Like Tree2Likes
Old 07-20-2005, 12:39 AM   #766
Ghostfit's Avatar
Originally Posted by vi3tishduy
Wait.. also what about the front hubs?
Usually you refer to the front Assy as C hubs/Uprights and Knuckles(Which houses the bearing) and the rear assy as simply Rear hubs/Uprights.
Help lots if pple understand the exact part you are talking about.
Ghostfit is offline   Reply With Quote
Old 07-20-2005, 01:33 AM   #767
tomdav's Avatar
Trader Rating: 42 (100%+)
Default 0deg hubs
"Oh, I forgot to mention... those suspension blocks go with 0 degree rear hubs. Not the 1 degree hubs. It's also for LW suspension as well.......
It's basically giving you 2degrees front sweep. And 2.5 degrees rear toe." - KillRuf
Ah, I emailed Champ R/C and they say that there are no 0 degree rear hubs.
Part #: TAM53807 alum. 0deg hubs.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 07-20-2005, 03:53 AM   #768
Ballsie's Avatar
Remember that those were originally designed for the 415MS / Evo IV but will fit your TA05 if you are running the lightweight suspension.
Ballsie is offline   Reply With Quote
Old 07-20-2005, 04:35 AM   #769
ttso's Avatar
Here is more detail:
If you running TA05 stock suspension, TA04, TRF414, TRF415, EVO3, TB02 suspension parts will work "except" swinging shaft.
If you running LW suspension, TRF415MS, EVO4, EVO4MS, TB02R suspension parts will work "except" swinging shaft.
Hope this help
ttso is offline   Reply With Quote
Old 07-20-2005, 06:44 AM   #770
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Aw crap... How much is it for the LW suspension? 80 dollars? Hmm.... So that setup that killruf said was only for the 0 degree hubs... Anyone have a good idea for a one-way, asphault track? Also ttso, which swingshaft would I need for it to work with the LW?
vi3tishduy is offline   Reply With Quote
Old 07-20-2005, 07:55 AM   #771
ttso's Avatar
42mm 100% no work, 46mm works mostly, and 48mm 100% work
LW is about 80usd. But stock is also good for asphault. LW is not really 100% must.
Old 07-20-2005, 10:44 AM   #772
vi3tishduy's Avatar
I dont know what suspension to use then, If I get that lw kit with the alloy hubs I'm going to go over board with price... Any suggestions?
Old 07-20-2005, 11:12 AM   #773
vi3tishduy's Avatar
I'm trying to see what I can do. I've never had a tamiya so i'm skimming through my TC3 manual to find something..
Old 07-20-2005, 12:34 PM   #774
ttso's Avatar
If the only parts supply in your LHS is LW suspension, go with LW suspension.
If the only parts supply in your LHS is stock suspension, go with stock suspension.
If LHS has both, pick the one you prefer
If LHS doesn't have both, re-exam if you really want a TAMIYA car without LHS support first!
Stock is better on durability. LW is better on setting ability (and slightly more agility). I see not much performance difference if you set them correctly. LW, indeed, has more settiong option, but also, easier to break.
So, check your LHS support first. This is what really matter! You will never want to play a car without LHS parts support.
Old 07-20-2005, 12:38 PM   #775
rayhuang's Avatar
ttso-if you or anyone else gets a chnace-can someone throw a pair of 28mm foams on the LW suspension and see if it fits? I know the evoIV steering knuckles make it a no go. Does that mean all LW suspension pices suffer the same fate? No foam tires?
Old 07-20-2005, 01:46 PM   #776
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
All lightweight suspension sets use the same steering knuckles... not that I run foams, but that is not a good news I guess.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 07-20-2005, 01:54 PM   #777
vi3tishduy's Avatar
Well, my LHS only carries Traxxas, AE, Losi. SO yes that is a problem but, I can always order online Also, I've heard bad reports on the JRXS, I would get it but, not sure, i'm some what set on the TA05. As for the TC4, I wanna try belt ^_^. I guess with the C-Hubs i'll have to go along with the 1degree with the setup that KillRuf gave. with those suspension blocks that Satoshi use's how much kickup does it give? Like I said earlier I was told that with 4degree total is good for One-Ways.
Old 07-20-2005, 03:08 PM   #778
Ray the easy fix as Fernando used at carpet nats is to use a Pro4 knuckle and a 1mm shim, as the pro4 knuckle is a touch shorter in vertical height. I think you also have to use an old style outdrive for the CVD also. Look back at the 415 thread and there was a pretty detailed, easy fix to make the LW suspension work with Foam.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-20-2005, 04:30 PM   #779
vi3tishduy's Avatar
I guess i'll just stick with that set up then.. 1 degree rear upgrights.. What about the front c-hubs and upgrights? If I calculated right... 3.5 in the rear and i'm not sure what stock front c-hub is... Is it ok if I do it this way?
Old 07-20-2005, 04:56 PM   #780
JimmyMac's Avatar
Simple, if you go with 1degree rear hubs, just switch the rear block from a 1B to a 1X. This will give you the same 2.5 rear toe.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
