Like Tree2Likes
Old 07-26-2005, 09:09 AM   #826
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Are those steel turnbuckles on ur ta05?
vi3tishduy is offline   Reply With Quote
Old 07-26-2005, 09:20 AM   #827
ttso's Avatar
No, front AE Ti (28.5mm), rear Kyosho Ti (32mm or something). I use longer in rear for extra secure while using most outer pos on upright. You never know if you going to knock the wall or be rammed in racing. A deformed upper link will cause the car losing its setting, even un-driveable.
ttso is offline   Reply With Quote
Old 07-26-2005, 11:13 AM   #828
Originally Posted by tomdav
Off subject. They had some lemans cars on display, are these re-release?
http://www.teamjoybox.com/shs05/shs05254.jpg
Yeah they are, i got 3 of those at home. I got the merc and the jaguar and i got the NSX in mint condition
Wouter.Z is offline   Reply With Quote
Old 07-26-2005, 03:29 PM   #829
vi3tishduy's Avatar
Haha, can you post the pics up if possible? What colour is that spray on that Ferrari? Looks pimp ^_^
Old 07-26-2005, 11:26 PM   #830
B3x
Default TA05 shocks
Hello
Which TRF shocks do you use on the car ?
B3x is offline   Reply With Quote
Old 07-26-2005, 11:54 PM   #831
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default TRF Shocks...
Originally Posted by B3x
Hello
Get these: #49355
and these: #49311 (the set above only comes with plastic retainers)
both can be ordered at speedtechrc.com
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-27-2005, 12:57 AM   #832
Ghostfit's Avatar
Originally Posted by sonicnova
Purchased my TA05 abt twoweeks ago. There are two here running in the asphalt track. Their performance "converted " a couple of the top racers...and now they are awaiting the arrival of the kits.
Sure glad I bought one
Even the owner of the lhs is building one.
Hmmmm .....I wonder whose TA05 those belong to ?
...BK aredi ran his with a 10T, looks like he'll be racing it this coming HPI open challenge race on the 31 July.
Ghostfit is offline   Reply With Quote
Old 07-27-2005, 02:07 AM   #833
B3x
Thanks for the info Hebiki
Old 07-27-2005, 08:23 AM   #834
vi3tishduy's Avatar
Eh, I think Tamiya are out of those shocks. They dont even have any red shocks
Old 07-27-2005, 08:39 AM   #835
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Originally Posted by Hebiki
Get these: #49355
Are those retainers the same anodized blue as the Special Blue ones? I looked for a set but the ones I found weren't the same blue, was a little darker and greyish-blue.
On a side note, I replaced the spur with a Kimbrough 104T 64P, and it runs nice and quiet, unlike my chattering TB-02. I'm getting a 105T as well, and it looks like it'll be exactly the size of the 70T .6 that came with it. I figure just stick to 64P and be able to switch them between my TA05 and Carpet Knife.
Also, Tamiya pinions are pretty expensive ($20CDN for 2) compared to standard ones like Robinson (7.50CDN each). Also I can just pick up any spur, not have to hunt down a Tamiya one. We don't really have metric spurs readily available around here...
Otherwise, my only Tamiya spur options are only the 90/96T Evo IV spurs, and the 102T TRF415.
That setup sheet is great, thanks for posting it. I figure I won't be getting the LW suspension anytime soon, so I changed it to only show the standard TA04 suspension options. I cleaned up some type, added a few things I could use (shimming, body posts, spring preload), and took out some that I really didn't have much use for (front/rear width, suspension mount spacing). It's simplified for the simple, lazy user like me
My original has a colour picture, much nicer looking, but with the upload limitations of the board, I figured I should keep it small...
Tamiya TA05 Touring Sedan-tamiya-ta05-setting-sheet-reg-suspension-small.jpg
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 07-27-2005, 01:44 PM   #836
vi3tishduy's Avatar
What are the advantages of getting a higher t spur gear? Lower accel higher end speed?
Old 07-27-2005, 02:58 PM   #837
vi3tishduy's Avatar
I read on the T1FK05 forumn that 64pitch suited the tamiyas alot better... Maybe i'll switch and choose the 102t 64pitch spur. What pinion would you use for stock?
Old 07-28-2005, 09:19 AM   #838
While awaiting the kit to arrive, I am trying to order some parts so I can add them when I start building the kit. I have a few questions concerning the kit.
1) Does the kit plastic rear hub come with any toe built in?
2) Which 415 suspension mount do I need in order to set rear toe in for 2 or 2.5 deg. using the kit rear hub?
3) To replace the front suspension mount, I will need one 415 type A mount and a 415 type A bridge mount. Is that right?
4) Anyone has the measurement of the required turnbuckles in the kit?
Thanks in advance for your help.
Supra66 is offline   Reply With Quote
Old 07-28-2005, 09:42 AM   #839
rtypec's Avatar
Okay...so I'm building my TA05...interesting build
rtypec is offline   Reply With Quote
Old 07-28-2005, 10:16 AM   #840
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
