Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 11-19-2007, 03:16 PM
  #8596
Trader Rating: 23 (100%+)
Arrow
Originally Posted by macnkitty2002 View Post
does anybody know if the Orion Platinum Lipo fits in the 05R chassis without modifications?
I have no problem running the 4800 lipo without any modifications to the chassis, just turn the strap upside down.
martman_oc is offline
Old 11-19-2007, 03:25 PM
  #8597
Core Creations's Avatar
Trader Rating: 105 (100%+)
I've always used the carbon strap, but the stock strap will work flipped over (it's designed to be used that way with stick packs).
You can leave the ribs in the chassis...but I like my CG as low as possible...and it lowers the pack 5mm so....
will the battery strap still work with it, or will I need to put some sort of spacer between the strap and the battery?
Core Creations is offline
Old 11-19-2007, 04:12 PM
  #8598
BLUE 2's Avatar
Questions??
Hi All
Does anyone know the specs of the new TA05RR coming out ?
49418 TA05-RR CHASSIS KIT 29800YEN JAN ( off Rainbow ten )
BLUE 2 is offline
Old 11-19-2007, 04:16 PM
  #8599
HI_808's Avatar
That's a typo.
http://www.tamiyausa.com/product/ite...oduct-id=49418
HI_808 is offline
Old 11-19-2007, 06:21 PM
  #8600
lbckevin's Avatar
Trader Rating: 96 (99%+)
The screw sets are on ebay all the time. Try this Item number: 120183397611
Check speedtechrc.com
lbckevin is offline
Old 11-19-2007, 07:11 PM
  #8601
Default TA05 Questions
I bought one of these off of ebay, and have some questions which I can't find answers for in either the documentation of the manual or as a reply in this thread.
1. My car came with a center one way, and I'd like to convert this to a standard layshaft, because I'd like to run this car with a solid axle in the front. So what parts do I need to make this happen?
2. I'd like to be able to change the rear toe in from anywhere between 0.5 degrees and 3.0 degrees, depending on the surface condition. Since this car doesn't use spacers like an Xray, I'm guessing I need either multiple suspension holders of different widths or different rear hubs. So what are the parts I need to make changes to rear toe in?
3. I noticed this car has pretty limited steering throw, about 10 degrees for the outside wheel and 15 degrees for the inside wheel using maximum ackerman. It seems to be limited by the turnbuckle ball end touching the bellcrank steering arm at maximum extension. Is there a way to get greater steering throw on this car?
edlan is offline
Old 11-19-2007, 07:22 PM
  #8602
C5R01's Avatar
Default I THINK THIS IS THE IFS NSX
If you look at the wheel wells there is a difference than the prev. NSX's
C5R01 is offline
Old 11-19-2007, 10:20 PM
  #8603
HI_808's Avatar
That's cool.
The older (2005 and below models) SuperGT NSX doesn't look as low as the current model. The 2005 (?) ARTA NSX I had on my TA05 used the lowest holes on the body posts, so scale replicas of new lower profile NSX aren't possible to use properly without the IFS setup.
HI_808 is offline
Old 11-20-2007, 03:24 AM
  #8604
sosidge's Avatar
Check the way that the steering has been assembled, if it is in the outer holes on the steering knuckle you will not have any lock.
Layshaft question should be answered with a look at a manual. Toe in is changed by blocks but it depends a little on what suspension parts the car is running.
sosidge is offline
Old 11-20-2007, 03:43 AM
  #8605
tc3team's Avatar
Heres a link to the manual, all the part numbers should be in it for you to change back to stock parts
http://www.tamiya.com/english/rc/rcmanual/ta05.pdf
I have a lightweight centre shaft, it saves a few g if you want to buy that instead, the p/n is 53915.
hth
tc3team is offline
Old 11-20-2007, 12:49 PM
  #8606
hth
Thanks for the help.
edlan is offline
Old 11-22-2007, 06:51 AM
  #8607
tc3team's Avatar
Can anyone tell me if this part will fit my ta05 please?
http://shopping.rcmodel.hk/product_i...oducts_id=5562
If it doesnt ah well, at least i've got an expensive paperweight in the post LOL
tc3team is offline
Old 11-22-2007, 08:42 AM
  #8608
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I don't THINK so...but you might be able to adapt it.
Here's a TA05 adapter.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNZB3
Turbo Joe is offline
Old 11-22-2007, 08:45 AM
  #8609
tc3team's Avatar
D'oh I'll have a go at trying to get it to fit, if not never mind only cost me a few £, thanks for the answer though
tc3team is offline
Old 11-22-2007, 08:56 AM
  #8610
sakaguchinet's Avatar
Square has also complete Sets of Titanium Screws (für TA05, TA05R and TA05IFS). These screws are 100% identical to the Tamiya ones.
More Info on http://www.rc-square.de/english/squa..._ta05-tb02.htm
sakaguchinet is offline
