Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 11-22-2007, 09:56 AM
  #8611
Trader Rating: 17 (100%+)
Originally Posted by macnkitty2002 View Post
does anybody know if the Orion Platinum Lipo fits in the 05R chassis without modifications?
It fits..but like other said, you just cannot sit it as low as Nimh or the Carbon version of Orion Lipo....I have both LIPO from Orion and used them on the R all the time. I care the less about letting the battery sit as low as possible like other ppls think they MUST do that....as long as I have 20 minutes run time with silver can and 4800....I AM HAPPY
Solara is offline
Old 11-24-2007, 01:34 AM
  #8612
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
ok i am having trouble getting my gears to mesh. I am running a 68 spur and a 29 pinion. I cant mount the motor close enough as it hits the aluminium center panel. i have a bigger spur on the way but i didnt get it in time for racing tomorrow. i dont want to grind away the alloy but i need a quick alternate way to get the motor close enough to get the right mesh. Anyone have any ideas?
Fast XXXS is offline
Old 11-24-2007, 01:38 AM
  #8613
tc3team's Avatar
The only other option I can think of is to see if a 64dp setup will fit in, with a similar ratio. (Maybe it will be easier for you to source 64dp gears with a bigger spur gear if you know what im trying to say?)
Other than that, youve gotta grind it.
If youre only running the stock ta05, the stock motor mount is cheap as chips so it wouldnt be too deep on your pockets if you ended up needing a replacement...
They dont look like a very nice material to sand down though, so be careful! (wear the usual goggles etc if youre using a dremmel)...
tc3team is offline
Old 11-24-2007, 08:14 AM
  #8614
Kregger's Avatar
I was wondering if anyone knew where I could get a replacement motor mount for the 3racing graphite chasis (it doesn't take the standard motor mounts). I recently bent mine in a collision and am trying to get the car backon the track.
Kregger is offline
Old 11-24-2007, 08:23 AM
  #8615
Probably all those HK online Rcstore (Rcmart, Dinball, Rc-mushroom, Rcmodel...etc)
Solara is offline
Old 11-24-2007, 08:07 PM
  #8616
rccardr's Avatar
Use a 104/44 combination. Or a 96/41, 98/42, or 102/43. Those all fall into the 5.25-5.337 final ratio range.
rccardr is offline
Old 11-24-2007, 09:06 PM
  #8617
Fast XXXS's Avatar
I managed to race today. i put washers under the plate and raised it higher so i could get the motor under it and closer then went up a pinion gear. Car was great today. At the track i was running i managed to get .1 of a second quicker with my fastest lap time then what they get. and a total time or around 5 seconds quicker. Quiet happy with my car for the first drive.
Old 11-25-2007, 06:17 PM
  #8618
Georgeshobby's Avatar
Default Just wondering.....
What's you guy's opinion of the IFS system. I know it will let you run some bodies that were only available to 2WD cars, but has anybody raced it in a parking lot yet?
Georgeshobby is offline
Old 11-25-2007, 06:56 PM
  #8619
macnkitty2002's Avatar
from what i have heard and read in magazines, the difference is small. only the seasoned vet would be able to distinguish the slight handling differences between the standard 05 and the IFS. it's mainly another way for Tamiya to get some more sales. you gotta say it does look cool though. i'd like to see it with the "R" treatment.
macnkitty2002 is offline
Old 11-25-2007, 07:54 PM
  #8620
Fast XXXS's Avatar
Could anyone tell me what the effect will be if i remove the rear sway bar? They are just the stock sway bars on it at the moment, front and back. Also does everyones TA05 tend to have a fair bit of steering slop? How could i reduce this? as my car tends to wander in a straight line.
Thanks in advance
Old 11-25-2007, 09:54 PM
  #8621
diha's Avatar
Anyone running a GTB SS10.5 in a TA05?
Can show pics of layout & also recommendation of gearing to start with?
Thanks in advance???
diha is offline
Old 11-26-2007, 01:24 AM
  #8622
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
For the layout, check it at http://www.rctech.net/forum/showthre...68261&page=253 post 7577.
-KilleR- is offline
Old 11-26-2007, 06:57 PM
  #8623
does anybody know the internal drive train ratio of the 05R? i am running a 104 spur and a 31 pinion.
Old 11-26-2007, 07:09 PM
  #8624
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
2.25 according to gearchart.com.
http://i63.photobucket.com/albums/h1...5gearchart.jpg
I use 48p, but you can make your own chart for whatever you use.
Turbo Joe is offline
Old 11-26-2007, 07:51 PM
  #8625
Default sway bar
By removing the rear sway bar you will let the rear end roll more and give you more rear traction. The sway bar stiffens up the back or front end and will make it slide easier as the weight transfer side to side is less with the sway bar on. At least that's my 2 cents....
I have been running the TA05 for a year in the stock 27T brushed class and its been great. There are three guys that are flat out faster than me at our club, mainly because they have more experience and take more time tuning their cars. I've been racing for a year and generally don't mess with setups unless I have traction roll. So the O5 is great car to learn how to drive with.
This weekend I stuck a 19turn in a stock 05 with just front universals and ended up 5th. Here I did traction roll in each of the qualifiers, but had it figured out for the final.
So to anyone thinking about picking up a TA05 kit is definately a good buy.
My current setup costs were as follows:
TA05 kit - 100 US New
GTS speed controller - 78 CDN
19 turn motor - 55 CDN
Foam tires - 16 US
Radio/receiver - 80 CDN - USED DX2
Total cost - $329
If you're interested in it PM me as it might be forsale shortly minus the radio.
cutwo is offline
