Like Tree2Likes
Old 08-02-2007, 08:38 AM   #8191
Trader Rating: 37 (100%+)
Originally Posted by Xanavi_R34 View Post
Hey guys, can anyone help me with my ta05 problem??? there is this sound that bothers me... before I ran the kit, whenever I press the throttle and let the wheels spin on air (when I'm carrying the kit), the motor or the sound is nice, it's like whistling but after few rans, suddenly it's not like it used to be, whistling... so what could be the reason behind??? it sounded like somewhere in the center, not front nor rear and checked the ball diffs, nothing is in their way... cleaned the motor, nothing is also in the way for now... still the sound is occuring... Hope someone can help me...
Is this your first TA05 or do you have another to compare it too? The car is just loud. When I first ran mine I thought it was broken but it's was not. The car is just way louder then other cars. I think it has to do with the sealed diff boxes and the layout.
As long as it's not binding it should be fine to run the car.
Nexus is offline   Reply With Quote
Old 08-02-2007, 08:41 AM   #8192
Xanavi, try a different motor, mine is whisper quiet all the time, spur and pinion that comes with Tamiya kits are junk too.
DA_cookie_monst is offline   Reply With Quote
Old 08-02-2007, 09:04 AM   #8193
Xanavi_R34's Avatar
what do you mean by first??? yes it is my first ta05 and last ta05 but I dont have another ta05 to compare with it... But before I test the kit, it was whistling but then after few packs, then I just noticed it was noisy...
Will try changing the motor if I have time to do so... but for now, school papers first... haha...
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-02-2007, 09:14 AM   #8194
The TA05 is as quiet as any other belt drive out there, and if the noise has only just started, it won't be the belt, it is either the spur/pinion, even the mesh is worse checking, or the motor.
Old 08-02-2007, 09:18 AM   #8195
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I had an annoying noise like that before, turns out it was one of the bearings holding the spur shaft.. I guess a rock flew between the spur and the mount, pushing the shaft to one side and dinged up the bearing in the process..
Now on the spur shaft I use a piece of silicone tubing to fill the gap instead of a solid spacer. I put a shim on the end so the silicone doesn't provide any resistance when it rubs the side.. It's solid enough to keep things from shifting, but will absorb any shock to spare my bearing should the same thing happen again.
Jam-ehz is offline   Reply With Quote
Old 08-02-2007, 10:37 AM   #8196
Xanavi_R34's Avatar
thanks for the help guys... will update you if I found and solved the problem...
TAMIYA TRF416
Old 08-03-2007, 07:58 AM   #8197
TMHippo's Avatar
Any of you out there that have the Penguin upgrade for the TA 05, could you share some of your set up secrets. I have just gotten this chassis and want to head off any headaches early.
Thanks Rodney
TMHippo is offline   Reply With Quote
Old 08-03-2007, 11:37 AM   #8198
Anyone interested in a brand new Kawada TA05 upgrade kit PM with. It also includes the shock tower upgrades
DOTMAN is offline   Reply With Quote
Old 08-03-2007, 06:28 PM   #8199
macnkitty2002's Avatar
i just spent three days running on a carpet track. after putting it on a setup board and making sure everything was the same, i put it on the track. i chased a steering servo problem for two days, and i used process of elimination to figure that the servo itself was just shot. i ran all day today and was clearly the fastest on the track, with a box stock setup! pretty cool schooling guys at their own track with a tub chassis against sponsored Xray drivers.just used a DNA2 body and CS27s with PGFXII traction compound.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 08-03-2007, 07:15 PM   #8200
m3ndo5a's Avatar
Anyone interested in a TA05R MoNsTer LMK. Fully Loaded! But Hun labor doesn't come cheap......
PEACE
m3ndo5a is offline   Reply With Quote
Old 08-03-2007, 07:59 PM   #8201
Being that TA05 diffs are fully open to dirt and dust, I read somewhere about putting a sticker to keep it clean. Anyone have an idea where to get these 'stickers?'
gerok is offline   Reply With Quote
Old 08-03-2007, 08:40 PM   #8202
Trader Rating: 31 (100%+)
It's these, and they work GREAT!
http://cgi.ebay.com/Tamiya-Ball-Diff...QQcmdZViewItem
ittjv is offline   Reply With Quote
Old 08-03-2007, 08:47 PM   #8203
cranky's Avatar
mine (ta-05 rtr)is quite noisy at the first but run smooth after i burned the motor and put grease on some moving parts.
cranky is offline   Reply With Quote
Old 08-03-2007, 09:49 PM   #8204
bukil's Avatar
Trader Rating: 39 (100%+)
Do you guys think 100spur and 45pinion will fit in the 05? I was told to gear a 10.5 brushless motor to 5.0 FDR. Any help would be greatly appreciated.
Mark
bukil is offline   Reply With Quote
Old 08-04-2007, 12:33 PM   #8205
Dan the Man's Avatar
Trader Rating: 40 (100%+)
YGPM
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
