Like Tree2Likes
Old 07-21-2007, 08:04 PM   #8131
macnkitty2002's Avatar
Where did you come up with the 4.0 FDR. 26 pinion would put you at 9.0 FDR? You forgot to multiply the variable into the formula!
sorry, i looked at that robinson racing link someone posted and they said to do it spur divided by pinion to get the FDR. guess i was mistaken.
i think i will use the actual 64 pitch 104 tooth spur gear i have because when i ran my car for the first time today, although the gear mesh was fine, it still felt "stiff" and did not roll smoothly. i will also install the 30 tooth pinion as my top speed was not up to par with what a stock motor should be at my track. i might need to get a motor heat sink though because it was getting a little warm. but i really don't know how warm it can get before i should pull it off the track. i have a temp gun, but can anybody tell me what kind of temp i should be running at maximum with 4200s, 30t pinion and a CO27?
thanks
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-21-2007, 10:36 PM   #8132
Super Moderator
Grizzbob's Avatar
thanks
I'd say you should keep it under 180 degrees F(& that would be pushing it a little bit, but it can stand that), & you should always try to base your gearing on how it tops out on the longest straight(try to get it to top out about 80-90% of the way down it), & then make small adjustments from there. Oh, & DEFINITELY use a "real" 64 pitch spur if you're using real 64 pitch pinions.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-23-2007, 06:24 AM   #8133
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
has anyone tried using the ta05 on carpet using rubber tires? I am in need of a base setup to work on. Thanks!
|JayFlores|2 is offline   Reply With Quote
Old 07-23-2007, 07:13 AM   #8134
tc3team's Avatar
Cant think what page it is on, but there has definately been one posted up on this thread that should help LRP Vtech tyres are pretty consistant for grip indoors.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-23-2007, 07:28 AM   #8135
okay thanks il just browse around.
but if any1 has a base setup that they want to share please hit me up.
thanks
Old 07-23-2007, 08:04 AM   #8136
Here is my setup, 19t, indoor, carpet, rubber and additive.
DA_cookie_monst is offline   Reply With Quote
Old 07-23-2007, 10:16 AM   #8137
Hebiki's Avatar
Trader Rating: 26 (100%+)
Cookie monster.. did i read your set up right... you have POSITIVE toe out in the rear? or is that a typo and it should be -1 toe in?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-23-2007, 10:44 AM   #8138
Originally Posted by Hebiki View Post
wow Solara.. how small is the track that you're running on? 7.5 for a stock motor. must be a tiny track.
we gear our CO27s in the low 6s out here. then again, not everybody gets to run on the Tamiya track.
we gear our 23Ts in the mid 5s. 5.3-5.6
Yupe...not everyone can run the TAMIYA track every sat, but I am sure you won't be able to run that track for long...so enjoy it. We do have a 1/8th track that is 10 times better then the Tamiya track but running stock or even 19T motor at that track is like watching paint dry....so we did 7700 and or 3.5/4.5 with foams/lipo instead...ALL OUT.
My TA05R using manuel setup was pretty good with rubber (stock) and even foams...however, just cannot run against the top rank car (007, Losi, Mi3...etc) for some reason (weigh, equal belt..etc). I have tried several setups and it just does not get that 1/2 sec or so more............that equal belt design might have something to do about that.
Between 7-7.5 is about right for our track...like 80 x 120...3 rolls of parking spaces parking lot style....the killer part is, all the turns are 90 or 180 degree formed by 2x4s...and they are all painted YELLOW, now....along with the parking stripes are all painted yellow and they look EXACTLY the same as the board....our challenge is...figure out which one is the board and which one are the lines...........the penalty, broken arms and DNF....
Old 07-23-2007, 11:21 AM   #8139
no, not a typo, I run the 3Racing blocks, so at the rear, I am running a +1 block, which is a wider block, and it increases the rear toe... confusing I know, sorry.
Old 07-23-2007, 02:37 PM   #8140
But no matter that is + or -, are you still running TOE-IN? I have never seen anyone run TOE OUT especially at the rear of the car...
If I am the one to write it...I will simply say TOE IN or TOE OUT 1 degree...
Old 07-23-2007, 02:48 PM   #8141
It was written for my info, so the rear block is wider, and is marked +1, but in reality you are increasing the Toe in, not making toe-out.
Old 07-23-2007, 03:18 PM   #8142
Thats relieving, I was still trying to figure out how rear toe out could possibly help...
Anyone know off the top of their head what degree toe in the rear blocks that come with a TA05R are set at? I think its 1 degree but Im not sure.
Frost99999 is offline   Reply With Quote
Old 07-23-2007, 04:09 PM   #8143
HI_808's Avatar
The stock 05R setup uses an A block for the front rear and a D block for the rear rear for a total of 1.5 degrees of toe in at the hingepin. The stock rear upright has 1 degree of toe in built, giving 2.5 degrees of toe in total.
HI_808 is offline   Reply With Quote
Old 07-23-2007, 04:19 PM   #8144
Thanks!
Old 07-23-2007, 04:47 PM   #8145
thanks DA_cookie, i will definitely try this soon rear toe is roughly how many deg of toe in? and what brand of damper springs are u using?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
