Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 10-24-2007, 05:53 AM
  #8461
DNA2 I found left a lot to be desired for rear end grip, Mazda6 I felt better, something a little less agressive.
DA_cookie_monst is offline
Old 10-24-2007, 08:59 AM
  #8462
macnkitty2002's Avatar
take off that rear sway bar and you will get the rear end grip that you are looking for.
macnkitty2002 is offline
Old 10-24-2007, 09:39 AM
  #8463
RC MARKET's Avatar
M6 is better !
RC MARKET is offline
Old 10-24-2007, 03:12 PM
  #8464
I don't run sway bars these days, tried it, don't like them.
Old 10-24-2007, 04:38 PM
  #8465
Trader Rating: 32 (100%+)
Nobody runs sway bars anymore... weird.
ittjv is offline
Old 10-24-2007, 04:53 PM
  #8466
Blue_VB_SL253's Avatar
Since every one is on about rear grip ive only just found a balance for mine, im now using a medium/ hard rear spring set up with 60w team associated oil in the rear and front is a hard spring with 60w oil, and the help of the Dodge Stratus 3 cover with the rear wing mounted in the middle hole. Before i all this the rear end would step out very easily when accelarating out of a corner, generaly very slidy with every movment.
Edit: i havent used sway bars yet, and now i dont think i will have to
Blue_VB_SL253 is offline
Old 10-24-2007, 04:55 PM
  #8467
I do
I use the stock ones that came with the kit.
DirtyRacer is offline
Old 10-25-2007, 02:37 AM
  #8468
tc3team's Avatar
Personally I dont run sway bars, and if I was to consider using them it would only be on high traction tracks.
They stop the car hooking up too aggressively in the corners, but it is a very crude way of doing it. I prefer to work on the springs/oil/camber links and shock mounting positions than to just hide a setup problem with sway bars.
My take on it is that the sway bar is a very artificial way of getting the car to aid compressing and rebounding its suspension. Also, by playing with the rest of your setup you are running less weight by not having the sway bars on your car.
tc3team is offline
Old 10-25-2007, 04:08 AM
  #8469
I have updated my setup, as the car seemed a little hard to drive with a one-way in, so here it is
Old 10-28-2007, 08:04 PM
  #8470
DA_cookie_monst, im just wondering why on your set up sheet, you have the front diff tighter then the rear belt, whould this be so there isnt as much power going to the rear wheels so it spins during accelaration?
Old 10-29-2007, 02:43 AM
  #8471
tc3team's Avatar
Blue:vb By allowing the front diff to be run a little tighter it allows for slightly better turn in, but not so fierce as a spool.
hth
tc3team is offline
Old 10-29-2007, 06:07 AM
  #8472
Originally Posted by Blue_VB_SL253 View Post
DA_cookie_monst, im just wondering why on your set up sheet, you have the front belt tighter then the rear belt, whould this be so there isnt as much power going to the rear wheels so it spins during accelaration?
It helps pull the car out of the corner better, as the front axle is lighter loaded, you can get some wheel spin on the inner wheel, so you run the diff tighter to get drive to both wheels evenly.
Old 10-29-2007, 07:20 AM
  #8473
tc3team's Avatar
d'oh, misread
tc3team is offline
Old 10-29-2007, 07:28 AM
  #8474
I am assuming the poster meant diff's as I made no reference to belt tightness on the sheet.
Old 10-29-2007, 08:09 AM
  #8475
Yea guy's i did mean diff's, also thinking about belts at the same time while posting that. Thanks for that anyway, might have to try it for a little more turn in
