Like Tree2Likes
Old 06-01-2007, 12:15 PM   #7726
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I run a 90t 64p and I am pretty sure a 88t would work fine too. I can easily get into the 4.00 range if needed.
Originally Posted by Nexus
Lets skip that part and tell me what spurs are the smallest you can run in the 05R...
Or atleast someone post what spur/pinion combos they are generally using when running a 13.5R Novak BL motor. I bought a big 108 to run my 4.5R Novak BL and now need to know what spur to order to run the 13.5R.
Thanks.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-01-2007, 12:20 PM   #7727
Goingfast's Avatar
Trader Rating: 29 (100%+)
very true
Goingfast is offline   Reply With Quote
Old 06-01-2007, 12:57 PM   #7728
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by sosidge
This is a version of KO's fix. I think the intention is to give the static a discharge route that avoids the servo, as it is metal-gear servos that are being affected. So the static will run along the wire (least resistance) rather than trying to discharge through the servo.
I see- well it's certainly worth a try. Just remember though that anodizing acts as 100% insulation so if you are trying to ground the alloy center piece then the anodizing will need to be scraped off where the screw contacts it.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-01-2007, 01:02 PM   #7729
Trader Rating: 37 (100%+)
Any reason a 78T spur and 35-42T pinion would not be able to make gear mesh?? Just wondering since I saw Robinson Racing makes a 78T spur in 64P...
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 06-01-2007, 01:25 PM   #7730
I don't think you will be able to reach the 4.75-5.0 final that you need for a 13.5. That's a pretty big 48p gear.
Get a 68-70t 48p gear and a 30-32t 48p pinion. Those will be all you need.
The 78T from Robinson is 64P.
Old 06-01-2007, 01:25 PM   #7731
Old 06-01-2007, 01:28 PM   #7732
A 78t 64 spur? Wow, didn't know they got that small...The the answer is no, the smallest I think you can use is 88. And you need from 38-42t pinions to reach the right rollout.
Old 06-01-2007, 01:33 PM   #7733
Yea they are rare but out there...
Thanks though I'll just grab an 88 and load up on the bigger pinions.
Old 06-01-2007, 05:47 PM   #7734
Send a message via AIM to A-Ko
With the 78t I think the smallest pinion you can have is either a 45 or 46. I was putting a 78t in but kept having to go much bigger than I wanted to for the pinion & the track. I was shocked when I found them and I did buy out a place on ebay but have not used them yet. Your probably better off with a 81 or 85.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 06-03-2007, 03:00 PM   #7735
Are there any guys using the TA-05R with the 3.5R brushless.
I had a cut-off issue in the 4th minute in a main with the (70/16)9.843 ratio.I think it is important to mention that the track temp was near 60 celcius
There is one more point;because the car doesnt let me to use 15 pinion(10.500 ratio)or greater..
Are there any solvings about this problem.Thinking of abrassing the motor mount with the dremel cutting tool..
Rifat is offline   Reply With Quote
Old 06-03-2007, 05:09 PM   #7736
maxepower's Avatar
Talking RE: FDR
You can fit up to a 108 spur with 64 pitch. You can get the ratio you need with a larger pinion.
Just my 2$
maxepower is offline   Reply With Quote
Old 06-03-2007, 06:24 PM   #7737
Simon K's Avatar
A couple of quick questions please...
Is the Tamiya Titanium screw set for the TA05(TA-49360) Philips head or 2mm hex?
Does the 05R come with the optional lightweight center layshaft(TA-53915)?
Can anyone post the maximum steering servo dimensions that are in the manual, I saw them when I had a quick browse but can't remember them. I'm getting a new servo at the same time as the car and don't want to buy one thats too big. Looking at an Airtronics/Sanwa ERG-WRX
After seeing a couple of 05R's running at the weekend, my order for one will be sent in the next day or so
Simon K is offline   Reply With Quote
Old 06-03-2007, 11:25 PM   #7738
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Titanium screws comes in hex.
The option comes with TA05R can be check at http://www.tamiyausa.com/product/ite...oduct-id=49418
[12~15 + 30] x 39~41 x 20.5 mm is the max servo dimension as stated in the manual.
-KilleR- is offline   Reply With Quote
Old 06-03-2007, 11:29 PM   #7739
Simon K's Avatar
Thanks Killer.
Old 06-03-2007, 11:56 PM   #7740
Maxepower!
Thanks for your quick reply.Thinking of a 108t will fit into the ta-05?It seems like it will rub to the ground
Have you ever tried using the 108t in your car?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
