Like Tree2Likes
Old 06-06-2007, 07:59 PM   #7786
AWK
AWK's Avatar
Hey thanks a ton! What bodies are you testing? I will be there with my new Pennzoil Skyline to try out. Someone let me try their Skyline and Carrera GT to compare to the 350z I had been driving, and I liked the Skyline a lot better than either one. The only body I didn't get to try was the Lexus which i heard was pretty good last year.
You're also running GT2 right? Me and another guy were the only 2 running GT2 cars last Sat and need more people to compare with!
AWK is offline   Reply With Quote
Old 06-06-2007, 08:05 PM   #7787
GSP
Default Spool and Battery
1. I have to ask this question what is a spool? I know from when I ran onroad 4 years ago what a one-way is but not a spool.
2. What Lipo packs fit this car? Or do all or any fit.
GSP is offline   Reply With Quote
Old 06-06-2007, 08:37 PM   #7788
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
a spool is a locked unit. or a direct coupling.
almost all packs fit the car, both orion packs, many of the uncased cells like Max amps.
tamiyarcracer is offline   Reply With Quote
Old 06-06-2007, 09:22 PM   #7789
Regional Moderator
Darkseid's Avatar
By "locked unit" he means a completely locked front unit in place of the front diff. Meaning that with no diff action at all, the two front wheels always turn at the same speed.
This can be very effective in the right conditions, but it is very brutal on the front drive components.
TLR 22...Tamiya F104...
Old 06-06-2007, 11:25 PM   #7790
Trader Rating: 37 (100%+)
Just make a spool from your diff. Take the balls out and put cardboard in there. Then lock it down....spool like drive without the destruction in a crash
Ran my TA05R w/ a 13.5R on carpet...first time racing in 7 months. The car is really good for a tub and mid-level car. It ran well and I was impressed but could see the difference with the weight. For the money it's probably the best new car in that $200 price range.
Anyone want to buy a 1 raceday old 05R?? :P
Nexus is online now   Reply With Quote
Old 06-07-2007, 03:21 AM   #7791
Simon K's Avatar
My old Losi G+ came with little sandpaper pads that you could put in the diff to achieve this. Never tried it but kept them nevertheless
Simon K is offline   Reply With Quote
Old 06-07-2007, 03:33 AM   #7792
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Forgive me if this has been brought up in this thread before, but you can't search threads anymore since the "upgrade".
Has anyone notice a binding problem with the center shaft on the "R" with the blue aluminum upper plate?
I put it together all stock...then started picking up a few little options here and there...still haven't gotten it running, I just like looking at it.
Anyways, it never seemed really free, but tonight I decided to test out my buddy's RPM "bearing blaster" thingie and clean the grease out of the bearings. When I did the bearings for the center shaft, they were really free...they just spun and spun. As soon as either side of the blue plate was snugged at all, the shaft would bind up pretty badly. It would almost "clunk".
I tried the plastic one out and it was better, but still bound up some. It seems like the center mount saddles for the bearings are a tiny bit shallow. I used a utility knife to shave a few thousandths off the underside of the blue plate between the screws to keep it from crushing down on the bearings.
It's really free now, but I was kinda surprised how much I had to shave off to get there.
Turbo Joe is offline   Reply With Quote
Old 06-07-2007, 03:36 AM   #7793
sosidge's Avatar
No problems at all here on my R. Perhaps you got a bad part?
Old 06-07-2007, 04:16 AM   #7794
Turbo Joe's Avatar
I don't think it's the upper plate, it's just flat. It could be the center mount though. I could do either pair of screws separately...and either one would lock the bearing for that side.
Old 06-07-2007, 08:03 AM   #7795
LOSI123's Avatar
Trader Rating: 63 (100%+)
I have a ? ,
Can you balance a TA-05R between left and right side with weights and still keep it at 1525 grams (with standard body, rubber tyres,mtr esc etc.. )
even with ib4200 6 cell pack which weigh in at 440grams.
as looking at the chassis design the batt sits out from centre of chassis alot compared to alot of the new cars.
like is it a light car to start with, so as can put weights on mtr side to balance weight of car?
LOSI123 is offline   Reply With Quote
Old 06-07-2007, 08:07 AM   #7796
sosidge's Avatar
No, it is overweight to start with, no point adding weight to balance, you would need a hell of a lot.
Old 06-07-2007, 09:04 AM   #7797
dag32's Avatar
Trader Rating: 109 (100%+)
Sorry guys shameless plug here, selling my TAO5R please check it out Thanks!
http://www.rctech.net/forum/showthread.php?t=167010
dag32 is online now   Reply With Quote
Old 06-07-2007, 09:16 AM   #7798
Probably bad part...
I ran mine with a Novak 13.5R and never noticed a bind....Solara on this thread has run his with a 4.5R and noticed no problems either.
As for this weird static and sparking issue...That has to be isolated or bad wiring. With all the wires needed to run a Novak BL system, transponder, and fan on a TA05R things can get bunched up. Also I would think running on carpet would cause this static/spark thing to happen even more. After 6-7 runs on ozite, GTB system, KO 2143 servo, and personal transponder mounted I had ZERO issue with static/sparking/glitches.
Unless you are trying to push another .001sec out of each lap I would rather use the sandpaper over a real spool any day. A real spool is great but there is no "give" when you crash. So the end result could be a decent amount of broken parts. The sandpaper spool will let you have something that's locked down but still "give" in a crash. This can save you some cvd's, outdrives, etc
Plus cardboard is practically free :P
Old 06-07-2007, 09:36 AM   #7799
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I've run an Orion 4800 in my car for a year and the car is about 15 grams off side to side...it ballances very well with the Lipo.
Originally Posted by LOSI123 View Post
I have a ? ,
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-07-2007, 09:48 AM   #7800
Trader Rating: 16 (100%+)
Yes...ran with Nexus last night, his TA05R (just like mine) is definitely capable to run against the big dogs like Mi3, Corally or even TC5...I ran mine with rubber/13.5, foams w/13.5, foams with 4.5 outdoor and rubber w/4.5 outdoor...so far, no diff problem, no glitch problem, no chassis static problem, no center motor mount binding problem.......overall, a good $200 RC car for mulitple motor speed and mulitple tires and indoor/outdoor track. A car to keep for awhile definitely...
The only problem is....using SPOOL. Now, it is to my understand that, a stock TA05R just cannot use the spool without changing 2 things (1 of the 2, your choice)
(1) shorter CVD........or
(2) wider pivot blocks @ front
Both will give the front track width wider, in order to create more space between the end bone and the spool's outdirve....that was my problem last week when I was running 4.5 with spool...when I was turning, the whole front will vibrate like they are going to fall apart...it did not break anything for me just because the spool/cvd were JUST barely has enough space for each other...but I am sure if I keep running it for another day, something will break..
About mod a front diff to be the spool methrod mentioned from NEXUS...it is a cheap way to try a spool without spending $25...however, here is the warning, the OUTDRIVE of your diff is plastic....and by using SPOOL, the plastic outdrive just will not cut it. If you don't want to ruin that ball diff outdrive, just try the spool for a short period of time and see you like it or not...and do not keep using it as a spool, that outdrive will not last. Thats why the Tamiya Spool I have is hard metal material...there is a reason about it.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
