Like Tree2Likes
Old 07-05-2007, 09:03 PM   #8011
macnkitty2002's Avatar
i pre-compressed my diff springs and it made it easy to install. they are not flattened, i just crushed them about 1.5mm. that made it possible to install them.
the build it going pretty well so far. just finished the shocks (which by the way has been the easiest and most efficient shock building time i have ever had). however i found a problem. the right front inside steering tie-rod ball cup is rubbing on the front "chassis brace" where it flares up to clear the rods. the left side is clear, though only by a little bit. when i turn the steering bellcrank to the right, the right inside ball cup gets caught on that flared part (on the underside of it). do you get what i mean? is it just a matter of having to dremel out some material, or is that threatening the integrity of the front end?
thanks
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 07-05-2007, 09:39 PM   #8012
when installing the steering servo, the instructions say to cut away some of the chassis to allow the servo horn to rotate completely. do i just cut away down to the bottom of the chassis, or go all the way through?
Losi Rock Rey
Old 07-05-2007, 11:18 PM   #8013
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I've never had to compress any of my diff springs. I just use a larger hex driver (2.5 or 3mm) to hold the nut assembly down a little and they go right together, no problem at all.
Turbo Joe is offline   Reply With Quote
Old 07-06-2007, 12:02 AM   #8014
HI_808's Avatar
thanks
My friend just had the same problem with his TA05 (I think at least). Going by your description of the problem, if you look closely at the steering assembly, you should notice that the right side of the steering plate (part K2) is pushed a little forward in comparison to the left side.
What caused his problem was that he did not install the right side bellcrank arm (part K7) the right way. From the center where the arm rotates, the side which connects to the servo is a little longer. If you install the arm upside down and backwards like my friend did, it will cause the cup to rub against the under side of the front brace.
An easy way to tell if you installed K7 properly is to look for a little dot facing up slightly in front of where the steering rod ball cup connects to it. If you do not see the dot, then it probably is upside down. In step 20 of the TA05R manual, you can vaguely see the dot I am referring to.
Ken
HI_808 is offline   Reply With Quote
Old 07-06-2007, 02:47 AM   #8015
sosidge's Avatar
Avoid cutting the chassis.
Old 07-06-2007, 02:50 AM   #8016
sosidge's Avatar
The spring will be compressed the first time it is installed in the car anyway so I don't see why people are getting all stressed about giving it a squeeze with some pliers to make assembly easy.
Old 07-06-2007, 05:59 AM   #8017
Jpelosi's Avatar
I had to cut a very narrow slot on my chassis to allow full movement of the steering assembly. I only went down to the first reinforcing rib on the side of the chassis, maybe .09" or so deep by .063" wide. By not hacking away at the reinforcement area you are not really affecting the structural integrity of the chassis. If you need more, trim the horn on the servo saver to give you the rest of the clearance you need. Just make sure you give enough clearance for the servo saver to do it's job in case you tag a wall with the wheels turned.
The Kyosho method of integrating the servo saver into the bell cranks would have been a nice feature on this car, given that space for the electronics is at a premium.
Jim
Jim
Jpelosi is offline   Reply With Quote
Old 07-06-2007, 09:12 AM   #8018
Turbo Joe's Avatar
Because it really can't get much easier to install than it already is. It just drops right in perfectly if you assemble it the way they say to.
Old 07-06-2007, 10:44 AM   #8019
2 quick and stupid questions:
1 - where can I get Tamiya .04 pinions besides Tower Hobbies (they are out of the ones I want) and dinball? I checked speedtechrc and tamiya america, no dice.
2 - is it Tuh-me-uh, or tuh-my-uh?
Told you they were stupid :P
Frost99999 is offline   Reply With Quote
Old 07-06-2007, 10:50 AM   #8020
RandomFellow's Avatar
My favorite Tamiya (Tuh-me-uh) shop is RC Champ. There is no online ordering, but if you fill out the order sheet with the part number, etc. and email it, they will get back with you right away. Price will be in Yen, but you can pay in Yen through PayPal.
Another favorite (besides RCMart a/k/a Dinball) is RC Mushroom.
There are others, but these are my favorites.
RandomFellow is offline   Reply With Quote
Old 07-06-2007, 01:53 PM   #8021
Thanks! Are there any others in the states?
Old 07-06-2007, 02:59 PM   #8022
i'm sure that's exactly what i did, put it on the wrong way. i'll go check right now. thanks.
Losi Rock Rey
Old 07-06-2007, 08:44 PM   #8023
Regional Moderator
Darkseid's Avatar
Any one looking for a Fully Loaded TA05, mine is going to finish selling in a few hours on ebay. The reserve is low, so act soon if you want a really nice car.
Just search for TA05 and you'll find it.
TLR 22...Tamiya F104...
Old 07-06-2007, 10:26 PM   #8024
maxepower's Avatar
Just switch to 64 pitch! Spurs and pinions will be more available at your LHS!
maxepower is offline   Reply With Quote
Old 07-07-2007, 09:22 AM   #8025
TMHippo's Avatar
Hi
Does anyone has setups for asphalt with foam tires. where i race they only use foam tires. I looking for suspencing settings mainly. Thanks
Rodney
TMHippo is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
