Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 08-04-2007, 03:11 PM
  #8206
Originally Posted by ittjv View Post
I was planning on making my own. This sounds dumb but, if you stick it to the pulley and the outdrive, how is the outdrive supposed to spin?
gerok is offline
Old 08-05-2007, 01:23 PM
  #8207
has anyone tried to fit maxamps lipos in there car, just wondering how they fit
C_Suzuki is offline
Old 08-05-2007, 01:39 PM
  #8208
HI_808's Avatar
It doesn't really stick to the outdrive. It sticks to the pulley and sort of just covers the outdrive. I agree, those stickers work very well to keep diffs from getting gritty.
HI_808 is offline
Old 08-05-2007, 05:12 PM
  #8209
over gear's Avatar
Trader Rating: 16 (100%+)
can anyone tell me the part number for the TA05 Swaybar set with lightweight suspension? thanks
over gear is offline
Old 08-05-2007, 07:51 PM
  #8210
Default Tasmiya Shocks
Guys ,
I nedd some helpo mounting my TRf shocks on my Yokomo. I have the TRF "black shocks," But i dont know what size ball stud they use.
Secondly Is this Tamiya part the correct ball stud that has a 3 mm thread all the way through?
http://www.precisionrc.com/nv/car/pr...oduct_id=27480
Thanks for you help
Simon
Bluey_74 is offline
Old 08-06-2007, 12:18 AM
  #8211
peejay's Avatar
Tamiya ball connectors/nuts for shock mounting are 5mm.
Your link shows a 3Racing part. It should be threaded 3mm but...
I have been caught out in the past through buying third party parts for Tamiya, now I only buy parts identified by Tamiya part numbers.
HTH
peejay is offline
Old 08-06-2007, 03:08 AM
  #8212
sosidge's Avatar
Tamiya's 5mm is the same as the other Japanese manufacturer's 4.8mm.
If you want a ball with a 3mm hole in the middle try Kawada #AJ4802N, I am using these to mount my shocks and am very pleased, better fit than the Tamiya ball and do not wear when you remove the shocks.
sosidge is offline
Old 08-06-2007, 05:23 AM
  #8213
Thumbs up
To Peejay and Sosige,
Thanks alot for your help. Much appreciated
Simon
Bluey_74 is offline
Old 08-06-2007, 09:20 AM
  #8214
macnkitty2002's Avatar
do the ball cups on the car ever get any easier to pop off as the car gets older? i was trying to get off the shocks from the ball studs and they are hard as sh!t to get off! i had to pry them off with a flat head screw driver and managed to scratch the ball stud a little.
macnkitty2002 is offline
Old 08-06-2007, 02:07 PM
  #8215
what si the internal ration of the ta05?
C_Suzuki is offline
Old 08-06-2007, 02:09 PM
  #8216
Core Creations's Avatar
Trader Rating: 105 (100%+)
Core Creations is offline
Old 08-06-2007, 02:21 PM
  #8217
thanks, and does anyone has a good 19t setup for a medium to large track?
C_Suzuki is offline
Old 08-06-2007, 05:43 PM
  #8218
Hey guys, after a brief foray into TC, I decided to run 1/8 buggy, so Im getting rid of my basically brand new ta05R, REALLY cheap:
http://www.rctech.net/forum/showthre...60#post3555560
This is a great way for someone new to TC to get in cheap Tell your friends!
Frost99999 is offline
Old 08-07-2007, 12:25 PM
  #8219
Ridge_Racer's Avatar
I would like to know as well. My local track is free flowing with a few hairpin and "S" turns. The back strait is very long and the track is slippery do to no grip.
My TA-05 keeps oversteering on power. I have already soften the shocks in the front and the rear by moving them in toward the middle. I will be trying softer springs next.
Any other tips would be great.
thanks
Ridge_Racer is offline
Old 08-07-2007, 03:03 PM
  #8220
HI_808's Avatar
Using zero degree rear uprights and more toe in at the hinge pins will give more traction at the rear wheels.
HI_808 is offline
