Like Tree2Likes
Old 07-20-2007, 03:57 PM   #8116
Trader Rating: 16 (100%+)
Originally Posted by macnkitty2002 View Post
haha, one last question.how do i determine whether or not my belts are tight enough? once i have broken them in, i know i will need to retighten them (going on what everybody has said). should they be tight enough so that they still give a little when i press down in them, but yet loose enough so that they do not bind up the drivetrain? i have little experience with belt driven cars, so any help will be appreciated by this EP TC noob.
Well, it is very obvious when you tighten the tension by 1 notch, you can feel it is too tight....then back that off 1 notch, and thats it...nothing you can do about it. My TA05R feels like too loose all the time (too loose to my taste at least) but never skip a tooth.....if you still want to adjust the tension, you must add a optional external belt tensioner that has a arm with bearing that can press the belt down for more tension. It should be pretty easy to do that. But I don't think that is necessary....belt tensioning is not a big issue on TA05R.
does anybody on here run lipo batteries in their car? is it necessary to have a lipo voltage cut-off module in the car, or can i just take it off the track and charge it once the battery dumps? i have lipos for my other mini cars, and i can easily see when the pack dumps and it is time to charge. since i'll be getting a lipo for my 1/10 TC now, i did not know if i needed one or are they just for the complete dummies...
this is what i was looking at.
http://www2.towerhobbies.com/cgi-bin...?&I=LXPGM8&P=M
Yes...if you need to add one, the NOVAK one is the best. I ran Lipo 3200/4800 on my TA05R indoor, outdoor, stock 19T and 4.5......never used the LIPO cut off....cause I bring the car back all the time after qualifier or race. And at practice, I don't run it more then 6-7 minutes...no reason to run the car untill it is dump, why take the chance when you don't have the lipo cut off.
Old 07-20-2007, 04:19 PM   #8117
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Solara View Post
I ran 7.5 to 8 FDR on 27T motor (CO27).....for 23T, you can try between 7-8 FDR.
wow Solara.. how small is the track that you're running on? 7.5 for a stock motor. must be a tiny track.
we gear our CO27s in the low 6s out here. then again, not everybody gets to run on the Tamiya track.
we gear our 23Ts in the mid 5s. 5.3-5.6
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-20-2007, 05:10 PM   #8118
macnkitty2002's Avatar
i have all the gear together for my ride, i just need to paint up the body and wait for my tires to arrive. when i am try to find some mounting holes for my DNA2 body, i noticed that the wheelbase is rather short for the body. should i try to center the wheels with the center of the body, or center the front wheels only since they are the ones that need to have proper wheel clearance since they steer?
also, i saw that my rear belt rubs on the stock cast motor mount just before the belt wraps around the center pulley. i probably did not see this before, but as far as i know i have built everything correctly. does anybody else's rear belt rub a little bit on their motor mount? is this something to be concerned about?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-20-2007, 05:39 PM   #8119
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
I set-up the car the way that I want it to sit than I cut the body around the car not the other way around. Is that right?
rctouringracer is offline   Reply With Quote
Old 07-20-2007, 06:49 PM   #8120
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
so if i use a 48 pitch spur gear, it doesn't have to have 105 teeth to be equivalent to a 64 pitch 105 tooth spur gear? do the gears just have to be the same diameter to be equivalent?
i'd just like to stick with 48 pitch because the pinions are cheaper and i can get them in 5 gear packs from Robinson.
Here is an explanation. Also tells you how to convert from 48 to 64 or 64 to 48. http://www.robinsonracing.com/tips.html
minicooper is offline   Reply With Quote
Old 07-20-2007, 09:45 PM   #8121
Super Moderator
Grizzbob's Avatar
There are a lot of different sizes of track out there, my local track is that small, & those of us who run brushed stock motors do gear theirs(mostly CO27's) at around 7.3 FDR, so that could be about right for Solara, too....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-20-2007, 09:59 PM   #8122
Default Gearing
Yep I'm geared right now at 7.8 in stock with a CO27 on a 100 by 50 foot track. Temp gets up to about 170 F which is a little warm for my liking, but trying to keep up with the brushless guys.
How hot do people run there stock motors by the way?
cutwo is offline   Reply With Quote
Old 07-20-2007, 10:00 PM   #8123
maxepower's Avatar
Default Bending corners gearing?
Chris,
What would you get a cobalt and a 23 turn at Bending Corners?
Max
P.S. Maybe I should go on Bending Corners thread!
maxepower is offline   Reply With Quote
Old 07-20-2007, 10:15 PM   #8124
i have not yet run my car yet, i'm just waiting on some tires. but i have no idea what kind of gearing i should have for a smallish parking lot track (about 75 feet by 55 ft). i will be running the stock 105 tooth spur and i am going to try a 26 tooth 64 pitch pinion on a CO27 pro stock. my FDR will be close to 4.0, but i'm guessing my pinion is going to be too big for the track. i've got a 19t, 23t, 26t, and a 30t for now (i really had to guess and buy a few pinions to start off).
Losi Rock Rey
Old 07-20-2007, 11:34 PM   #8125
Simon K's Avatar
Buy a proper 64 pitch spur, the Tamiya one in the kit is not the same. It won't mesh as smoothly(close but not quite). There's plenty of discussion in this thread about mixing whatever it is module/64 and 48 pitch gears..in general, don't do it.
Simon K is offline   Reply With Quote
Old 07-21-2007, 12:52 AM   #8126
maxepower's Avatar
Lightbulb FDR?
(105/26 = 4.038 x 2.25 =9.08)= calculation for FDR on TA05
I would start with the 30 tooth pinion which would put you around 7.875 FDR.
Where did you come up with the 4.0 FDR. 26 pinion would put you at 9.0 FDR? You forgot to multiply the variable into the formula! All cars have different variables depending on the number of teeth of the pulley and the center pulley. For example the TA05 pullies are 36 teeth and the center pully is 16, So 36/16= 2.25
Based on the size of you track I would say 8.0 FDR might be closer to what you want. The motors RPM's should max out just before the end of the straightaway.That should get you close to your best FDR on the track!
Just my2$
Old 07-21-2007, 02:13 AM   #8127
Xanavi_R34's Avatar
Just my2$
It think he used a 105(spur)/56(pinion)... is this R/C car-ly impossible???
Xanavi_R34 is offline   Reply With Quote
Old 07-21-2007, 02:43 AM   #8128
dOM91's Avatar
Exclamation
hey guys,
we use 23T high torque motors (Orion Katana), the others tend to run on FDRs around 5.9 - 6.3, so which pinions and spurs will work best?
Also, does anyone know where i could get setup sheets for a TA05 or TA05r?
thanks
Dom
-Victoire ou défaite, on est toujours fiérs-
dOM91 is offline   Reply With Quote
Old 07-21-2007, 03:19 AM   #8129
Xanavi_R34's Avatar
Originally Posted by dOM91 View Post
hey guys,
thanks
Dom
what spur are you using??? if it is 105t then 38 pinion - 40 pinion...
Old 07-21-2007, 06:13 AM   #8130
HI_808's Avatar
hey guys,
thanks
Dom
http://www.tamiya.com/english/rc/manuals.htm
Look in the right hand column.
HI_808 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
