 1518 grams, with a weight limit of 1500 i think thats pretty impressive.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-07-2005, 05:44 AM   #915
badboy's Avatar
Hebiki : thanks again dude!!!
Waht would be the best lighweight set to buy for the TA05?
1. TA04/TB02 Lighweight Suspension Set
or
2. TRF 415/TB Evo III Lighweight Suspension Set
slow is fast . . .
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
