Like Tree2Likes
Old 08-21-2007, 02:55 AM   #8281
Originally Posted by sportssedanman View Post
So it is likely that they will have one weight of shock oil and several spring rates since this is also an "R" kit.
Can anyone who has a TA05-R tell me what I get in kit in the way of shock oils and springs?
i tihnk you get tamiya "soft oil" not sure and i tihnk red white blue and yellow springs
C_Suzuki is offline   Reply With Quote
Old 08-21-2007, 03:08 AM   #8282
Simon K's Avatar
White springs with a dab of yellow on them(med)and 350 wt oil I think. I found it too soft out of the box.
Simon K is offline   Reply With Quote
Old 08-21-2007, 03:25 AM   #8283
sportssedanman's Avatar
Send a message via Skype™ to sportssedanman
Thanks man. I will buy some springs with different rates and a couple of extra shock oils.
sportssedanman is offline   Reply With Quote
Old 08-21-2007, 10:28 AM   #8284
Hebiki's Avatar
Trader Rating: 26 (100%+)
TA05R comes with tamiya yellow oil which is rated as "400". its "supposed" to be equivalent to 40wt oil.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-21-2007, 10:44 AM   #8285
Trader Rating: 16 (100%+)
Originally Posted by raffaelli View Post
I was discussing the TA05 and the TA05IFS this weekend at the track with a few racers. One of them was saying that the TA05 is not competitive foam on carpet. Do you agree?
Depends on who are you racing against.........and how light is your TA05. If you are talking about bone stock TA05 (even TA05R) race against sponcered drivers @ A-main....yes, TA05 should not be competitive to WIN. But I am sure TA05 is capable to HANG with them.....
I am talking apple to apple....this is a touchy question that has 1000 different answers from 100 ppl.
Old 08-21-2007, 11:28 AM   #8286
Trader Rating: 38 (100%+)
Ta05 with Penguin chassis is nice on carpet. Ive seen it hang and beat sponsored drivers (by another sponsored driver)
or8ital is offline   Reply With Quote
Old 08-22-2007, 08:53 AM   #8287
How do I increase ride height using the basic kit?
My chassis is rubbing against the road that I run on and caused a lot a lot of scratches under the car.
techrix is offline   Reply With Quote
Old 08-22-2007, 09:05 AM   #8288
tc3team's Avatar
Tecrix- you will get some C shaped plastic parts on a sprue with the kit, the same size as the shock body, they come on the same sprue as the top mount of the suspension and are of various sizes depending on how high or low you want to make the suspension. You just clip them on the shock body inbetween the top of the suspension (below the screw top joint) and the spring collar.
I think come in 1,3 and 5mm in size with the kit from what I remember.
hope that helps
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-22-2007, 11:07 AM   #8289
pole_position's Avatar
Default Stock TA04 suspension arms?
Hi guys,
My TA05R seem to have bent hinge pins pretty often. Those pins are usually bent at the section where it supposed to stuff in quite a few spacers before the suspension ball end.
It was mentioned in this thread earlier that the stock TA04 arms are much tougher than the LW reversable arms that come with TA05R and the arms take up more of the entire hinge pins with lesser spacers required. I am seriously considering to replace the entire suspension section with the TA04 parts.
Comments? if any...
Appreciated.
Thanks!
pole_position is offline   Reply With Quote
Old 08-23-2007, 04:03 AM   #8290
13Zulu's Avatar
Default TA-05R spinouts
Hi all,
I am relatively new to all of this, and find that my TA-05R with a silver can motor spins out whenever I go around a corner or put on almost full lock.... I have been mucking around with diff tensions etc to try and overcome it, but wonder if anyone has had a similar experience. I am running TO27 tyres???
TT-01....... Ta-05....... TA-05R
HARRIS RC - Matched Packs......
13Zulu is offline   Reply With Quote
Old 08-23-2007, 04:08 AM   #8291
tc3team's Avatar
Tyres are THE most important tuning tool for handling.
If you have the wrong tyres for the place youre using your car, it can very easily spin out,or just understeer. No amount of differential resetting will change that.
All I can suggest you do is take the suspension off each corner and see if each arm is moving up and down freely. If one is jamming up the chances are your hinge pin is bent and needs replacing, that could help things.
If not that, try different tyres and take it from there.
hope that helps
Old 08-23-2007, 09:44 AM   #8292
CSeils's Avatar
Trader Rating: 48 (100%+)
Does anyone know the spring weight compression for Tamiya's super hard and ultra hard shock springs? Which one is stiffer? Where do they fall in with the other spring rates?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 08-23-2007, 10:05 AM   #8293
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Carl,
here is an old chart I have with the spring rates.
Purple (ultra hard) is the stiffest Tamiya spring
Gray (super hard) is the second stiffest spring
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 08-23-2007, 10:12 AM   #8294
tc3team's Avatar
Originally Posted by f1larry View Post
Carl,
Thats a very useful chart, ta However, i've never managed to find out anywhere how hard/soft the kit springs are on the '05. Does anyone know?
Ta
Old 08-23-2007, 11:21 AM   #8295
Ta
If I am not wrong, the silver kit spring falls between the yellow and blue spring.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
