Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 12-11-2007, 07:55 AM
  #8686
wog....supraman's Avatar
hey,
can any1 give me any advice on building a Ta05.....as iam going 2 start building mine soon!
cheers
wog
wog....supraman is offline
Old 12-11-2007, 08:37 AM
  #8687
tc3team's Avatar
Originally Posted by wog....supraman View Post
hey,
cheers
wog
Take your time and be careful how you assemble the steering assembly (If the arms are put on the spindles the wrong way you wont get enough steering lock left to right) and pay attention to the differential housing belt tensioners, make sure they are both on the same spline each side.
It is in the manual, but make sure you file out the wishbones exactly as per the manual, or they could bind.
If something doesnt look right, check and recheck the instructions and be logical, HTH
tc3team is offline
Old 12-11-2007, 08:39 AM
  #8688
Just follow the instructions and pay attention to the parts orientation and you're good to go. If you have four (4) 5x8 bearings you can drop them into the steering arms and use some 5mm shims to remove play.
AreCee is offline
Old 12-11-2007, 08:43 AM
  #8689
Trader Rating: 17 (100%+)
Originally Posted by lbckevin View Post
what gearing are you guys running for brushless ( 13.5) in your TA05 ?
I run rubber tires....looking for a good FDR or spur /pinion combo...
4.5 FDR should be plenty fast for your TA05. Once you have the setup that you are comfortable with, you can go even lower...4.2 may be.
However, you might have to grind a little alum off the top motor plate in order to use a 50 pinion and 77 spur (just kidding...but you still need to do that to mount some monster size pinion for 13.5)
Solara is offline
Old 12-11-2007, 09:23 PM
  #8690
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
I run 4.4 FDR with my 13.5 standard rotor.
Fast XXXS is offline
Old 12-11-2007, 09:37 PM
  #8691
Originally Posted by grantbaker View Post
Picked up an 05ms about 2 months ago (in japan), and was wondering about the 2 sets of front c's that come with the kit. They're labeled 2rl and 4lr, is the difference in caster or camber?
The MS is great, the only weak points I've found are some of the plastic/carbon in the front end and the aluminum turnbuckles on the front. I ditched the front one-way after the first few laps.
The futaba s9550 is great! Unfortunately, the mamba is too much for the local track here...
Could you please tell me the maker and part number of your aluminum steering knuckle? They have three holes on them, I suppose they are made by Square RC? Could you tell me where to get them?
I keep breaking this part on my local indoor track, so I really want to replace them with aluminum parts.
Thanks a lot!
dendog220 is offline
Old 12-11-2007, 11:23 PM
  #8692
Trader Rating: 8 (83%+)
i need a very torquie fdr
i will be using 18t center pullys
anyone wanna help me out what gears i should use?
48p
i730 is offline
Old 12-12-2007, 03:03 AM
  #8693
Fast XXXS's Avatar
What motor will you be running? What track? Tight or open? or just bashing?
Old 12-12-2007, 05:35 AM
  #8694
g12314's Avatar
Just put the 13.5 from my MRE (sintered rotor) into my TA05R. 88 spur / 43 pinion is my starting point (4.6 FDR). Depending on the track, it may be even lower, like 4.2 FDR.
I did need to grind a bit of the top plate to allow the motor to move further forward for proper gear mesh.
Jimmy
g12314 is offline
Old 12-12-2007, 08:59 AM
  #8695
novak xbr 8.5
lipo
spool in rear ball diff up front
18t center pullys
drifting
i730 is offline
Old 12-12-2007, 09:01 AM
  #8696
Trader Rating: 41 (100%+)
Jimmy
Where's mine??
Nexus is offline
Old 12-12-2007, 09:08 AM
  #8697
Originally Posted by Nexus View Post
Where's mine??
I told you before...your TA05R with options and TCS ready is in my house right now, all you need to do is bring my NIB RTR LOSI 8ight and you are ready for the TCS. Simple as that....
Who wants to sell NEXUS a TA05R..? He paid top $$$$....promise.
Solara is offline
Old 12-12-2007, 03:57 PM
  #8698
HI_808's Avatar
Next year Nissan is going to run the R35 GTR in the Japanese SuperGT series. I hope Tamiya produces a replica body of it for the TA05!
HI_808 is offline
Old 12-12-2007, 04:05 PM
  #8699
HI_808's Avatar
I forgot to show what the R35 race car will look like... Here are some pics. It looks like it would fit the TA05IFS profile quite well!
HI_808 is offline
Old 12-13-2007, 05:12 AM
  #8700
macnkitty2002's Avatar
agreed!
macnkitty2002 is offline
