Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 06-20-2007, 07:50 PM
  #7876
WakattE's Avatar
hey guys, regarding the tamiya spool, do the shaft that hold the steel cups come out during usage? do u glue them in?
WakattE is offline
Old 06-20-2007, 08:41 PM
  #7877
maxepower's Avatar
Default Spool
Their held on with a pin and then the bearing covers the hole and keeps the pin in place!
NO GLUE!
maxepower is offline
Old 06-21-2007, 05:36 AM
  #7878
buboy28's Avatar
Originally Posted by ttso View Post
I'm running on small asphalt track, always run front diff as it allow me to brake and turn at the same time, much more aggressive than 1way, which if you brake-turn, you spin.
i'm using a front one way and like you said if i brake i spin any suggestions on how to prevent or minimize this effect when using a front one way, thanks
buboy28 is offline
Old 06-21-2007, 05:54 AM
  #7879
I use a centre one-way, so the same issue, what I do is set my transmitter to pulse the brake (ABS on a KO) and turn the brakes down, I can slam on the brakes to regress the speed to go into a corner, I set it so that in a straight line it just starts to slide the rear. But I use the brake mostly at the turn-in point of the corner, and the slide aides getting the car in tighter.
DA_cookie_monst is offline
Old 06-21-2007, 06:26 AM
  #7880
buboy28's Avatar
ok thanks will do that did not know that i can also use the ABS function of my radio to an Electric TC all the while i thought that it is only used for Nitro vehicles
buboy28 is offline
Old 06-21-2007, 09:44 AM
  #7881
Yes, Thats an excellent idea!! Would you mind sharing your ABS/brake settings? I have a KO (Helios) as well.
qwkpony is offline
Old 06-21-2007, 10:53 AM
  #7882
ttso's Avatar
Acturally if you use front one-way, you try not to brake at all.
First you use brake-travel to limite the brake stength to a very small level that will slightly slow your car down, just a bit faster than off-throttle drag brake. Than, you increase front steering, loose rear for rotation. If you get a right setting, it would be like off-throttle > turn > corner in. No brake unless you get into a 180 hairpin corner. Than it's like brake > off-throttle > turn > corner in.
The driving style with front 1way is very very different with front-diff/spool, setting also be very different. For me my driving style fit diff/spool best, and bcz my track is small and lots corner, plus I run stock, I use diff.
ttso is offline
Old 06-21-2007, 11:11 AM
  #7883
I shall dig out my KO later and rummage through the menu's and post the setting for them.
It acts live a harsh drag brake, but by setting the transmitter up to do it rather than calibrating the ESC then reducing the EPA, it means you can swap ESC and keep the exact setting.
Old 06-21-2007, 05:22 PM
  #7884
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
Got to run my TA05 on the track today for the first time. Must say I am very impressed by how smooth it is. I did manage to pull a rear inner suspension pin out of the suspension mount. Which cracked the mount. But overall it performed very well. My current setup is pretty much stock, with 3 racing shocks with 40wt oil, 3 racing front one way, and cs27 tires.
Blacktiger355 is offline
Old 06-23-2007, 12:12 AM
  #7885
Simon K's Avatar
I'm running my 05R for the first time tomorrow. Must admit, I've been a little disappointed with the way the build went(those grey plastic ball ends are awful) and how a couple of the factory options I'd bought didn't work as well as I felt they should.
I ordered the Tamiya option carbon fibre battery plate. It came with two blue aluminium standoffs to replace the factory ones. When fitted, there was a good 2-3mm of clear air between the cells and the snap pins. I'm assuming this is due to the plate needing to be high enough to allow the fitting of stick packs but I certainly didn't expect my 4200's to be floating around semi-restrained. After a bit of searching around, I found some suitable rubber grommets to keep things locked down.
The lightweight center layshaft could also have done with a couple of shims included. Considering the kit itself has all sorts of extra fasteners included I don't think one or two suitable sized washers packaged with the layshaft would go amiss.
I'll reserve judgement until tomorrows maiden run, I have a feeling I'll be in a much more positive frame of mind.
Simon K is offline
Old 06-23-2007, 05:46 AM
  #7886
OSherman's Avatar
Thumbs up
You will be...
OSherman is offline
Old 06-23-2007, 02:57 PM
  #7887
Skitee's Avatar
You will be very surprised how good this car is out of the box, I have lost count of the number of people who praise the car after the first run. Especially the TCS guys who have moved from the TB-02 and TA-04.
Skitee is offline
Old 06-23-2007, 05:34 PM
  #7888
macnkitty2002's Avatar
is there anything you need to get hop-up wise right off the bat for this car, or can it be run competitively at local club races? i know it is the "R" version with all the goodies, but as we all know, some cars need one or two pieces necessary to be truly race-worthy. do any exist in the 05R?
thanks
macnkitty2002 is offline
Old 06-23-2007, 08:17 PM
  #7889
PitNamedGordie's Avatar
thanks
I don't own an 05R but the 05 needed a few parts to be truly race-worthy. The 05R has all of the extras the 05 didn't. My 05 has been upgraded but I still don't have all of the parts that are on the 05R. It's a great value.
PitNamedGordie is offline
Old 06-23-2007, 09:49 PM
  #7890
buboy28's Avatar
thanks
the 05R is already loaded with almost all of the hop-ups that goes with the kit and already is a very raceworthy car but if you like you can still add a few hop-ups like the carbon fiber shock towers ( front and rear), carbon fiber foam bumper holder and the aluminum motor mount
buboy28 is offline
