Like Tree2Likes
Old 07-23-2007, 06:14 PM   #8146
macnkitty2002's Avatar
I'd say you should keep it under 180 degrees F(& that would be pushing it a little bit, but it can stand that), & you should always try to base your gearing on how it tops out on the longest straight(try to get it to top out about 80-90% of the way down it), & then make small adjustments from there. Oh, & DEFINITELY use a "real" 64 pitch spur if you're using real 64 pitch pinions.....
thanks. i am using a real 64 pitch spur now, though it's a 104 tooth. i still need to go higher with my gearing, only 1 or two teeth though. running great so far though.
how can i determine if my diffs need to be tightened up?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-23-2007, 08:10 PM   #8147
Super Moderator
Grizzbob's Avatar
Well, I've always done it(with ANY car I've run) by holding the front or rear tires still & try to turn the spur(just do one end of the car at a time). If you feel the spur slip much, then the diff on that end is too loose. So you tighten it a bit more & then try again until you can just BARELY move the spur(if at all, personally, I still allow a TINY bit of slip, but that's a matter of preference & it just takes time & practice to get the feel for it).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-23-2007, 08:56 PM   #8148
i jsut got a ta05 and was wondering how people mounted there mamba max esc?? it is the original ta05
C_Suzuki is offline   Reply With Quote
Old 07-23-2007, 11:57 PM   #8149
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
You'll have to cut the chassis in the stock version. I tried to mount mine. Or you can mount it at an angle.
minijosh is offline   Reply With Quote
Old 07-24-2007, 12:10 AM   #8150
can you post a pic?
Old 07-24-2007, 03:19 AM   #8151
Originally Posted by |JayFlores|2 View Post
thanks DA_cookie, i will definitely try this soon rear toe is roughly how many deg of toe in? and what brand of damper springs are u using?
They are the stock wishbones, as they are far more resiliant to indoor racing, so it is 2' on the hubs and 1' on the blocks giving you 3' total toe IN.
The springs are Kit silvers and Tamiya blue normal length on the back, I also run about 20g of weight in the rear just to weigh it down a little as it would get a little slidey back there. It turns great on that setup with a centre one-way, a front one-way was just to much work indoors and to hard to drive cleanly as the last thing this car needs.... is more steering...
DA_cookie_monst is offline   Reply With Quote
Old 07-24-2007, 07:01 AM   #8152
Rubber tire on Carpet setup....
I run the TA05R setup as per the kit build instructions with the following exceptions:
Carbon chassis and carbon fiber shock towers
Tamiya B3 or TakeOff CS27 tires
40wt front and 30wt rear shock oil
Front one-way
5mm ride height all the way around
Droop 2mm front and 3mm rear (both above ride height)
This setup gives me slight on power understeer. The car is very easy to drive. I'm going to try .5deg less rear toe and see if it turns a little better.
With a Sport Tuned (black can) we have managed to get lap times within about .5 secs of the average 19T cars at our small indoor carpet track.
qwkpony is offline   Reply With Quote
Old 07-25-2007, 07:25 PM   #8153
Is there some sort of magic trick that makes one of the servo savers included in the TA05R kit actually fit onto any of my JR or aitronics steering servos? I have 2 JR's and an old airtronics and all of the servo saver holes are too small for the servo posts.
I rigged up one out of the included white servo cam thingies and the servo saver arm for tuning and intitial runs, but actually running on a track with no servo saver is obviously a bad idea.
Anyone have this issue, or am I missing something really obvious?
Frost99999 is offline   Reply With Quote
Old 07-26-2007, 02:55 AM   #8154
I went from running a servo saver and having centralisation problems and the saver breaking to running none with steel gears and alloy servo horn, far better.
Old 07-26-2007, 08:17 AM   #8155
Default Mamba Max in TA05
I just mounted mine on end and zip tied it in so that it would not go anywhere. It doesn't look pretty, but I haven't had any trouble with it. I haven't cut the chassis or anything like that.
cutwo is offline   Reply With Quote
Old 07-26-2007, 01:28 PM   #8156
So you have a JR racing servo, or one that the stock kit doesnt fit? Mine has a plastic post, its just too big to fit into any of the holes in the stock kit. I really had a lot of issues getting this servo in place, so I dont want to switch if I cant help it. Im just afraid of running it without a servo saver, because I tapped a curb with my current setup and it popped apart pretty easily. I would REALLY like it to work like its supposed to...:\
What brand of servo are you using? Mounting it on its side sounds like it would work if the servo was too big, but thats not my problem...
Old 07-26-2007, 05:00 PM   #8157
This may sound like another stupid question, but what is the advantage of a carbon fiber chasis? Is it lighter, stiffer, stonger, more adjustable?
Also, can you mount the aluminum bulkheads from a 415 on a Ta05?
tom
tsyrc is offline   Reply With Quote
Old 07-26-2007, 05:19 PM   #8158
Hebiki's Avatar
Trader Rating: 26 (100%+)
tom
415 bulkheads will not fit/work on the TA05. Tamiya will be releasing alum. bulkheads for the TA05. i think its out this month or next.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-26-2007, 05:21 PM   #8159
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
The aluminum bulkheads from a TRF415 will not fit on to a TA05.
But there are after market and Tamiya hop-up part number 53990 when it becomes available.
rctouringracer is offline   Reply With Quote
Old 07-26-2007, 05:37 PM   #8160
AWK
AWK's Avatar
It sure will look pretty, but will it be worth it?
AWK is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
