Like Tree2Likes
Old 09-22-2007, 06:58 AM   #8371
macnkitty2002's Avatar
I cleaned it up, I rushed it to test it. I would liek to make motor wires shorter but I use the esc in my buggy so I need the long wires.
i know, jk.
installed an XBR on my 05R last night. the unit is just a little too big, so i might need to put it on 1/4 inch risers to clear the "tub wall". or could i just shave down some of the "wall" to get the clearance i need?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 09-22-2007, 10:18 AM   #8372
Josh222's Avatar
Send a message via AIM to Josh222 Send a message via MSN to Josh222 Send a message via Yahoo to Josh222
I used some thick 3m foam tape to clear that little lip in the bottom of the tub.
Hellfire SS
RS4 3 Type SS
TA05R
DF03
M03
RC10GT Black tub
RC10T1/2 Hybrid
Mini-Slider
Super Dog Fighter
Josh222 is offline   Reply With Quote
Old 09-23-2007, 03:27 AM   #8373
aussierevo's Avatar
Trader Rating: 14 (100%+)
seeking some help.....just purchased a new TA05 and running standard running gear 70T spur and 24T pinion with a orion method 17x2. Ran today and after 5minutes motor starts smoking and is really hot to touch. Track I run on is flowing, with a couple of tight sections, but I'm unsure of gearing (spur/pinion combo) to use for this motor, or in fact say a 15T motor that I was thinking of geteting. Can anyone suggest a balanced set-up for someone who doesn't race, and is not going to cause motor to over heat/smoke in the future.
Any suggestions will be appreciated.
aussierevo is offline   Reply With Quote
Old 09-23-2007, 05:06 AM   #8374
why don't you just have two sets of motor wires, one for the buggy and one for the tourer?
DA_cookie_monst is offline   Reply With Quote
Old 09-24-2007, 09:56 AM   #8375
Trader Rating: 37 (100%+)
Does anyone know if any other brand "inner hinge-pins" fit the 05R?
Stock ones bend pretty easy and just looking for options outside of Tamiya
Nexus is offline   Reply With Quote
Old 09-24-2007, 07:10 PM   #8376
pole_position's Avatar
I had the same problem with the TA05R. I found out the main issue lies with the initial design of TA05...
It is design to accommodate the old TA04 arms which are much wider than the LW reversible arms. Look at the nos. of spacers require you will understand... I had swap back those LW rev. arms to the old TA04 arms and no bend hinge pins since...
The old arms are much tougher than the LW arms...
pole_position is offline   Reply With Quote
Old 09-24-2007, 07:43 PM   #8377
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
Default TA05MS DEAL
http://www.rctech.net/forum/showthread.php?t=181788
THE NEW TA05MS AT A AWESOME PRICE!!!!!
twistedone is offline   Reply With Quote
Old 09-24-2007, 07:59 PM   #8378
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
That theory would be plausible IF the same thing didn't happen even worse with the older arms and on the older cars. The arms are just plain strong and when you hit something hard enough...something is going to bend somewhere.
A good friend of mine had a problem bending hinge pins on his Lazer and he cut up an old hex driver (Losi, Hudy, Racers Edge, etc) and used the shaft, It's really hard stuff. You'll probably bend the pivot blocks (BTDT) and or arms then...that's not really cheaper though...so I'm not sure if you'll be better off.
Turbo Joe is offline   Reply With Quote
Old 09-24-2007, 08:33 PM   #8379
really? i've never seen anybody bend their pivot blocks. they seem pretty tough to me, but they are aluminum....
Losi Rock Rey
Old 09-24-2007, 09:54 PM   #8380
Patriiick's Avatar
ooh they WILL bend, they ll actually bend before you break the arm..
ask any 415 owners
Patriiick is offline   Reply With Quote
Old 09-25-2007, 03:07 PM   #8381
maxepower's Avatar
Talking bending hinge pins Raceway!
I also have problems with dots and boards jumping in front of my car so I do bend pins, driver design problem! (Using old style arms)
I found that the old EVO pins fit the 05 and their 50% cheaper. So I bought two sets for the price of one!
Just my2$
maxepower is offline   Reply With Quote
Old 09-25-2007, 10:28 PM   #8382
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Probably the cheapest and most available root is to buy drill blanks from a tool supply store. The diameter for the old arms is 3MM. I don't know about the LW susp. as I have yet to run it. I believe you can get a dozen blanks for around$5 or $6 and cut them to size. They are much harder than the stock hingepins.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 09-25-2007, 10:33 PM   #8383
Turbo Joe's Avatar
They both (STD and LW) use the same hingepins.
Old 09-25-2007, 10:34 PM   #8384
nice.
I ordered TC5 hingepins. They are 3mm diameter but about 5mm longer so you need to cut them also. For about $3.60 you get 4
Old 10-01-2007, 11:21 AM   #8385
waOscar's Avatar
The number of spacers required is so that you can change your wheelbase to suite the type of track you run on.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
