Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 10-17-2007, 05:52 PM
  #8431
pole_position's Avatar
Originally Posted by tc3team View Post
It can work well yes, any track thats flowing it will help your speed through the corners off throttle.
For tighter, technical tracks use a spool
Guys,
Any good spool to recommend for a TA05?
Thanks!
pole_position is offline
Old 10-17-2007, 06:08 PM
  #8432
macnkitty2002's Avatar
Guys,
Thanks!
right here!
http://www.speedtechrc.com/store/ebp...id=459&id=5802
macnkitty2002 is offline
Old 10-19-2007, 09:40 AM
  #8433
does the CF chassis dissipate the static charges better than the stock nylon chassis?
Old 10-19-2007, 09:41 AM
  #8434
Trader Rating: 32 (100%+)
Does anyone have a link for the TA05R manual? I can't seem to find it on Tamiya's website.
Thanks!
ittjv is offline
Old 10-19-2007, 10:05 AM
  #8435
yes, but if you don't want to buy one, you can add that jumper wire from the front chassis brace to the center motor mount
DirtyRacer is offline
Old 10-19-2007, 12:01 PM
  #8436
AWK
AWK's Avatar
Thanks!
You planning on getting one? We don't have one online, but let me know and I could get a copy to you. Maybe your post office would go a little quicker this time. Chris got his stuff in 2 days!
AWK is offline
Old 10-19-2007, 12:09 PM
  #8437
Hebiki's Avatar
Trader Rating: 26 (100%+)
yup..thanks dude! now get to BCR and race with us.
Hebiki is offline
Old 10-19-2007, 03:40 PM
  #8438
i've all ready got the chassis, i was just wondering if i still had to use the ghetto jumper wire.
Old 10-19-2007, 04:48 PM
  #8439
I'm thinking of upgrading my bother's car from a TB-02R to a TA05R.
ittjv is offline
Old 10-19-2007, 04:52 PM
  #8440
Hebiki's Avatar
05R is a good deal, esp with all the hopups it comes with.
jose, you making plans on attending the Seattle SIR TCS? you should try to go man, they have a fantastic track up there. (think indoor tamiya)
Hebiki is offline
Old 10-19-2007, 05:06 PM
  #8441
I'm *strongly* considering this. The good thing; my wife is totally for it too!
ittjv is offline
Old 10-20-2007, 12:24 AM
  #8442
don't bother with the jumper on the new chassis. I haven't had any issue since I've made the change.
Old 10-20-2007, 11:34 AM
  #8443
ya, i wasn't going to anyways. although this CF chassis is certainly a whole lot stiffer!
Old 10-21-2007, 04:02 PM
  #8444
i just tested out my car with the CF chassis, center one-way unit, rebuilt diffs and shocks, and a new 19t motor. i went from the stock shock oil (40wt?) to 30wt hoping to get a more plush ride, but i am getting the opposite effect. the car feels "jittery" whenever it gets up to higher speeds, and especially when i turn. maybe my diffs are still too tight, cause it is really not looking setup well. maybe it's just because i am running it on an unprepared (rough) asphalt neighborhood road, with really crappy HPI X-pattern treads (no bite at all). any suggestions as how to smooth it out? maybe go to a softer spring? i am using the stock white (yellow) springs.
Old 10-21-2007, 10:16 PM
  #8445
Registered User
asil's Avatar
CF chassis makes the car a lot stiff. you should try softer springs to give the car roll that it needs. And when you feel comfortable with set-up, you'll see that you drive a more predictable car with CF chassis.
Asil
asil is offline
