Tamiya TA05 Touring Sedan >
Like Tree77Likes
Old 11-14-2007, 01:40 PM
  #8551
rtherbe's Avatar
TurboJoe I have a question. You mentioned your car spinning out while coming out of turns (turned out to be a radio glitching on yours) I have a similar problem with my RDX only it just spins out on left turns, here is my plea for help on the RDX thread: http://www.rctech.net/forum/showthre...pp=30&page=346 It is post 10364 and a few others after, I believe I might try looking in that direction, any input?
rtherbe is offline
Old 11-14-2007, 01:57 PM
  #8552
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I'm a decent wrench and a mediocre driver...LOL...I just keep to the basics.
Assuming you have sufficient friction (the right tires), then it's gotta be either a steering symmetry issue (more throw on one side or the other) or a weight transfer issue (uneven droop, binding suspension, wrong springs, uneven roll centers, etc.)
Is it always the same corner you're going left through...or every left turn on the track?
Turbo Joe is offline
Old 11-14-2007, 03:02 PM
  #8553
rtherbe's Avatar
We run an oval on asphalt mostly. All left turns are unstable. I have yet to rebuild the diffs with fresh springs/cone washers. I have them on the way. Thats my next step.
I have checked and double checked all suspension settings, and movements, short of re-rebuilding the shocks (they feel good) I have a good understanding of how cars work, been a Volvo tech for the past 22 years.
It is almost as if when in the middle of the turn, the left front wheel sticks and the rear spins around on that wheel as a pivot. This only happens on power, she seems to react normally off power. It is no huge deal, I have two great cars a TC3 and TA05 to keep me happy. This RDX is a sweet car though, especially on right turns Thanks for the reply. your post gave me some things to think about. AL Mohr
rtherbe is offline
Old 11-14-2007, 06:22 PM
  #8554
Turbo Joe's Avatar
I wish I could see it...
On the other hand, one of the factory Kyosho guys was helping me with my cars the other night...sorting out stuff I didn't even know was wrong...LOL...the sad thing was that I thought it was pretty dialed the way it was.
Old 11-15-2007, 02:21 AM
  #8555
Blue_VB_SL253's Avatar
Originally Posted by tc3team
I live in the UK and ive had no problems, the only "problem" if you can call it one is the hold up you get in customs. Cant say what shipping to Australia is like though.
Thanks for that mate
Originally Posted by MonkeyNuts
With a center one-way you can corner at higher speeds. you shouldn't need to 'brake' just come of the power gently with the front + center one-way and hold your speed and corner quicker and you will gain time.
Liam
so what you are saying, if you buy a front one way diff, also buy a center one way as it helps with overall handling and performance?
Also while Im at it, im just wondering why there are so many people wonting to convert the ta05, into the ta05 ifs, to em it seams like a fair bit of mucking around to a car that already performs well if you just add a few upgrades. Swaping over major parts that work diffrently is silly, just go buy a ta05ifs imo
Blue_VB_SL253 is offline
Old 11-15-2007, 02:35 AM
  #8556
rtherbe's Avatar
Thats Funny. I am just changing one thing at a time, I will swap radio and receiver at one point. I am using my JR xr2 on this which I usually use for off road may have a glitch I am not aware of.....But my gut tells me drive train since it is on power.
rtherbe is offline
Old 11-15-2007, 11:28 AM
  #8557
Turbo Joe's Avatar
Naaah....unless you had some trick front out-drive bearing that locks up on cue, that's not very likely. Just stick to the basics. Besides, it's almost always tires.
Old 11-15-2007, 06:04 PM
  #8558
Fast XXXS's Avatar
Trader Rating: 51 (100%+)
Just got my TA05R the other day.
Here are some pics. I also have NIP Front and Center Oneways to try out and also a full sway bar kit.
Attached Thumbnails Tamiya TA05 Touring Sedan-100_1775.jpg   Tamiya TA05 Touring Sedan-100_1776.jpg
Fast XXXS is offline
Old 11-15-2007, 07:02 PM
  #8559
Airflow's Avatar
Hi. Im stocking up spare parts for my TA05R. In tamiya USA, theres --- 1
RC Reversible LW Sus Set - TA05/TB02/TA04 #53899 which is super expenssive for me. And theres this ---- RC Short Reversible Sus Arm #53928. My question is, is this the same suspension arm included in the LW Sus Set? All I need are suapension arms.
Airflow is offline
Old 11-15-2007, 07:19 PM
  #8560
Turbo Joe's Avatar
These are the original TA05R arms:
http://www.speedtechrc.com/store/ebp...id=509&id=1697
That full kit (53899) would give you a complete set of spares for the entire suspension system...bearings and all the uprights and axles and everything. Not a bad deal for spares...but more than you'll probably ever break.
Old 11-15-2007, 07:38 PM
  #8561
Airflow's Avatar
Hey thanks for the reply.
Now which is better?
RC Reversible LW Susp. Set - TB-02 & TA04
Item #53794
or
Item #53899
Airflow is offline
Old 11-15-2007, 07:44 PM
  #8562
Patriiick's Avatar
careful..the short arms are less used and are not the same as the regular lightweight ones..
airflow: you obvioulsy want the ta05 set (53899).that s the most adapted one.
Patriiick is offline
Old 11-15-2007, 08:40 PM
  #8563
Turbo Joe's Avatar
Item #53794
or
Item #53899
I'm pretty sure the 53794 has been replaced by the 53899.
The early one had 46mm dogbones included, now it comes with axles only,because the 05 takes 48mm bones when using that kit...so now it's more "universal".
It comes with some other parts now, instead of the bones but I forget what they are...but you need to buy the correct bones to complete it.
Yep...
http://www.tamiyausa.com/product/ite...oduct-id=53899
Old 11-15-2007, 09:12 PM
  #8564
Airflow's Avatar
Shucks...
Universal shafts are not included.
Oh well...
Thanks.
Airflow is offline
Old 11-16-2007, 01:50 AM
  #8565
buboy28's Avatar
MY TA-05R sorry for the pics still learning the camera
buboy28 is offline
