Like Tree2Likes
Old 06-29-2007, 01:17 AM   #7921
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Double Quattro View Post
I just noticed a major problem with my rear suspension. The A-arms are coming in contact with the inside of the rim presumably during heavy cornering. This may be why I would get the tail coming out really quickly sometimes. I haven't been able to dial it out and if the rim is "locking up" on the arm, then it would explain the erratic performance.
I currently have 1 degree rear camber and changing it to about 3 will eliminate this problem but I don't really want to have to do that. The rim itself may be suspect; it feels a little loser than the stock Tamiya dish wheels. I use the premount CS27/RP30's because they are the spec tire in my club series.
You'll see in the attached pictures that it's actually chewed out a good portion of the carbon reinforced A-arm. Anyone have this problem. Any input would be greatly appreciated.
The other pic is my newly finished Kawada conversion. So far every setting change is much more pronounced with this chassis. Next week it will get raced for the first time.
trying using a .5mm or 1mm spacer in addition to the alum. hex hub. (i had rubbing on the front until i added a .5mm spacer.)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-29-2007, 01:17 AM   #7922
I would check for any slop on your camber link ball joints, if they wobble, that can happen.
DA_cookie_monst is offline   Reply With Quote
Old 06-29-2007, 02:13 AM   #7923
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Mine just a slight problem as compare to yours. I'm having 1.5 degree rear camber with extra 0.5mm wheel spacer. On the manual that came with my reversible lightweight suspension set, it does recommend to use 0.5mm + 1mm wheel spacer. Hope it helps.
-KilleR- is offline   Reply With Quote
Old 06-29-2007, 05:20 AM   #7924
Originally Posted by -KilleR- View Post
You can try to get the 3racing TA05 conversion kit at http://shopping.rcmodel.hk/product_i...oducts_id=7459
This is the cheapest I found and I bought 1 myself 2-3 months ago.
None in stock
Double Quattro, where did you get your kawada conversion?
gerok is offline   Reply With Quote
Old 06-29-2007, 07:11 AM   #7925
Double Quattro's Avatar
$165 shipped and it got here FAST!!!!
http://www.rakuten.ne.jp/gold/rc-rainbow/index.html
I posted this back on page 262. Give them a try. Though I'm note sure if they still have them.
Double Quattro is offline   Reply With Quote
Old 06-29-2007, 07:18 AM   #7926
Thanks for all the help.
BTW: the multiquote button works great! Anyone know if you can quote from different pages?
Old 06-29-2007, 09:07 AM   #7927
Trader Rating: 16 (100%+)
I have used the 05R with 4.5 and 27 premount tires on outdoor high traction track........does not have your problem. I do have a Schumacher wheel spacer (don't know how thick...0.5mm I think) behind the wheel hex.
Old 06-29-2007, 10:32 AM   #7928
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Use the Tamiya 6mm wheel hex units, This is better than the spacers, less parts to keep up with!
rctouringracer is offline   Reply With Quote
Old 06-29-2007, 03:14 PM   #7929
speedtech had one last penguin chassis for $95 and bought it just in time! w00t! I sorta needed the weight transfer more in the front for drifting.
Old 06-29-2007, 11:14 PM   #7930
Myker*'s Avatar
Send a message via AIM to Myker*
Does anybody happen to have an asphault setup that would provide me with a good basis? Setup sheet would be preferred, i need to know especially what suspension blocks would be ideal.
I also have 42mm universals from my 415 in the 05, and they look like they are a bit on the short size, should I get the 46mm's (i'm using std. suspension)
Also, i have a 102t spur in my 05, and i'm planning on running a monster stock, what pinion size would i be looking to get, or would I need to get a smaller spur and pair it up? Thanks!
Myker* is offline   Reply With Quote
Old 06-30-2007, 08:17 AM   #7931
Blue_VB_SL253's Avatar
Send a message via MSN to Blue_VB_SL253
Hey every one, im a newbew to this forum. Could any one tell me what toe is better on the front, negative or possitive. Plus what pitch (64 or 48) is better and what spur size you are using.
Blue_VB_SL253 is offline   Reply With Quote
Old 06-30-2007, 11:18 AM   #7932
birdy's Avatar
what advantages and disadvantages would there be to swapping my 3 racing chassis back to the tub chassis
thanks
birdy
birdy is offline   Reply With Quote
Old 06-30-2007, 11:27 AM   #7933
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
You'll always want negative toe (toe out) for the front, or at the very most no toe. Most do 1 degree or so out.
64 pitch is more efficient, a bit less noisy, and gives you more options when it comes to gearing, but is more prone to debris getting in the way of the meshing since it uses smaller teeth. I myself have no problems runnning 64p outdoors, but some will prefer the 48p.
Jam-ehz is offline   Reply With Quote
Old 06-30-2007, 12:40 PM   #7934
Which pitch will match up with the stock 104tooth spur that comes with the TA05R?
Frost99999 is offline   Reply With Quote
Old 06-30-2007, 01:35 PM   #7935
bukil's Avatar
Trader Rating: 39 (100%+)
I use 35-37 tooth pinion with my 104 tooth spur for my CO27.
bukil is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
