Like Tree2Likes
Old 08-18-2007, 10:39 AM   #8266
pole_position's Avatar
Originally Posted by Aluma View Post
what do you mean by short arms?
Speaking of short arms...
Guys,
I am considering to swap the current reversable LW arms for TA05R back to the old TA04 arms as I found out the LW arms have been bending a couple of those hinge pins
Comments will be appreciated. Thanks!
pole_position is offline   Reply With Quote
Old 08-18-2007, 03:11 PM   #8267
m3ndo5a's Avatar
The shorts are normally found the EVO V... These are a great hop up for any Tamiya chassis....
Tip Off:
If you run short arms in the front and Long arms in the rear your car will get through chicanes alot faster. Its like running narrow suspension blocks!
You will need to make rear grip adjustment...
m3ndo5a is offline   Reply With Quote
Old 08-18-2007, 03:39 PM   #8268
macnkitty2002's Avatar
how often should i take out my diffs and inspect/clean/relube them? my car has been run about 25 times, mostly on carpet.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 08-19-2007, 05:59 PM   #8269
m3ndo5a's Avatar
Some upgrades
I decided to go with the Aluminum Bulkhead, because it easier to work on. Plus you can lower the diff height for more added traction.
I got the Tech Racing Pulley to Lower the IR.(1.944 with Black TRF Pullies)
Ofcourse all of this ramp up the Price of the TA05R....But I like this car alot so its worth the Investment.
Somethings to think about.
Tamiya TA05 Touring Sedan-mre-ta05-077.jpg   Tamiya TA05 Touring Sedan-mre-ta05-078.jpg   Tamiya TA05 Touring Sedan-mre-ta05-079.jpg   Tamiya TA05 Touring Sedan-mre-ta05-076.jpg
Old 08-19-2007, 08:38 PM   #8270
i usually do mine after every race day but thats just me i guess it depends what kind of motor your using and how many times in a day you run
C_Suzuki is offline   Reply With Quote
Old 08-19-2007, 10:54 PM   #8271
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by m3ndo5a View Post
Some upgrades
very nice i also like those aluminum bulkheads BTW those bulkheads when you bought it does those include the front and rear as a set or i have to buy 2 sets 1 for the rear and 1 for the front and where did you buy those our LHS still have none of those bulkheads, thanks
buboy28 is offline   Reply With Quote
Old 08-19-2007, 11:43 PM   #8272
can you run the evo V steering on the ta05????
Old 08-20-2007, 12:53 AM   #8273
HI_808's Avatar
If you have an aftermarket carbon chassis, then it might be possible. Otherwise, I am pretty sure it will only work on the TA05MS because the tub chassis doesn't allow a steering setup as low as the TB Evo V to be mounted on it.
HI_808 is offline   Reply With Quote
Old 08-20-2007, 02:02 AM   #8274
Xanavi_R34's Avatar
The built of the ta05 (tub chassis) is different compared to the ta05ms or the after market chassis... So if you're planning to change your steering to like the evo IV's steering arms and link... Then I might as well tell you to get the steering set of the ta05 (tub chassis) instead... This is like almost the same because it is aluminum and has ball bearings already for steering... But if you have, what HI_808 said, then it could fit maybe... But for me, I am not sure about it though...
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-20-2007, 02:44 AM   #8275
buboy28's Avatar
if you have the tub chassis then the answer is NO if you have the MS version then the answer is YES
Old 08-20-2007, 06:58 AM   #8276
sportssedanman's Avatar
Send a message via Skype™ to sportssedanman
Does the TA05-R come with one weight of shock oil and four springs of the same rate or does it come with several weights of shock oil and several spring rates?
sportssedanman is offline   Reply With Quote
Old 08-20-2007, 07:02 AM   #8277
Xanavi_R34's Avatar
Tamiya always gives only one weight of shock oil and four springs of the same rate in their kits... But my first experience of having a one weight shock oil and three pairs of different spring rate is in the M03R... It comes with the soft, medium ad hard with the white coated springs...
TAMIYA TRF416
Old 08-20-2007, 07:55 AM   #8278
raffaelli's Avatar
I was discussing the TA05 and the TA05IFS this weekend at the track with a few racers. One of them was saying that the TA05 is not competitive foam on carpet. Do you agree?
24ITA
raffaelli is offline   Reply With Quote
Old 08-21-2007, 01:56 AM   #8279
tc3team's Avatar
I cant speak for running the stock chassis, as I run a double deck graphite chassis, but I have no problems at club level getting in the A on foams, the car felt dialled on them uber grippy, the back end would not snap out under full acceleration one bit.
The stock chassis is a bit heavier and more flexible, but I cant see it making a huge difference.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-21-2007, 02:43 AM   #8280
So it is likely that they will have one weight of shock oil and several spring rates since this is also an "R" kit.
Can anyone who has a TA05-R tell me what I get in kit in the way of shock oils and springs?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
