Like Tree2Likes
Old 10-01-2007, 11:33 AM   #8386
macnkitty2002's Avatar
The number of spacers required is so that you can change your wheelbase to suite the type of track you run on.
haha, i never knew that! it's so obvious now.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-02-2007, 04:40 AM   #8387
tc3team's Avatar
And a very good design too. Shimming the arms out to .5mm is great if you ever need to adjust it with that much precision... just make sure you use the tamiya blue colour hehe
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-02-2007, 06:48 AM   #8388
i was wondering why there was no wheelbase adjustment, i just had not found it yet!
Losi Rock Rey
Old 10-02-2007, 07:26 AM   #8389
tc3team's Avatar
lol, easily overlooked when its just a washer that looks like the rest of the kit stock parts as I found out too.
I guess I only really thought about it when I saw some blue shims going for cheap money that I thought "I could use them on my ta05"... And I then realised the same thing
Live and learn. Just dont go too excessive on the adjustment or you might bind up the dogbones (if you still run them) as the whole hub carrier obviously moves to make the wheelbase longer or shorter, the more you adjust from the kit setting, making the dogbone off centre in its positioning.
I think you'd have to be at maximum extremes to do that though! Most shims you can buy from 0.5 to 5mm, thats what package I got hold of.
Old 10-02-2007, 09:54 AM   #8390
waOscar's Avatar
I run L/W suspension (no dogbones) and you don't need to worry about how much you move the hubs in relation to the diff outdrives.
We run on tight/technical carpet and asphalt tracks. Keeping the wheelbase short makes the car respond quicker in cornering, unfortunately this normally make the rear end loose, so by moving the entire wheelbase rearward it settles the rear down but keeps the car responsive thru corners. End result faster corner speeds. We also run centre and front one-way for stock racing.
Wheel base settings
Front/Front 6.5mm
Front/Rear 3.5mm
Rear/Front 6.0mm
Rear/Rear 3.5mm
Total spacing is differant because the front still has the standard kit plastic suspension blocks.
Tamiya spacer set 53539
http://www.tamiyausa.com/product/ite...oduct-id=53539
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 10-02-2007, 10:06 AM   #8391
tc3team's Avatar
Thats useful info was0car, I kept my wheelbase almost similar to kit, but used the kit wishbones so I wasnt too sure how things would work out, thought better to post and be safe than sorry
Theres a few options to play with and see what works best.
Old 10-03-2007, 01:08 PM   #8392
Anyone have a rubber tires on carpet setup?
DirtyRacer is offline   Reply With Quote
Old 10-03-2007, 02:37 PM   #8393
tc3team's Avatar
there is a good setup quite a few pages back if you are able to spend the time to look for it, sorry I dont remember the page number
Old 10-03-2007, 02:48 PM   #8394
yea i don't wanna say i'm lazy buuuuuut i don't fee like going through 210 pages
Old 10-03-2007, 03:35 PM   #8395
before you ask, the rear toe-in is three degrees, 2' on the hubs and 1' inboard.
DA_cookie_monst is offline   Reply With Quote
Old 10-03-2007, 04:28 PM   #8396
Thank you!
Old 10-03-2007, 10:37 PM   #8397
Trader Rating: 37 (100%+)
Cool car but I'm debating selling mine...
If anyone has interest in a TA05R roller please email or PM me.
[email protected]
Nexus is offline   Reply With Quote
Old 10-08-2007, 06:10 PM   #8398
aussierevo's Avatar
Trader Rating: 14 (100%+)
Originally Posted by aussierevo View Post
seeking some help.....just purchased a new TA05 and running standard running gear 70T spur and 24T pinion with a orion method 17x2. Ran today and after 5minutes motor starts smoking and is really hot to touch. Track I run on is flowing, with a couple of tight sections, but I'm unsure of gearing (spur/pinion combo) to use for this motor, or in fact say a 15T motor that I was thinking of geteting. Can anyone suggest a balanced set-up for someone who doesn't race, and is not going to cause motor to over heat/smoke in the future.
Any suggestions will be appreciated.
Does anyone have any suggestions for me?
aussierevo is offline   Reply With Quote
Old 10-08-2007, 06:56 PM   #8399
Rcjunk-yard's Avatar
Default smokey motor
> seeking some help.....just purchased a new TA05 and running standard >running gear 70T spur and 24T pinion with a orion method 17x2. Ran today and >after 5minutes motor starts smoking and is really hot to touch. Track I run on >is flowing, with a couple of tight sections, but I'm unsure of gearing >(spur/pinion combo) to use for this motor, or in fact say a 15T motor that I >was thinking of geteting. Can anyone suggest a balanced set-up for someone >who doesn't race, and is not going to cause motor to over heat/smoke in the >future.
There could be a lot of things wrong. If that motor has BUSHINGS instead of BEARINGS it will generate more heat especially if it's not broken in. I think the HAVOC's are not rebuildable which means theres not a lot you can do to them. Try a STOCK motor like a p2k or green 3 and see if you have the same problem. You could have a bad bearing or binding somewhere, does the car roll fine without the motor in? Your gonna have to be more specific. Do a search on here there should be a gear ratio chart somewhere. You want approx 3.24 I think it was for final ratio. If you order any of the HPI spur gears they used to include a chart for gear ratio.
HTH
p.s. check out the setup sheet above, 19t motor 76 spur 26 pinion, big difference than what your running.
Rcjunk-yard is offline   Reply With Quote
Old 10-08-2007, 07:25 PM   #8400
aussierevo's Avatar
car rolls all ok, doesn't appear to be any binding at all....all new bearings etc.
I'm confused about overgearing and undergearing the car.....it appears that at 70/24 x 2.25 I'm running 6.56 FDR, which I'm unsure is overgeared or undergeared.........the more I read the more confused I get.
If I was to run 70/22 x 2.25 I get 7.15 - would this address the heat problem for the motor, or if I go 64 pitch spur and pinion, some good combo's to run with a 14t or 15t Associated LRP V10 14t Double.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
