Like Tree2Likes
Old 03-22-2008, 08:48 PM   #9106
Originally Posted by Waltrip55 View Post
That's how my car is right now...but doesn't seem right for some reason. Maybe because I've never had the weight distribution this off
It was the same with the TC3, TC4, Schumacher ST2000, etc. All those had some imbalance issues depending on your running gear and batteries.
You learn to add weight to the light side and adjust pre-load/tweak as needed to level out the ride.
C'est la vie!
AreCee is offline   Reply With Quote
Old 03-22-2008, 09:34 PM   #9107
oME
oME's Avatar
Default Guys do you have the pictures for the F.D.R. table for TA05???
Also if anyone can help about the list of hop ups for ta05
thanks!
Itís not about winning the race itís about being on the race!
oME is offline   Reply With Quote
Old 03-22-2008, 10:41 PM   #9108
myan_gsr's Avatar
thanks!
Hi,
The best resource for the hop-ups I've found is the tamiya usa site link below:
http://www.tamiyausa.com/product/rcp...chassis_id=A73
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 03-23-2008, 04:47 AM   #9109
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
looking to run 2 or 2.5deg rear toe in in the rear... can anyone point me to which suspension blocks i should be looking for (TA05MS)? Kinda new to the Tamiya camp...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-23-2008, 07:35 AM   #9110
myan_gsr's Avatar
I would really like some more information on this also... A friend of mine wants to use aluminium toe blocks for his standard suspension 05. Did tamiya ever supply this information in the manuals?? I remember seeing something but i was never confident that i would make the right decision.
www.brccc.org
Old 03-23-2008, 07:47 AM   #9111
It's in some of the manuals and not in others. It's in the TA05IFS manual but not in the TA05R manual.
Short course on suspension blocks:
A=0 degrees
B=1 "
C=2 "
D=3 "
Old 03-23-2008, 12:11 PM   #9112
Waltrip55's Avatar
After putting the car on a set-up board, ajusting the preload on each shock to have even ride height would have one messed up car. It's even for the most part, with minor preload ajustments. I need to add weight to the right rear...that should balance it out and make it easier to set it up. As far as droop, I just have it so I can lift up the the car with the tires still touching the ground with the suspension unloaded slightly. I tried getting the droop screws as close as I could in the manual, and ajusted so they are even on both sides.
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 03-23-2008, 12:48 PM   #9113
That makes the most sense to add the weight. I know that adding weight just doesn't sound right but it is the best way to balance the side to side variation. My brushed set-up doesn't need the weight but the BL does.
Old 03-23-2008, 12:57 PM   #9114
Waltrip55's Avatar
Ya, adding weight does sound backwards, but should help greatly. Thanks for all the help.
Brett Steller <><
Old 03-23-2008, 01:10 PM   #9115
Blueman Austria's Avatar
Hy there!
Does anyone know if the new NSX2007 Body from the IFS fit on a normal TA05 or an other "normal" Tamoya chassis?
Greetings from Austria
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 03-23-2008, 01:36 PM   #9116
Originally Posted by Blueman Austria View Post
Hy there!
No, Nein, Nyet; it will not fit the normal upright chassis, that is the reason for the IFS (lower front profile).
Old 03-23-2008, 10:20 PM   #9117
TEM
TEM's Avatar
Default IFS?
For the guys running IFS conversions from a regular 05 or an R; can you actually use the regular LW knuckles and C hubs (that comes with the R kit) in the front? or do you HAVE to use the IFS C hubs and knuckles?
TEM is offline   Reply With Quote
Old 03-23-2008, 10:27 PM   #9118
lbckevin's Avatar
Trader Rating: 91 (99%+)
You dont have to run the IFS knuckles...I ran the conversion and had no problems with the regular type r parts.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-24-2008, 02:41 AM   #9119
Same here. No problems using the R parts in the conversion.
DirtyRacer is offline   Reply With Quote
Old 03-24-2008, 09:36 AM   #9120
mjderstine's Avatar
hey guys, besides having options for some cooler looking bodies, wher are the benefits of having the OFS conversion on the ta05?
TA05 spec class.
DF03 w/ carbon chassis
DB01R Stock class
2 x GB01 Tamtechs
Custom solid axle SC
mjderstine is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
