Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 03-19-2008, 05:25 AM
  #9076
mjderstine's Avatar
thanks for the feedback guys. i race on smooth asphalt that was put down specifically for racing rc cars at the track site. most guys use foams because the track is very smooth and foams seem to get the best grip. i am using hpi x-patterns and get very good grip with them too.
the track, when set up for tc racing,(they make it an oval sometimes too) is usually very tight with two long straights with big sweeping turns at the ends.
so maybe a stiff chassis wouldn't be the worst thing for this track.
but when i race oval i would want a more flexible chassis correct?
mjderstine is offline
Old 03-19-2008, 06:28 AM
  #9077
thanks for all the info regarding the gearing of ta-05
best of blue is offline
Old 03-19-2008, 06:37 AM
  #9078
tc3team's Avatar
I would change the chassis as a last resort, more so if you have not been racing for too long. The stiffer chassis is best suited to high traction tracks, (usually indoors on foam tyres) moreso if the track is tight and a technical layout.
The ideal solution would to buy a 2nd chassis and use that solely for the thicker chassis, then experiment your heart away... Get a roller cheap off ebay etc...
tc3team is offline
Old 03-19-2008, 07:41 AM
  #9079
Kevin CBR's Avatar
Originally Posted by Hebiki View Post
ooo new car scheme coming out.
Hey Hebiki, I already have this kit (Yeah, I know you are surprised). The body is the same as the Ebbro 350R, just different livery.
Kevin CBR is offline
Old 03-19-2008, 07:42 AM
  #9080
mjderstine's Avatar
thanks TC3.
i was thinking about the same thing. just trying another chassis. one for each setup, first of all it a pain changing the setup every two weeks for oval then road courses. what i did do is get another guy really intested in the ta05, who actually races it, he beat a whole bunch of corallies and asssocisted guys the other day with his $100 ta05.
what i did do is get a tb02 chassis the other day on ebay, its coming ready to run from a guy who only drove it a couple times. its not the same chassis, but at least ill have two that share some parts.
Old 03-19-2008, 08:26 AM
  #9081
tc3team's Avatar
cool, hope things hook up well for you! Just keep an eye on the belt tension on the ta05, after a few races from new you might need to retension them.
Raced my ta05 for a year in stock, still on the first set of belts too...
tc3team is offline
Old 03-19-2008, 09:02 AM
  #9082
Hebiki's Avatar
Trader Rating: 26 (100%+)
you dont surprise me anymore Kevin yah i like this livery better than the original one.
Hebiki is offline
Old 03-19-2008, 09:11 AM
  #9083
Redwings's Avatar
Default Drag problems
Hey guys, need help.
I have a TA05r, its the first time I ran since buying it new two week ago at TCS. I noticed that the gears were kind of loud compaired to others running TA05's that are quite. I took the motor out and dosen't seem to be rolling as freely as it should. The belts are ok (not too tight or too loose). What seems to be the problem? I'm just wondering if its the bearings because it new?
Thanks for the imput.
Paul
Redwings is offline
Old 03-19-2008, 09:30 AM
  #9084
Hebiki's Avatar
Paul
Paul,
did you spray out the bearings? or just install them? if you didnt spray them out, the grease is still in there. that might be a cause of the drag.
- Chris
Hebiki is offline
Old 03-19-2008, 09:33 AM
  #9085
Check your diffs to see if one or both are rubbing against the bulkhead. It is easy to misalign the eccentric bearing holders thereby tilting the diff.
Remove the center shaft and try rolling the chassis without the belts on the center pulley.
AreCee is offline
Old 03-19-2008, 09:44 AM
  #9086
mjderstine's Avatar
i have the blue aramid belts in mine and after a couple runs i had to tighten it, they are both on the tightest setting.
i have also noticed my car is pretty darn loud compared to the other guys, ive cleaned the bearings before with some acetone and relubed them. i think its my spur and pinion, both have had their share of pebbles in them.
Old 03-19-2008, 09:46 AM
  #9087
tc3team's Avatar
check the teeth on the spur gear, they go loud after a few runs usually, they may look a bit "off centre" too as a clue.
Switch to 48 or 64dp and you should see the noise go away
tc3team is offline
Old 03-19-2008, 09:52 AM
  #9088
Redwings's Avatar
Thanks for responses. I will be looking in to all of your ideas.
Thanks again.
If anythings else, please let me know.
Paul
Redwings is offline
Old 03-19-2008, 11:14 AM
  #9089
mjderstine's Avatar
never mind (edit) its on the same page as this one. got my answer. 26-32 and 104
what company makes them?
can i just get an old spur gear/ pinion combo. im running the 19T class races on a pretty tight track, and i have never switched any of my rc to anything but the stock pinions/spurs.
what are the "normal" teeth count for 48 and 64 pitch?
Old 03-19-2008, 09:04 PM
  #9090
HCS
Hello, I was hoping someone could help me out. I recently got a TA05-IFS and have a question about drive belt tension: How much deflection should the aramid drive belt have? Any advice on a suggested range would be greatly appreciated, thanks
HCS is offline
