Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 07-01-2007, 07:53 AM
  #7951
Myker*'s Avatar
Originally Posted by DA_cookie_monst View Post
totaly incorrect, although they are very VERY similar, Tamiya supply .4module pitch gears with the TA05R, which is obviosly METRIC. 64dp is an imperial measurement, they are not they same, not to be confused as the same either. You run either one or the other, never a mix.
sorry, but i was referring to .04 as being called 64 metric, just like you would see in this tower description for .06 http://www2.towerhobbies.com/cgi-bin...?&I=LXEX46&P=7
Myker* is offline
Old 07-01-2007, 08:10 AM
  #7952
I am having problems with the 49.7mm Titanium Coated Suspension shaft, it looks like that it does not take a small impact at all, however, the stock suspension shaft seems to be stronger. Do anyone have this problem?
trf_racer is offline
Old 07-01-2007, 11:47 AM
  #7953
Had the same problems with the Titanium coated pins aswell. Not bent a steel one yet
davetamiya is offline
Old 07-01-2007, 11:52 AM
  #7954
What an awefull description... thats like saying a 3mm 12mm length machined screw is a metric 4-40 1/2, it isn't, it will never be and is wrong..... The pinion on display is a .5Module and although you can get away with running 48dp, it will munch your spur gear.
DA_cookie_monst is offline
Old 07-01-2007, 11:54 AM
  #7955
As far as im aware in the uk Tamiya series most of us run 64dp pinions with tha tamiya .04pitch. I have been since ive had the car and not had a problem. From what ive been told the difference is very minimal
Old 07-01-2007, 12:52 PM
  #7956
Thanks for your input! I will use the steel ones from now on.
Old 07-02-2007, 09:29 AM
  #7957
Trader Rating: 17 (100%+)
I have to agree....they are very very very very very very close...but if you do have the Tamiya 0.4 pitch 22T pinion (just a example), use it and mount it onto the TA05R stock 0.4 pitch 105T spur (I believe the box stock one is 105 and not 104...)..then roll the car, listen and feel the motor spinning (brushless motor with stock bonded rotor is the best to feel/listen)...then compare the 0.4 pitch pinion with a 64 Pitch 22T pinion........you can find out the Tamiya 0.4 pitch is ALOT better fit then 64P...
I would not recommand use 64P (unless it is necessary) pinion and use the Tamiya 0.4 Pitch spur....it damaged my F103GT 0.4 pitch spur on the recent TCS race within 30 minutes of run time.
On my TA05R...I replaced the Tamiya 0.4 pitch spur and use 64P 108T (the biggest that you can use on TA05R)....then use all the 64P pinion that you can easily find in USA and LHS....problem solved.
On the recent outdoor rubber stock racing....I was using 28t/108T Trinity CO27 motor....had faster race time (5 minutes) then brushless modified car...
Yes...the TA05R suspension drive pins are HORRIBLE...mine bent UPWARD (ended up anti-dive on 1 side...WEIRD)....I ended up cutting some NTC3 shaft, some cheap steel material....wacked several times, not a single problem (Serpent 3mm shaft works too....even stronger).
Solara is offline
Old 07-02-2007, 10:55 AM
  #7958
TMHippo's Avatar
Hi All
I need a recommendation for a replacement bumper. The stock bumper is not cutting it with my two sons, lots of broken suspensions parts
Thanks Rodney
TMHippo is offline
Old 07-02-2007, 11:08 AM
  #7959
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by TMHippo View Post
Hi All
Thanks Rodney
PDub bumper. pdubracing.com and speedtechrc.com carries them.
Hebiki is offline
Old 07-02-2007, 12:27 PM
  #7960
Solara: you are right, it is a 105 tooth spur.
I just bought these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXTG10&P=7
Frost99999 is offline
Old 07-02-2007, 04:43 PM
  #7961
Double Quattro's Avatar
Is this the 108t 64p gear you used? If not, anyone know if the Robinson type ones mate up (hole position, center diameter) to the Tamiya center shaft and pulley?
http://www2.towerhobbies.com/cgi-bin...2&I=LXEZ13&P=K
Double Quattro is offline
Old 07-02-2007, 04:56 PM
  #7962
One time I got rear anti-squat
Old 07-02-2007, 04:59 PM
  #7963
Speedtechrc.com has a line of spurs and pinions made by Xenon. Those are the ones I use
DOTMAN is offline
Old 07-02-2007, 06:31 PM
  #7964
Jpelosi's Avatar
The Robinson spurs fit perfectly on the TA05. They are by far the best spurs that I've ever used. I race outdoors so I like to use 48 pitch, plus that's what I use on my off road cars and it's nice to be able to use the pinions and spurs that I already have and will have on any of my cars.
Jim
Jpelosi is offline
Old 07-02-2007, 07:08 PM
  #7965
Blue_VB_SL253's Avatar
Jim
Will the Robinson spurs have clearance in the normal Tub chassis? As iam looking into buying a Robinson spur and pinions?
Edit: This is a picture of my car.
Blue_VB_SL253 is offline
