Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 06-14-2007, 08:54 AM
  #7846
tc3team's Avatar
If it helps you, the dimensions are below if you wanted to measure up
http://www.teamnovak.com/products/esc/TC2/index.html
I have the Cyclone TC in my spare car (for my son when he's older hehe) which I believe to be the same size, but the most recent Novak capacitor is BIG, so I could see a problem installing it, even in a TA05.
Tbh I think it would be a push to get it in, not impossible, but pretty tricky.
tc3team is offline
Old 06-14-2007, 09:22 AM
  #7847
Awesome, thanks for the help!
EDIT: do you think an LRP ESC with these dimensions would fit?
Length:41mm
Width: 36mm
Height: 19mm
Frost99999 is offline
Old 06-14-2007, 07:46 PM
  #7848
dubifreak's Avatar
Originally Posted by sosidge View Post
Basically you change the suspension blocks. There is 1/2 degree difference between each block. Standard combo of 1A front and 1D rear gives 1.5degrees inboard, standard plastic rear hubs have 1 degree outboard, so that is 2.5degrees toe as standard.
thx for the help man
dubifreak is offline
Old 06-14-2007, 10:00 PM
  #7849
Length:41mm
Width: 36mm
Height: 19mm
I am driving with LRP Sphere Comp and it fits easily.
TommyW is offline
Old 06-15-2007, 01:23 AM
  #7850
tc3team's Avatar
Length:41mm
Width: 36mm
Height: 19mm
No problem
Sorry,im not familiar with the ta05r chassis, (I have a ta05 with a 3racing chassis which is a bit different).
Seeing as you already have the kit, measure out those dimensions on a scrap peice of paper, cut it out and allow for the wires and see how it is in different positions on the car is the best thing I can think of
tc3team is offline
Old 06-15-2007, 06:41 AM
  #7851
No problem
The kit is actually arriving in the mail today...Im so excited I just peed a little.
But yeah, thats what I will do Thanks!
Old 06-17-2007, 12:58 PM
  #7852
Double Quattro's Avatar
Default KAWADA TUB501
I got it straight from Japan and just put it together. I'll report on the performance in a few weeks.
Fit and quality of parts are as good if not better than Tamiya. The shock towers are the thickest I've seen at 3.5mm!! I'll put this up against a TA05MS any day and better yet, unlike the 05MS, it's a real TA05 with equal belts!
Attached Thumbnails Tamiya TA05 Touring Sedan-kawada-ta05-1.jpg   Tamiya TA05 Touring Sedan-kawada-ta05-2.jpg
Double Quattro is offline
Old 06-17-2007, 01:17 PM
  #7853
When I assembled mounted the diffs/gearboxes, the front belt seems a bit more tight than the rear. I double checked the settings and everything is correct...is that normal? I have the TA05R with blue belts...
Old 06-17-2007, 01:23 PM
  #7854
I think I had my rear belt set 1 notch tighter than the manual says when I initially built the car. You will also feel it get loser after you run the car a few runs. Just like the diff, you may have to adjust the tension after you "break it in"
Old 06-17-2007, 07:20 PM
  #7855
Cool, thanks!
This is seriously the nicest kit I have ever put together...the instructions are fantastic and everything fits together perfectly. Its pretty brilliant.
My only beefs are with having to cut down ball cap ends (wtf?) and the relatively soft metal of the scews, which strip pretty easily.
Otherwise its just perfect. So happy with my purchase
Old 06-17-2007, 08:00 PM
  #7856
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
May I know what is the price for this conversion kit?
-KilleR- is offline
Old 06-17-2007, 08:58 PM
  #7857
$165 shipped and it got here FAST!!!!
http://www.rakuten.ne.jp/gold/rc-rainbow/index.html
Old 06-17-2007, 10:50 PM
  #7858
peter p's Avatar
Hi what make is that kit
peter p is offline
Old 06-18-2007, 01:07 AM
  #7859
Chassis & Towers are Kawada (TUB501, TUB503/504)
The bumper support bits are Tamiya and 3Racing stacked together.
Old 06-18-2007, 01:54 AM
  #7860
This may sound like a dumb question , but what are the advantages of the kit? Is it a lot lighter? More rigid? Lower center of gravity? Less static? More durable?
It sure looks nice though. I'm sure it's worth doing just for looks!
I'm not questioning why do it, I honestly would just like to know why it's better.
tom
tsyrc is offline
