Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 08-30-2007, 06:04 AM
  #8311
Picked up an 05ms about 2 months ago (in japan), and was wondering about the 2 sets of front c's that come with the kit. They're labeled 2rl and 4lr, is the difference in caster or camber?
The MS is great, the only weak points I've found are some of the plastic/carbon in the front end and the aluminum turnbuckles on the front. I ditched the front one-way after the first few laps.
The futaba s9550 is great! Unfortunately, the mamba is too much for the local track here...
grantbaker is offline
Old 08-30-2007, 06:34 AM
  #8312
Registered User
asil's Avatar
They refer to caster values in degrees..
Hope this helps.
Asil
asil is offline
Old 09-01-2007, 01:50 AM
  #8313
RC MARKET's Avatar
Alum. bulkhead
RC MARKET is offline
Old 09-03-2007, 12:48 PM
  #8314
i have 2 05rs looking for anyones setups sheets for rubber tire/asphalt/low grip,looked at this thread only found one on carpet,and 0n pg. 244someone ask but nothing ever answered.if i miss one let me know the page #please.or post it for me thank you
fred71 is offline
Old 09-03-2007, 10:32 PM
  #8315
buboy28's Avatar
Originally Posted by RC MARKET View Post
Alum. bulkhead
how much are those aluminum bulkheads
buboy28 is offline
Old 09-04-2007, 02:44 AM
  #8316
sosidge's Avatar
My basic setup for Asphalt, medium grip was basically kit settings except,
No roll bars
plenty of droop (5 on the gauge front, 3 rear)
Blue Tamiya springs, #450 Much-More oil all round
Seemed to work just fine as a start. Yellow (kit springs) are also OK but can make the car roll a little too much in some corners for my tastes and start to feel a bit sluggish.
sosidge is offline
Old 09-04-2007, 03:13 AM
  #8317
Default asphalt setup
i use white ultra hard springs in the front and blue hard springs at the rear. solved most steering problems. i had a little toe out in the front also. running a tekin g11 pro esc and 10x2t motor. handles very well with a little drag brake set on the esc (:
hottapole is offline
Old 09-04-2007, 10:57 AM
  #8318
guinnes.s's Avatar
would be possible to swap the ta05 chassis with the ta05ms one?would everything else fit back in to it?
thanx
guinnes.s is offline
Old 09-04-2007, 11:08 AM
  #8319
Hebiki's Avatar
Trader Rating: 26 (100%+)
thanx
not possible since the middle bulkhead is different. also the rear belt on the 05MS is shorter than the regular TA05. and the front belt on the 05MS is longer than the regular TA05.
Hebiki is offline
Old 09-04-2007, 11:29 AM
  #8320
guinnes.s's Avatar
so in this case if i buy the ms chassis (top ,bottom),ms motor mount and belts should the rest from the ta05 fit?
Old 09-04-2007, 11:49 AM
  #8321
Hebiki's Avatar
not sure? but by the time you purchase all of those items separately, you might as well purchase the 05MS kit because it'll probably cost about the same as the individual parts combined.
Hebiki is offline
Old 09-04-2007, 12:44 PM
  #8322
RC MARKET's Avatar
http://rcmarket.com.hk/products_new.php?page=3
Old 09-04-2007, 05:42 PM
  #8323
Default Mounting a Mamba Max
Hi all. Just got my TA05 kit in the mail and look forward to getting on with the build.
Any suggestions on how to mount a Mamba Max in the stock tub? I was planning on just sticking it in the chassis at an angle and be done with it until I can afford to grab one of the carbon chassis. The only other ESC I have on hand is an LRP AI that is even bigger than the Mamba
Variable is offline
Old 09-04-2007, 06:30 PM
  #8324
pole_position's Avatar
I had no problem mounting the MM in my TA05. I attached my MM ESC on to a used piece of bumper to raise it higher
pole_position is offline
Old 09-09-2007, 02:21 PM
  #8325
rtherbe's Avatar
Quick question: I usually run a 19t Orion in the Ta05 with the origional gearing, but have recently thronw in a 12t mod motor. The question is what gearing combo should I be running?
rtherbe is offline
